Question about Jenn-Air 30 in. CVG4280 Gas Cooktop
Igniters not working
Model CVG4280 fan has power but igniters not working any ideas
  • 311 Answers
Ignitors run from a spark moudel thru switches at the kobs then to the will need a volt meter and wiring diagram
Posted on Dec 31, 2008
We had a power outage for several days. Now that power is back on, the electric igniter will not work. We have to light the burners manually. There is no "clicking sound" indicating the...
See where the range is plugged in. Check to see if there is power there. If so, the igniter must be replaced. This is not a difficult repair. I would guess there is a power problem, blown circuit breaker, open GFCI outlet or the plug is out.
Sep 01, 2011 | Jenn-Air 30 in. CCG2423 Gas Cooktop
The right side back burner will not light. There is gas, I can smell it but the spark will not start. BUT, the spark will initiate and light the front right burner. What is going on? Its the same...
Can have below issue.
(1) Electric current is not reaching the ignitor. (wire is broken or have a leak)
(2) Having problem with ignitor. (need to replace the ignitor)
Feb 03, 2011 | Jenn-Air 30 in. CVG4280 Gas Cooktop
Romvoing the top of my Whirlpool Cooktop
well usually you have to remove the knobs. thentake all of the caps off of the burners. sometimes there are scres that hold the burner caps on. make sure you turn the power off. Then after you have done this the glass should come right off. If not there may be screws under the cooktop. Do these first steps and let me know how it goes.
Jan 18, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Igniter keeps firing
The problem resolved on its own. I'm guessing some moisture from my cleaning was the culprit...when the moisture dried the igniter stopped sparking.
Jun 01, 2008 | Jenn-Air 30 in. CVG4280 Gas Cooktop
Jenn-Air 30in. Exaust problem
liquid spill and alarm won't go off.
Mar 21, 2008 | Jenn-Air 30 in. CVG4280 Gas Cooktop
Exhaust fan not starting
Bearings are worn. You should be able to replace with a standard utility fan. You can find them at your local big box hardware store or order online here.
Jan 27, 2008 | Jenn-Air 30 in. CVG4280 Gas Cooktop
Exhaust fan comes on when burner turned on
The left side is set for your grill. There is apparently a switch under the left side top / front of the cooktop. The aeration tray has a prong on one end that fits into a hole in the front end of the burner basin and activates the switch which stops the fan from coming on when using the burners and allows the fan to run when using the grill. Try switching sides with the aeration trays as one might make better contact than the other.
Dec 01, 2007 | Jenn-Air 30 in. CVG4280 Gas Cooktop
Ventilation system on Jenn Air CVG4280
My Jenn-Air had the same problem. When you install the drip pan for the burner module, there is a "finger" on the pan that is inserted into a hole in the front of the stove. If you look into that hole, you will see a lever switch. The finger on the drip pan on the burner module is supposed to push that lever switch down and turn the fan off, but over time the lever gets pushed down further and ultimately it does not get activated when the drip pan is installed.
You can either replace the lever switch, or you can try to pull it back into place and tighten the two small screws that hold it in place. Actually, I chose a third option and attached a small, flat spring to the finger on the drip pan.
Oct 17, 2007 | Jenn-Air 30 in. CVG4280 Gas Cooktop
Jenn-air downdraft fan not working
there are 4 wires for that red white black and green sure you didnt miss a wire
Apr 15, 2007 | Jenn-Air JED8430 Electric Cooktop
Cooktops Logo
198 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
