The graphics aren't the best, pretty simple nothing fancy but the videos look pretty good. The deck has a lot of features and has surprised me so far. It has a clock adjustment but it doesn't display a clock in any screen. I believe it is a deck that is worth the money, even the three extended warranty only cost me 28 bucks. I haven't had it that long and I read in previous reviews that the longer you have it is when you start having problems, I hope not but if so I will just take it back. I would recommend it to anyone that is looking for a in dash TV but doesn't want to spend a lot.
SOURCE: replacement screen for xo vision 1742 deck
Model LCD 7'' :Innolux AT070TN07 + Touch panel (unknow)
SOURCE: How do you get the clock to display on XO vision
heres the manual to download, it should help you.
http://www.retrevo.com/support/XOVision-XOD1742BT-Car-Videos-manual/id/13483bh928/t/2/
SOURCE: XO Vision XOD1740BT in dash dvd player bypass code
I solved it By connecting the pink wire to a constant ground this acts as a bypass so the unit plays anytime.
SOURCE: help me with back up camera for xo vision xod1740bt
I am just giving a suggestion. I too need to know how to wire this. From what you posted it sounds like you hooked the wire to a constant +12v that is always on. Forgive me if I am wrong. Anyway, Did you connect this wire to rear reverse light power. I think from what you say it is supposed to be connected to the positive side of that light. If this solves your problem can you PLEASE let me know the full details of everything else you hooked up on the circuit to make the backup work. For instance what is the label of the orange wire. TIA.
SOURCE: xo vision dvd player
hi there
it shouldn't be to hard to install this but it does require cutting a hole in your interior part of roof........a install like this could take anywhere from 30 mins - 1hr for a installer to put it in. to do it yourself it could take 1-3hrs to complete (note for your first time doing this take your time and follow the install manual that will be provided)
