Question about Kenmore 46462 Front Load Washer
Water coming out from detergent dispensor drawer
From my kenmore front load washer 46462
  • Anonymous Jan 06, 2009
    I have the same washing machine and this started to happen to me.
    Problem Solver:
  • 17 Answers
Is this an HE2 washer? if it is, open door gently tug at bellows top left hand corner you should see a small piece of clothing stuck between tub and dispenser inlet to the tub.
Posted on Mar 03, 2009
  • 188 Answers
Remove the dispenser, pour water into the opening and make sure water can get into the machine freely. Inspect the opening for soap build up.
If water goes down slowly, open the washer door and feel around the bellow for anything blocking the water inlet port into the washer (socks can sometimes get wedged up there and cause a blockage).
If it all checks out ok, make sure the machine is properly leveled and not leaning forward.
Oh My God, that is exactly what it was!!!!! A sock, a mens sock stuck up in there, thanks so much!!!!!
Posted on Jul 22, 2009
Thank you so much bacoo for the advice. The HE2 washer had sucked up a sock right where you said to check. Took some time getting sock out of such small area but did it. Thanks for saving us much money.
Posted on Jun 19, 2009
Kenmore HE 4t Elite Front Loader Washing Machine
Inside the dispenser drawer, at the bottom there is a tab that you can push down to remove the dispenser drawer. Remove the drawer and check if the dispenser holes are clogged, this is a common cause.
Mar 22, 2008 | Kenmore Elite 45986 Front Load Washer
Water runs from out the detergent dispenser on my front loader
Try pulling the drawer out again and look in the hole. Look on the bottom for detergent or softener piled up and allowing the water to come out the door or anything clogging the tube in the back of the hole. Look on the top, there are a bunch of little holes, make sure none of these are clogged, clean with a toothbrush and sewing pin if clogged. Take the drawer completely apart and clean thoroughly, check for any cracks. If nothing is found here Take the lid off with the 3 screws in the back and push the lid toward the back of washer and lift off. Run the washer and check for the leaks with a flashlight. DO NOT TOUCH ANYTHING ELECTRICAL. As there is a shock hazard with the lid off.
Thank you
Jan 23, 2010 | Kenmore HE2 Plus Front Load Washer
Door not locking on front load washer
No reset, sounds like a bad door lock switch. The unit is under warranty, call for service.
Mar 30, 2009 | Kenmore 46462 Front Load Washer
Front load washer pouring water from detergent drawer
w would immagine that if you have water pouring out from your dispensor that something has found its way down into the the dispensor hose leading to the tub and is bl;ocking free passage of wwater. you can remove the top off the machine and check the dispensor to tub hose for possible debris/ sock/washcloth. ive even seen the pull tab from the top of the detergnet bottles in there
Feb 23, 2009 | Kenmore 46462 Front Load Washer
The indicator lights that surrond the dial are flashing on my Kenmore 110.46462501 front loading washer.
Unplug and wait 40 minutes to reset the ECU and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2009 | Kenmore 46462 Front Load Washer
Water pouring out of detergent dispenser drawer
There is a rubber hose that connects dispenser housing to outer tub of washer. Disconnect hose at outer tub and fish out article of clothing that has wedged itself in there cuasing water to back up and pour out of dispenser. In the future use a linen bag for small articles of clothing such as underwear and socks.
Dec 31, 2008 | Kenmore 46462 Front Load Washer
Kenmore 46462 Front Load Washer Logo
1,103 people viewed this question
Sal De
fordexpert
Robert Rankin
