Question about Hoover Windtunnel Supreme U5280-900 Upright Vacuum
Plugged hose on Hoover Windtunnel
I have no suction on the floor or carpets and feel the hose is plugged. I have replaced the belt so it's not that. There is no air blowing like there usuaslly is...help
  • 1 more comment
  • geeeeeee Dec 31, 2008
    Thanks for replying so quickly. I didn't think I would get an answer so fast and being frustrated I just happened to do just what you suggested before I came back to check and YEAH it works now..so much better. Have a Happy New Year!
  • Anonymous Mar 14, 2014
    hoover windtunnel not sucking at the hose
    very little sucking at the hose
    Problem Solver:
  • 13 Answers
You will have to remove the bottom cowling under the vaccum cleaner there are 4 phillips head screws one at each corner when you turn over the vaccum cleaner, take this off and remember how it goes back on. in the area where the hos is there will probably be a clog at that point. remove this and pull hose off and make sure it is not clogged farther up the hose, reinstall and check
Posted on Dec 31, 2008
  • ZZZZ
    ZZZZ May 04, 2014
    hose does not come off..cheap vacuum cleaner
There is too much suction even with the hand tools on Hoover wind tunnel. Can i adjust suction somehow?
Hi, it's Jeremy from Crucial Vacuum.
If there is too much suction, adjust the nozzle control knob to a higher setting. The knob is located on the front of the vacuum at the bottom. For optimal cleaning efficiency a low setting should be used for most types of carpet and for hardwood floors, tile, and deep carpets use a higher setting.
You can purchase direct all of your replacement filters, bags, and accessories for your Hoover vacuum from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=hoover
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jun 17, 2014 | Hoover Self-Propelled WindTunnel Bagless...
Why would a Hoover Windtunnel have no suction?
It could be clogged at the head or throat, or you might have a hole in the hose. Unplug the hose; if you're getting suction where the hose plugs in then the problem is in the hose or the head. If you're not getting suction where the hose plugs in then the problem is in the body, probably the throat. If the problem is in the hose or head, detach the hose from the head and check for suction at the end of the hose. If there's not suction there, then you've got a clog or a hole. If there is suction there, then you've got a clog in then head.
May 20, 2014 | Vacuums
Bag was not on good, resulted in dust,dirt, dog hair everywhere...have cleaned pretty thoroughly but vacuum does not have any suction. After taking apart did find that the larger wide belt is broke but I...
Greetings from GoVacuum,
There are two things that you should check on this vacuum after running it without a bag inside. The first thing you should check is the filter that is underneath of the vacuum bag. This filter is underneath of a bracket, and the bracket can be removed by pulling straight up on the bracket. The bracket and filter are directly below the vacuum bag inside the vacuum bag housing. If the machine was run without a bag (or the bag fell off) then this filter is most likely going to be extremely clogged. You can simly remove the filter, and run it under hot water until clean. Make sure the filter is 100% completely dry before putting it back in the vacuum and using it. Running the vacuum with a wet filter will destroy your motor.
Now in terms of the belts. Where as the belts don't directly control the suction of the vacuum cleaner, they certainly facilitate the pick up of dirt and debris on the floor. Many people assume that since the vacuum is not picking up from the floor, then the vacuum doesn't have suction. You can test this by pulling out the attachment hose and feeling for suction, is there suction at the end of the hose? If yes, then the reason the vacuum is not picking up on the floor is because of the belts. If you don't have suction at the end of the hose, then you have a clog, some where or a dirty filter.
The belts actually are what spin the brush, and the brush basically sweeps the carpet, and throws the dirt and debris into the suction port, and when the dirt and debris are near the suction port, the suction then takes over and takes it to the bag.
There are two belts on this model, it's best to replace both of these belts at the same time. If you replace just one, then the other belt will wear out quicker. It's always best to replace these two belts in conjunction.
The two belts that are used on this vacuum are:
Hoover Windtunnel V-Belt Part 38528034
Hoover Windtunnel Flat Belt, Hoover Part 38528035
Once you have the belts, and you're ready to replace them, here's a great video that we shot here at Govacuum.com that shows you exactly how to replace these belts, as well as some basic maintenance on your roller brush;
I really hope that my repair solution was helpful to you in fixing your vacuum cleaner. If you have any further questions about this repair, or any repair, feel free to contact me at chris.jones@govacuum.com, or request a clarification here on Fixya.
If you did find this repair solution helpful, please kindly rate this repair helpful by clicking the 4 Thumbs Up Icons in the top right hand corner of this solution.
Thank you very much,
Chris Jones
GoVacuum.com
Mar 19, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
My Hoover U5491900 Anniversary Windtunnel will not pick up very well, there is good suction when I use the attachments, but when I use it on the floor it won't pick up much, what is wrong with it and how...
The reason why it is not picking up well is because the belt is worn or stretched and it can't turn the brush (which picks up debris) against the resistance of the carpet. Here is the belt you need:
Hoover U5491900 Belt
Jan 20, 2010 | Hoover U5491-900 Bagged Upright Vacuum
The windtunnel vacuum has suction but does not pick up the dirt. I'm puzzled as to what might be the problem. Help!
The problem is that the belts are stretched and worn and slip instead of turn the brush when it is put against the resistance of the carpet. You simply need to replace the belts. Here are the (2) belts you need and the manual with instructions:
Hoover self-propelled windtunnel belts
Manual
Jan 02, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover 5470-900 no longer contacts carpet with beater brush
your floor adjustment spring is broken there is a plastic slider and clip if it is broken the height adj will not work you should get a new vacuum because this repair can cost as much as a new vac.also this is a common problem with the hoover brand I would get a sebo or an oreck they have a great warrentty and you will more than likly never buy a other vac.
Jan 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Decreased hose suction with Windtunnel
There are very few things left to check. First verify that the filter is installed properly, in the dirt cup. second check to make sure the dirt cup lid is on and secure. Did you use water on the round dirt cup filter? if you have you will need to replace it. To verify this remove the round filter and re-install the dirt cup on the vac. do not vacuum the carpet, just turn it on to check for proper suction. and then turn it off.
Your problem has nothing to do with it in the upright position. once turned on you will always have suction, either to the floor or when hose is removed from foot for accessories.
Dec 03, 2008 | Hoover U5753-900 WindTunnel Bagless...
Brushes won't spin on carpet
belt is stretched replace the belt and all will be well
Jul 22, 2008 | Hoover U5753-900 WindTunnel Bagless...
Hoover wind tunnel self propelled U6617-960
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=40485&thid=557365
Hoover Windtunnel self propelled U6617-960
Posted by srkelly on Apr 29, 2008
The vacuum has no suction at the floor. I have checked the hose, and no blockage. When I try to use the attachments, still no suction. What could be the problem.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Hoover U6437-900 / U6439-900 Windtunnel upright Vacuum
You definitely have a clod between the tube by the brushroll area and the attachment hose and the best way is to take a wire hanger and make a little hook on the end to see if there is a clog, the clog is closer to the fan area and anything big would clog up the area sideways and
-- you may have to remove the top cover to see if there is a clog and to better get @ it from the top. Another suggestion is to do a belt change whether you have one or 2 belts on the vacuum and to change the belts @ the same time every 4 to 6 months. Also, check you owner’s manual under trouble shooting to see if there is something else, other wise that is what I think is the problem. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Apr 29, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Windtunnel Supreme U5280-900 Upright Vacuum Logo
544 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
