Question about Husqvarna Forest & Garden No.967012396 345 16" Gas Chain Saw
From day 1 it has been hard to start can't start this morning
I cain't start it
unit is 3 hours used
  • rcrelect Dec 31, 2008
  • 17 Answers
If it's new take it back to dealer,should have come with owners manual>
Posted on Jan 03, 2009
I find it hard to start my l 200 after running several minutes.i could start it in the morning after I on the switch what ,s the problem.
May just be a bad temperature sending unit. Once warmed up, it's supposed to go off cold start, which puts more fuel to the engine. If sending unit is not telling the computer the engine is warm, it will still be putting more fuel into the engine and flooding it, making it hard to start. Check/replace said sending unit and you're good.
Sep 24, 2014 | Cars & Trucks
Hi, I have a 2009 BMW 328i with 57,000km. 1 morning about 2 weeks ago, i went to start the car to go to work, the car started, rmp danced between 1k-2k and stalled! i had to try starting the car about 6, 7...
If you can get a list of the codes It may help the experts to see a common item that affects all the codes. We need to know in what areas the codes were apperaing
Nov 20, 2013 | Cars & Trucks
Hi and welcome to FixYa, I am Kelly
Without your model number here is what most likely has happened:
The automatic defrosting system is not working due to a component failure.
The components of the automatic defrost system are:
1. Defrost control
2. Defrost heater
3. Defrost thermostat.
4. Wiring to inter-connect 1 - 3 above.
What your currently doing is a manual defrost cycle every 3 weeks because ice blocks the air-flow across the evaporator in the freezer compartment so everything starts warming up in the fresh food section first and finally the freezer as the ice block gets larger.
FYI you can unplug it... remove the contents from the freezer...use an external directed into the freezer compartment for just over 2 hours to do the same process your doing in 24 hours. Until the automatic defrost system is repaired you should do a manual defrost at least every 4 days.
Most units are on an automatic defrost cycle of 6 - 8 hours (usually) all the way up to 10.35 hours per cycle. Yours just is not working at all.
Thanks for choosing FixYa,
Aug 15, 2011 | Refrigerators
How do i set timer
How to program Raindrip R673CT
Download R673CT manual at raindrip
Other models
Raindrip drip water guide
Install 2 AAA batteries to power display
Set current time:
Press TIME and hour digit flashes > Use up-down arrows to set 24 hour clock
Press SET to confirm hour
Use up-down arrows to set minute
Press SET to confirm minute
Use up-down arrows to set day of week
Press SET to confirm day
Program review
Timer can set 16 watering schedules
When programming, look at display:
Notice: PROG for programming mode, #1, start time, run time, SU MO WE for days
Press PROG and display appear just like image above
Use arrows to select 1, 2, 3, 4 through 16 different watering schedules
Start time hour will flash
Once hour flashes, use arrows to select hour
Minutes will flash
Use arrows to select minute
Press SET to confirm minutes
Run time hours will flash
Use arrows to set run time hours duration (0 to 9 hours)
Run time minutes will flash
Use arrows to set run time minutes
Press Set to confirm
Now #2 shows on display this is about which days the timer will water
Decide 1) every other day, 2) every third day, or 3) watering at will
1) To water every other day:
While 2nd is flashing, press SET and SU TU WE FR will appear in display
2) To water every third day:
While 2nd is flashing, press down-arrow
3rd will start flashing and TU WE SA will display
3) To water at will:
While 2nd is flashing, press down-arrow twice
SU will flash
Press down-arrow to go to MO TU WE etc
Press SET when day you want appear on display
To set another watering program
Scroll back up to "programming" on this page
Press arrows to select programming 1 thru 16
Repeat programming sequence
After programming is set, press clock button and current time will show
Oct 07, 2010 | Raindrip R673CT Digital Water Timer
Freezer not cold
Could be alot of things. First thing: fully defrost the unit. It might be ice. One way is to shut it for about 2 days and let the rest of the ice melt. Clean the condenser coils. Check door gaskets. Restart the unit and check for refrigerant amount: Find the compressor from the back, clean off the largest pipe. Start unit ( must be off for at least half an hour). It will frost up. Does the frost stop after 5 minutes? If icy,dry or wet, you are okay.
Make sure your doors seal properly.
After that, might be the defrost timer or the control panel. Hard to tell.
Dec 22, 2007 | Jenn-Air JCD2389G Side by Side...
Satellite reception
I have being having similar problem as every one else. There is nothing wrong with your Nuvi. Garmin (the company is the problem) they are trying to make you buy a new map--Not Exactly Cheap--Do Hard Reset and solve all the problems.
1) Place a finger (Any finger, middle finger worked for me!) at the left lower corner and turn on the Nuvi unit a message appear saying "Do you really want to start up in maintenance mode?" tap Yes
2) At the Maintenace screen tap clear user data (this will restore to factory condition) and follow the instruction on adjusting your prefered setings.
3) turn it off and Repeat step 1, this time when you get to maintance screen tap on "Clear waypoints" and follow the instruction. Let it sit for about an hour then voila.
Nov 05, 2007 | Garmin nuvi 350 GPS Receiver
HX2410 won't start , have to reset every morning
To my experience, tehre's some evidence this occurs when th device is sort of locked up for too many alarms/notifications being prompted while the device is shut off. This may cause a shortage of memory, for which soft resetting is the only way out. Anyway, as long as you don't drain your battery out, it should NOT cause a hard reset (which would imply losing data and third-party software). Bye
Sep 08, 2005 | HP iPAQ hx2410 Pocket PC
Husqvarna Forest & Garden No.967012396 345 16" Gas Chain Saw Logo
89 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
