Question about Microwave Ovens
Panasonic Microwave NN-T785SF Door switches are broken.
The two switches on the side of the door that hold the door closed are loose now and don't hold the door closed.
  • Anonymous Mar 14, 2014
    Microwave switches on without closing the door
  • Microwave Ovens Master
  • 9,086 Answers
Oddly enough, the switch holder is called a "door hook". For this model, it is part # F3020-1200 in case that is bad.
The hook assembly that protrudes from the door is called the "door key".
If you gently push up on the door key there should be spring tension. If it just flop right up, the spring is off inside.
Normally the problem is not the spring, but a broken spring mounting tab on the door key or the inner door panel.
If it's the door panel,it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door key is easy to replace or repair if that's the issue.
Normally you have to separate the door panels (as shown in the attached photo)and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
The best place to order parts for this brand is Tritronics. Or you can call them toll-free at 866-779-5835. Their Web site will be down until Jan. 2nd.
Posted on Jan 01, 2009
Door release buton does not open the door
You can disassemble the microwave oven and check out the release mechanism. You'll find several hooks that hold the door closed and a linkage mechanism to the door opening button. There may be a broken piece of plastic or maybe just a loose or missing screw that holds linkage together. In the case of a broken plastic part, you can fix it with a 2-part epoxy adhesive, but you'll need to permanently splint across the break with a piece of metal or strong plastic that you've scavenged from somewhere. Before epoxying the splint in place, rough up all plastic surfaces where you want the epoxy to stick well.
Good luck.
Mar 16, 2015 | Panasonic Microwave Ovens
1200 watt panasonic, power on but will not perform
Hello :
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
best regards .
please don't forget to rate !
Apr 04, 2010 | Panasonic NN-S262SF Microwave Oven
I have a Panasonic Inverter Model NN-T664.It acts
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you only need a switch, you can order a universal type here for $5 postpaid.
Oct 11, 2009 | Panasonic Microwave Ovens
Microwave comes on when I open the door.
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
The best place to order parts for this brand is Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Jan 03, 2009 | Panasonic NN-SN657SMicrowave Oven
Microwave oven runs when door is open, and does not always run.
Dec 27, 2008 | Panasonic NN-C994S Convection/Microwave...
Microwave not cooking
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
The best place to order parts is Tritronics. You can also call them at 866-779-5835
Nov 21, 2008 | Panasonic NN-T990SA Microwave Oven
T993 - Positive Lock Switch ?
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
You can find an authorized Panasonic servicer here. You can order Panasonic parts here.
Sep 27, 2008 | Panasonic NN-T993SF Microwave Oven
I have a Panasonic NN-S961 microwave. It turns on when I open the door. When the door is closed it turns off. Otherwise it opperates normally.
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 29, 2008 | Panasonic Microwave Ovens
Nn t993sf
Sounds like the door switches are out of adjustment or broken.
I would take it to a shop for repair. Microwaves are almost always repaired affordably unless it is really old.
Hope ya fix it!
Feb 07, 2008 | Panasonic NN-T993SF Microwave Oven
Microwave Ovens Logo
437 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
