Question about Kenmore 46462 Front Load Washer
Water pouring out of detergent dispenser drawer
On my Kenmore He2 front load washer 46462
    Problem Solver:
  • 14 Answers
There is a rubber hose that connects dispenser housing to outer tub of washer. Disconnect hose at outer tub and fish out article of clothing that has wedged itself in there cuasing water to back up and pour out of dispenser. In the future use a linen bag for small articles of clothing such as underwear and socks.
Posted on Jan 02, 2009
Water is pouring out of my dispenser drawer
I have read other folks say that this has happened to them when a sock or wash cloth gets stuck behind the rubber seal of the door. There is a pipe that drains the water from your detergent tray and it may be clogged with a sock. Try feeling around behind the rubber seal in proximity to the detergent tray and see if there is a piece of clothing stuck in the pipe that drains the detergent tray. Also remove the tray and check the pipe from that end too.
May 04, 2010 | Kenmore HE2 Plus Front Load Washer
Water is pouring out of the detergent dispensing drawer from my 1 year old Samsung clothes washer model WF328AAW. When I opened the drawer, it was full of water. Something must be plugged. Is there...
Pull the drawer out you will find detergent has built up in side the dispenser probably from from way too much detergent, modern front loaders work best with a small amount of detergent and liquid detergent normally will wash better.
Apr 17, 2010 | Samsung WF203ANW Front Load Washer
Water runs from out the detergent dispenser on my front loader
Try pulling the drawer out again and look in the hole. Look on the bottom for detergent or softener piled up and allowing the water to come out the door or anything clogging the tube in the back of the hole. Look on the top, there are a bunch of little holes, make sure none of these are clogged, clean with a toothbrush and sewing pin if clogged. Take the drawer completely apart and clean thoroughly, check for any cracks. If nothing is found here Take the lid off with the 3 screws in the back and push the lid toward the back of washer and lift off. Run the washer and check for the leaks with a flashlight. DO NOT TOUCH ANYTHING ELECTRICAL. As there is a shock hazard with the lid off.
Thank you
Jan 23, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore 11047511701 Front Load clothes washer: Liquid detergent runs out of dispenser and down front of machine immediately as liquid is poured in instead of holding liquid. Dispenser was not overfilled.
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 14, 2009 | Kenmore HE2 Plus Front Load Washer
Bleach and fabric softner despenser liquids not being used.
Feb 25, 2009 | Kenmore HE2 Plus Front Load Washer
Front load washer pouring water from detergent drawer
w would immagine that if you have water pouring out from your dispensor that something has found its way down into the the dispensor hose leading to the tub and is bl;ocking free passage of wwater. you can remove the top off the machine and check the dispensor to tub hose for possible debris/ sock/washcloth. ive even seen the pull tab from the top of the detergnet bottles in there
Feb 23, 2009 | Kenmore 46462 Front Load Washer
Water coming out from detergent dispensor drawer
Is this an HE2 washer? if it is, open door gently tug at bellows top left hand corner you should see a small piece of clothing stuck between tub and dispenser inlet to the tub.
Dec 31, 2008 | Kenmore 46462 Front Load Washer
Front load washer leaks from the detergent drawer in the front
try taking the drawer out and clean it thoroughly, including the underside of the drawer, then clean the inside of the machine where the drawer fits into. Sometimes a build up of dertergent can casue this problem
Dec 28, 2008 | Kenmore 46462 Front Load Washer
He2 leaking from detergent dispensor
Plug off the wall, etc. Remove the rear cover. There is a thin tube coming from the control panel area to the base where the water exits, this should not be blocked, remove from top and blow to check, refit. Next clean out your outlet filter, it could be clogged, refit. This tube controls the water level. Another thing that could be the problem: Try to take the top of the machine off; there are three tubes coming into the dispenser box, these may hv come loose or something. Connect well.
Sep 12, 2007 | Kenmore 46462 Front Load Washer
Kenmore 46462 Front Load Washer Logo
173 people viewed this question
Sal De
fordexpert
Robert Rankin
