Question about Innovage Mini Flip Phone 1510255
Innovage Deluxe Handheld Mini Flip Phone Problem
I receive the calls but I can't enter the numbers to call someone
You need to change the two batteries. by any chance do you have the manual for your phone. i need a copy if you can do this for me.
Posted on Jan 03, 2009
I have a Shift 3 lcd touch panel phone with 12 digit calculator.I cannot find the manual for this phone.I can receive calls but cannot call out.A manual would be helpful Thanks
  • Check your phone to make sure it is set up properly. Open the back of the phone by pressing your fingertip on the small lever that opens the battery area. The battery cover will come off in your hand. Insert three "AAA" batteries into the back of the phone so you can use the night light feature. Replace the battery cover by sliding it into the battery area and clicking it into place with your fingers. Connect the phone to the telephone phone jack by connecting one end of the wire to the phone and another end to the wall jack. Connect the handset to the phone by inserting the end of one end of the curly phone wire to the handset and the other end into the side of the phone. Listen to the dial tone by pressing the speakerphone or picking up the handset to make sure your Innovage LCD touch panel phone is connected.
  • 2
    Review calls you missed. Use the up and down arrows on the Innovage LCD touch panel phone to view the caller ID phone numbers.
  • 3
    Use the night light to view the Innovage LCD touch panel in the dark. Slide the switch on the front of the panel to turn the night light function on. Slide the switch to the off position to turn the night life off.
  • 4
    Adjust the volume on your speaker by selecting the speaker loudness that you want. Press the hands free button once and press the "Delete" button. Choose a loudness from one to four.
  • 5
    Press the hold button on the front of your Innovage LCD touch panel phone. This will activate the hold function when you are on a call and it will allow music to play while someone is on hold. The hold music is built in to the phone and will automatically play when you press hold.
  • 6
    Save a phone number as a VIP number on your Innovage LCD touch panel phone. Press set and save when an important number comes onto your caller identification. This makes it harder to delete the phone number by accident.
  • Read more: Innovage LCD Touch Panel Phone Instructions ' eHow.com http://www.ehow.com/how_7256783_innovage-touch-panel-phone-instructions.html#ixzz1eMIaaXLV
    Sep 23, 2011 | Innovage Speaker/Caller ID* LCD Touch...
    I am setting up my Innovage Deluxe Corded Handheld Mini Flip Phone for use with my MagicJack while traveling. 1. I can receive incoming calls fine, just pressing the green phone button to connect and...
    First i would say both units are still in good condition as you can still receive calls from them comfortably without any hassles. If you cannot dial out it is probably as a result of the area code or the dial code not being set correctly. The area code helps to determine which location the home phone is situated to enable the calls to be routed through the proper channels to enable connectivity. The dial out code basically does the same as the area code. Both of them are just like address systems to determine where and how the calls are routed. Try setting both codes and see if the calls still dont go.
    Hope this solution has been helpful?
    May 01, 2011 | Innovage 1502084 Corded Phone
    How do I integrete my flip phone with magic jack
    When you sign into majic jack and access your account, there is a space down the page where you can forward your number too. Just put your cell phone number in the space provided and all calls from the majik jack will go to your cell.
    Sep 02, 2009 | Computers & Internet
    What is a dial out code?
    A dial-out code is a number that is automatically added when you dial a number. It can be either your area code or (usually) your country code.
    Let's say the number stored in your phone is (123) 456-7899. So if your dial-out code is set to "+1", then the number dialed is +1-123-456-7899. This ensures that, wherever you are on this planet, you will always reach that number in the US.
    On home phones you can sometimes set a dial-out code (like "123"), and if you dial 456-7899, then it automatically adds your area code to the number.
    What sometimes happens is, let's say you bought your phone in the US, but you live in another country, your phone still automatically adds a "+1" to all your numbers stored in your phone unless specified otherwise. That's why you have to set the dial-out code to your specific region.
    Jan 11, 2009 | Innovage Lands Phones
    I can receive the calls but I can't enter the numbers to call someone
    you need to change the batteries in your phone. do you have the manual for this phone? if so could you send me a copy as i lost mine. thanks
    Dec 31, 2008 | Innovage Mini Flip Phone 1510255
    My Innovage cell/flip phone #150255
    see it is a old modeled phone.better you consult your vendor
    May 31, 2008 | Innovage Mini Flip Phone 1510255
    this is a corded phone that plugs into your home phone line. This is not a mobile phone.
    Feb 05, 2008 | Lands Phones
    Innovage photo keychain.
    when I try to enter new pictures it says it failed what do I need to do
    Dec 23, 2007 | Innovage Mini Flip Phone 1510255
    Innovage Flip Telephone
    i found mine but i dont know how to send it to share it with others that needs a copy
    Dec 10, 2007 | Innovage Mini Flip Phone 1510255
    Lands Phones Logo
    238 people viewed this question
    Top Innovage Lands Phones Experts
    wiccan8thhouse
    wiccan8thhouse
    Computer Repairing
    Computer Repairing
    Kolbrun...
    Are you an Innovage Lands Phone Expert? Answer questions, earn points and help others
