Question about Amana ALW480DA Top Load Washer
Need to replace pump/spin belt
Cant get the belt around the pulley on the pump. how is this accessed?
  • 115 Answers
This washer your have to take the 2 1/2" bolts on each side the motor then you will have to take 3 star bit screws out of the bottom of the pump slide the pump off then put it all back together and then after mounting you motor and pump back up put it on the transmission puller
Posted on Dec 31, 2008
MAYTAG MAVT446AWW WILL NOT SPIN
I would check the pump before anything else. The reason is because there is only one belt that actually goes around the motor, transmission, and the pump itself. You can lean the machine backwards and have access to the belt and the pulley to each one of the parts listed. The belt can be rolled off and once that is done each pulley should be able to turn smoothly.
May 30, 2012 | Maytag Washing Machines
My washer is making a grinding noise during spin cycle and it smells like burnt rubbert
The grinding you hear is from the drain pump. I have replaced around 60 this year alone. There is a insert that works its way down around the pulley on the pump and restricts the pump. The burning rubber is from the belt trying to turn the pump but cannot. Here is a link to the part you need. You can gain access to the pump by removing the four screws on the rear bottom left side of the washer. You will need to remove the belt before you remove the pump.
Aug 11, 2011 | Maytag Admiral AAV7000A
I have a GE washer model wdss412oaww how do I tighten the belt
Greetings,
this washer has a belt that more or less tightens itself...if its cracked or split the washer usually makes noise as the belt flops around and will not wash or spin properly. The motor assembly must be removed and pump taken off to replace belt. The front must be removed to gain access to motor pump assembly. There is four nuts that hold motor to frame..Remove the belt off the pulley before you do anything to make it easier on you...take the four nuts off and remove motor/pump and sit with pump up...play close attention how the belt goes through the pump and around the post of the pump to motor......It is possible, that you may need to replace the pump...if it gives you any problems coming off...it may be need to be replaced as well...I hope this helps and if so,,,please rate my help.....Bruce Denton
Jan 20, 2011 | Washing Machines
Need to replace the main belt on the bottom of the washer. The belt goes around the drive pulley directly below the electric motor which is accessible from the front bottom access panel. The belt goes...
Unplug the motor wiring, remove the bolts holding the motor bracket (4 I think) remove the hoses from the pump and lift the motor and pump out. Remove the 3 screws on the pump and separate from the motor. Put the belt on the pulley and replace the pump. Slide the motor and pump back in with the belt attached, but don't put the 4 bolts on until you put the belt over the tub pulley. Then put them in and plug the wiring back onto the motor. That should do it!
Nov 20, 2010 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
No spin agitate or drain just motor noise
The noise coming from the motor means it is running but cannot drive the drive pulley and the pump pulley because the drive belt is either broken or has slipped off. The drive pulley and the pump are driven by a single belt. Replace the drive belt if broken or loose and has slipped off. Disconnect power then drain the water manually by placing the end of the drain hose into a bucket or a shallow basin. Position the bucket/basin as low as possible to extract as much water from the tub. Once drained, lay the machine on its back to access the belt under the machine. When replacing the belt, wrap it on the motor and the pump pulleys then on the drive pulley. Turn the drive pulley in such a way that the belt wraps around the motor pulley, pump pulley, and the drive pulley.
Nov 11, 2010 | Maytag Atlantis MAV6000 Top Load Washer
I have a Frigidaire GLTF1670A washer. When the washer goes into the spin cycle, I have noticed a progressively louder belt slipping sound. The washer is 7 years old. Do I need to replace the belt, or is...
Disconnect the washer from the electrical supply then remove the screws shown holding the rear access panel to the washer’s rear panel and lift the access panel off.
Cushion the bottom of the cabinet opening as shown to avoid hurting yourself with the sharp edge.
Plug the washer in then start a loaded spin cycle to check for belt slippage and the motor operation itself.
Replace the belt if loose or slipping. Remove the belt by turning the tub drive pulley and rolling the belt off the pulley.
Install the new belt in reverse order by wrapping it around the motor pulley and on one side of the tub drive pulley then turn the pulley to the other side in such a way that the belt wraps completely around the pulley. Secure the rear access panel back into position to complete the procedure.
Note: This advice is intended solely for the asker dolanbox as per live chat discussion.
Aug 30, 2010 | Frigidaire GLTF1670A Front Load Washer
My belt slipped and i cant get it back on. do i need to loosen something or what?also the bottom right pulley is eating into the bracket what causes that?
hi this sounds like the actual bearings have gone in the pulley, hence the belt coming off, you will have to replace that pulley or what ever it is that the pulley is attached to ie power steering pump, water pump, etc, to put the belt back on after the repair has been done, you will need to loosen off one of the tensioner pulleys to put it back on...hope this helps
Apr 06, 2010 | 1988 Chevrolet C1500
I need the drive belt configuration for a 1988 Jeep Cherokee.
To replace belt, first loosen the pivot and slide bolt on the steering pump, then use the jack bolt below the pump to move it. Belt goes (ccw) around outside of ps pump, under idler pulley, over a/c compressorover alternator over fan pulley, over crank pulley over water pump and back to the ps pump. best bottom (grooved area) should match with any pulley with grooves, back of belt should contact smooth pulleys. 9example...grooved part contacts ps pulley, smooth back goes under idler pulley) When finished the water pump should spin ccw (I've seen them put on incorrectly so it turns backwards) Tighten jack bolt till the long strech of belt is giving about 1" deflection, then lock pivot and slide bolts down.
Nov 28, 2009 | 1988 Jeep Cherokee
There is a rubber burning smell during the spin cycle on my stacking washer/dryer applicance. It is about 10 years old. How do I open the applicance and check the belts during the spin cycle?
This is a drive blet problem
To replace the drive belt, you will need to open the access panel or in some cases tip the washer onto its side to expose the belt on the bottom. Start by removing the back cover, and look for a belt. If you do not see a belt (or a place for a belt - the belt itself may have broken and is hidden from view) and you can see the floor then your washer is a direct drive model that does not use a belt. If you cannot see the floor because there is a steel floor in the washer, locate the motor and determine if it extends through the bottom plate. If so, then the belt is accessed from beneath the washer.
If you have to tip the washer over, place a large piece of cardboard on the floor to protect the floor and the washer's finish. Because a washer is pretty heavy, you will need an able-bodied assistant to safely tip the washer onto its side. Also, there will be some water remaining in the washer, so have sponges and towels ready to clean up any spill.
To remove the old belt unscrew the clamps securing the pump coupling ( a leathery or rubber flexible part that connects the motor to the water pump). Remove the pump coupling to slip the old belt out. Some models instead require you to loosen the motor mounting bolts and shift it inward to relieve tension on the belt. Remove the old belt.
Place the new belt over the transmission pulley first then place it over the motor pulley. If it is too tight, place the belt over the motor pulley's nearest edge and then slowly turn the motor pulley to pull the belt around and into the pulley. Replace the pump coupling or tighten the motor mounting bolts. The belt should deflect no more than one half inch when you press on the longest straight run.
Replace the cover and test the washer for proper operation
Sep 29, 2009 | Kenmore Washing Machines
I am having trouble replacing my belt on my Kenmore 70 series
i've got them down to 10 minutes, but here goes. remove the bolts going into pump, but do not remove pump . remove the transmission bolt with the spacer and this is where you push the belt through and around pulleys.. this is a little more difficult. you will need to take off the yoke spring and move the transmission pulley around until the spin control magnet catches for spin. it will begin to take pressure off of clutch. you will need a long screwdriver or something like it to apply pressure down on the clutch plate this is to allow to to slip the belt thru the bar the spring came off of and under it.. you can then pull the belts around all pulleys and put everthing back in its place and your done...
Jul 18, 2009 | Kenmore Washing Machines
Amana ALW480DA Top Load Washer Logo
60 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
