Question about RCA F27648 27" TV
Audio can not get sound out of tv,can get sound when using dvd player.
0 characters
1 Points
Connect this TV with any other sources, ie, to a DVD player. check whether there is sound output with DVD player. If yes, the audio processing circuit of your TVs main board should be troubleshooted. If there is no sound even DVD player, the speaker of your TV is faulty.
Jun 12, 2012 | Sylvania Standard (CRT) Televisions
My tv has no volume but when i hook up the dvd player to the same tv i get
Check if you are using digital audio out cable for making a connection between TV and dvd player,
if yes their is problem with your normal audio output for solving this repair your TV by a good technician
Feb 15, 2011 | Sony Standard (CRT) Televisions
No sound on my DVD. Using S connector or jacks. Swapped DVD player, checked the cable connections, went through the menus on both the player and the TV. Never was a problem before.
if you are connected the S video output of ur dvd to ur tvs s video input , the u should connect another two RCA cable fo audio.S video connection is only for video input. connect the audio out put of ur dvd to the corresponding S video audio input, using a stereo RCA chord.
Dec 21, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
How do i get to the channel to watch a dvd
You will need to connect the video and audio from your DVD to the Input of the TV. So use a RCA cord to connect from the video output /audio output of the DVD player to the AV/Input/video input/audio input of the TV. Now use your remote to select the AV channel and your video and sound will come. Do this carefully . Hope you try. Good day
Aug 13, 2010 | Zenith B27A11Z 27" TV
How do i connect a dvd player to the tv?
Behind DVD player you will have sockets
(red -Audio
white -Audio
yellow- video)
Same set of sockets will be there behind your TV also.
Please connect the Audio video cable correctly accordingly to the colour.
Now your DVD player is coonected to the TV. You can start using your DVD player
Jul 23, 2010 | Disney Lightning McQueen TV
No audio when using VCR/DVD player
the first thing that you need to do is use the video cables and audio cables that are on the back of the unit. This makes sure that you have sound and video.
Dec 22, 2008 | Sanyo DS27510 27" TV
Goodmans Tv wont show dvds
Usually with DVD players, picture & no sound, or sound & no picture is caused by the scart lead not being plugged in properly.
Sound pins are at one end of the connector and audio pins at the other.
If you are using scart make sure that the plugs at both ends are pushed in all the way. The plastic part of the plug should just touch the socket.
If you are using S-Video (Round connector with 4 pins) you also need to connect a twin phono-phono (Red & Black or White) lead to carry the audio, as S-Video only carries video.
Feb 09, 2008 | Goodmans 1475TS 14" TV
Getting sound to come through DVD receiver
is it a dvd/surround sound if so does your tv have audio out or just in if it dont have audio out rcas then you can buy a coax to rca converter like for dvd players but instead of running you dvd player through it to the tv run the coax cable from the tv to the converter where it says ant in then run the from the audio out of the converter to the surround sound they usually run from about 15 - 25 dollars and you can get the at wal-mart k-mart and radioshack and any other big electronic store around your area just make sure it has audio and video out to.... not just audio in
Feb 06, 2008 | RCA F32650 32" TV
Trying to hook up dvd player with sanyo tv. Also hook this up to satellite and surround sound. No picture, just audio.
Well are you ready for this I hope you can under stand if not maybe I can draw a diagram. Starting with your stereo take the component video out and goto component on the back of your tv to component in then the stereo coaxial in to the digatl audio out on the DVD player then DVD player anntena out to TV anntena in then DVD anntena in to reciever anntena out and Sat cable to reciever. also s-video on Dvd componet to s-video on TV DVD player Audio out to Audio in on TV. Set Stereo to TV and DVD player to channal 3 or do auto scan and TV will work on 3 with the reciever and also TV works with Video 2 I hope this works for you good luck
Jan 03, 2008 | Sanyo DS31590 31" TV
Can't get the DVD connected to the TV directly without Cable or Satellite...
what brand is your TV and your DVD? Most TVs have a Audio In(put) and Video In(put) connection at the rear. Similarly, most DVD players have a Video OUT and Audio (L) and Audio (R) outputs at the rear. Now all you need to do take the supplied cable - or if you do not have one, buy a cable from radio shack - should not cost you more than 5$ - and connect the Video Out of the DVD player to the Video IN of the TV and Audio Out of the DVD to the Audio Input of the TV. On the TV, using the remote, select Video Input using the TV/AV button. Play your DVD machine, and enjoy your movies.
Apr 07, 2007 | Durabrand DWT1905 TV
RCA F27648 27" TV Logo
21 people viewed this question
Top RCA Standard (CRT) Televisions Experts
John mullen
Are you a RCA Standard (CRT) Television Expert? Answer questions, earn points and help others
