Question about Epson Stylus Nx420 All-in-one Color Inkjet Printer
Why am I getting W11 error on Epson Stylus NX420?
Telling me 2 of 4 cartridges need to be replaced - and they're all new
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • Epson Expert
  • 236 Answers
Steps to troubleshoot Epson Printer error code W-11
Step 1: Replace the printer cartridge
The very first step is to replace the cartridge. If you see that this error code remains as usual even after a replacement has been properly placed inside the printer then, the most probably it signifies that the cartridge was inaccurately installed. To replace the cartridge, perform the following instructions:
§The very first thing is that the Epson printer and its software will let users know when an ink cartridge is in low or expended state.
§If it is found that the ink cartridge is expended then, an automatic message will appear on the printer's LCD screen asking users to replace
§It will further perform a proper printing process, copying as well as the scanning in a smooth way.
§Make sure that you have kept the ink cartridges out of the reach of children.
§Keep a note that you won't be able to copy, scan or print whenever an ink cartridge is expended even if the other cartridges are not expended. So, it is recommended for users to replace the expended cartridges before copying, scanning, or printing process.
§Keep a track when you are working with Windows system to check whether black ink is low or there is more color ink than black ink. A user will get an error message when to print from their computer device.
§The next thing what a user needs to do is simply to save black ink by using a mixture of colors. This message will only appear if a user has selected the "Plain Paper/Bright White Paper" optionas the paper type and the "Text' as the Quality Option setting.
If you need any further help kindly visit us: Epson printer error code w 11
Toll-Free No: +1-888-633-7151
Posted on Aug 28, 2019
    Habit-Forming:
    New Friend:
  • 23 Answers
It is a very common Error in Epson printer as it is related to ink cartridge Error Code W-11 in Epson Printer is related to the installation or problem with cartridge. The cartridge might have gone empty that is why the printer is not able to print. If so, replace your cartridge with a new one according to your choice. One more cause can be a reason to this problem. The cartridge isn't installed properly due to which the printer cannot read/detect the presence of cartridge. Detach the cartridge and reinstall it properly.
You may take the help of Epson Printer Support Number
1-800-213-8289 if you are unable to resolve the Error.
Posted on Sep 14, 2017
    New Friend:
I ad tried all kinds of things after looking all over the internet for a solution. Finally, I found out what the problem was. The little metal clips inside that make contact with the chip... One had fallen out of place and was laying at the bottom on the print well. I retrieved it, cleaned it, carefully reinstalled it, replaced the cartridge in question and it started charging right away.
Posted on Apr 17, 2013
SOURCE:
Basti
  • 1447 Answers
SOURCE: epson stylus dx6000 error message e-02 have tried
Hi
Chances are the mechanism to recognize the ink cartridges is already damage and it may cause a lot having it replaced. I suggest to get a new printer instead specially if you have tried reseating the ink cartridges several times and won't work still.
Thanks for using Fixya
Posted on Oct 14, 2010
Testimonial: "Thanks, thats wot i thought. cheers"
Basti
  • 1447 Answers
SOURCE: epson stylus photo rx580
Hi-
You are having a hardware problem with the printer, the sensor is damaged. call epson @ 5622761300 for replacement ink and printer.
Hope this helps
Posted on Nov 08, 2008
  • 28 Answers
SOURCE: Installed new OEM Epson ink cartridges, get error message 2. Cartridges are installed correctly and tested ok. Chip problem? Print head problem? Cartridge problem?
Go to printers and faxes, and uninstall the printer.
reboot, this should solve the problem
Posted on Apr 14, 2009
SOURCE: Scan without replacing print cartridges on Epson Stylus NX410?
You actually can scan documents when you dont have ink. Instead you will have to activate the scan function from the epson driver/program instead of pressing the scan button directly on the printer. I had the same problem and it took a while to figure out.
Posted on Jun 30, 2010
  • 26 Answers
SOURCE: (Epson Stylus C60)red light blinking, says contact
keenepadgl, "Contact service engineer" for a C60 used to be all you could do. Now you can go to SSC Service Utility and download it. But the red light blinking (if that is all that is happening) simply means you have a ink cartridge that is low but not empty. If the red light stays on, then it means a ink cartridge is empty. By downloading SSC Service Utility you can solve about any problem you have with a C60. That's what the "Service Engineers" use. Check out the protection counter reset in SSC, that is the main reason people had to send their C60s to have serviced., and what service would do is press the reset button in SSC program. NOTE: I would go to inkmizer and get some cleaning fluid instead of nail varnish remover.
Posted on Mar 24, 2010
My epson stylus nx420 printer does not recognize the new black ink cartridge
I thing you need to call customer support try 0-800-090-3966 for more info
thanks
Sep 06, 2017 | Epson Stylus NX400 InkJet Printer
Epson stylus nx420 will not feed paper
If this is an older printer, the pickup "fingers" get worn and need to be replaced
Oct 11, 2012 | Epson Stylus Nx420 All-in-one Color Inkjet...
Epson 4000 will not see new ink cartridges
epson is crappy printers i know alot of people like it on repairing them i will never buy epson or brother ... anyways hopefully you have OEM/REAL epson cartridges.......otherwise it will give you an none or empty cartidges.
Jun 29, 2012 | Epson Stylus Pro 4000 InkJet Printer
Epson stylus photo rx700 lockout
Look for cartridge sensor and clean them with a piece of close. re-install the cartridge and see if the problem is solved. if not may be U have bad sensor so replace with new ones.
Jun 02, 2012 | Epson Stylus Photo RX700 All-In-One InkJet...
How to change Ink Cartridge on Epson NX420
you have to pull out scanner unit upward. you can see all four cartridges. now you can change cartridges.
Jan 17, 2012 | Epson Office Equipment & Supplies
Epson Stylus SX515W black will not work. Put in a new cartridge, still would not work. checked it was in correctly, etc and all the time when the cartridges are changed it recharges. Have got through a...
From: https://www.computing.net/answers/hardware/epson-styles-nx420-printer-wont-print-black/85723.html
...I figured it out for my printer today... just got new ink, had the same problem, saw these posts getting me nowhere, so I figured ok the ink cartridge is fine... so what else is between that and the paper. I decided to go out on a limb and get a paper towel and clean off the little plastic nubbin that's inside the printer (the part that sticks into the cartridge, sticking out from where you place the ink) and it printed completely perfectly after that.
Apr 05, 2017 | Epson Stylus CX6600 All-In-One InkJet...
My Epson stylus NX 400 continually says "error..replace ink cartridges" I did and nothing changed.
Assuming the cartridges are new (since almost all of them have a chip on them)
1. Make sure you match color of cartridge with the correct slot. If same error, then
2. remove all carts. and clean both cartridge holder and cartridge contacts with alcohol.
good luck
Nov 06, 2010 | Epson Stylus NX400 InkJet Printer
Epson Stylus Nx420 All-in-one Color Inkjet Printer Logo
5,193 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
