Lexmark X2600 InkJet Printer Logo
Posted on Oct 14, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cant connect wierless
Dosnt show on add printers
Anonymous
Level 3:
  • Lexmark Master 6,487 Answers
  • Posted on Oct 15, 2012
Anonymous
Lexmark Master
Level 3:
Answers
6487
Questions
6
Helped
1556380
Points
18452
For wireless printer like these you need to make sure that it is connected and configured already to your existing wireless network. If not yet better connect the printer to your computer via USB and then run the setup disc and follow the setup wizard to setup the wireless.
Need to connect my nvg510 brodband
Does your bluray player have an internal wireless system, or does it require an add-on? Need to know model of bluray player
1helpful
Wierless router not responding
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
I cant open the b luetooth on my lenovo laptop
1.please make sure bluetooth is turned on use fn+(search for bluetooth symbol ie.B)
2.if windows 8/8.1
  • press windows key and type add devices and printer
  • click on the result
  • add device
  • it will show your phone or device to connect
  • connect
  • type pass code
enjoy
if win7
take setting and search like above add device enjoy
Printer dosnt connect thru netgear router
Well if there is no light on port 3 it means,its not connected physically to printer(or could be that port 3 is faulty can try other port number to rectifie that )
Please check and let me know for further support
Happy to help
Thanks for using Fixya
CAN I HOOK MY PRINTER UP TO MY WIERLESS ROUTER AND MAKE THE PRINTER WIERLESS OR DO I NEED A SPECIAL PRINTER
Generic Answer
Depends ... Is yours a network ready printer (has a ethernet port and firmware to allow you to set a I.P.?)
Hook it to your router.
You may be interested in network management from Cisco ... Network Magic. Download evaluation copy free. Google it ... you can read the deal they offer there so I will not repeat it here.
I use the paid pro version and I love it. They do not provide Network Printer support per-ce but, your printer will show up on the network map and it will give you assistance is some areas.
I hope you find this generic answer helpful.
a
51helpful
6answers
R230 Epson Printer
I cant print coz of my printer (R230 Epson Printer) blinking 2 red light. Printer dosnt ready. It say-Service required. how can I release this problem. Plz tell me.
How to connect to a wierless network ?
hello you could try this turn the power off to the modem and take the ethernet lead out. at the back of the modem is a reset button press and hold for 30 seconds after that reconnect the ethernet lead and power and re set up again good luck
shaun
I just set up wireless router and cant get my ps 3 to connect
Ps3 does not support wierless N, use wireless G works awsome for me.
Hi i cant get my printer installed on my pc. i have a HP photosmart c4180 but i dont have a disk so when it asked which make etc the c4180 dosnt show up on the list.
To add the printer to your PC, please click on the below link or copy the URL and paste it in your web browser.. And follow the steps..
For XP - http://kb.iu.edu/data/aksl.html
For Vista - http://www.lockergnome.com/windows/2007/01/25/add-a-printer-in-vista/
To download the driver, Click on the below link and download the drivers that supports your operating system..
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1141647&lc=en&cc=in&dlc=en&submit.y=3&submit.x=4&lang=en&cc=in
Thank you....
How do i change channel on router? when i play on ps3 and wii online, the phone will ring and cut off my playing.
you cant
you need a multi chanel router
i reccomend wierless g
even if you have no wierless
about$35-50
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
