Question about Dryers
Unable to take drum out to inspect issue
Currently the drum rotates and heats with really loud noise that begs ya to turn off the appliance. I am struggling to get the drum out. I have unscrewed the lint filter, taken off the top screws that keep the front door near the drum. I am unable to get down to the bottom screws or hinge. Whatever is keeping the front bottom part of the unit near the drum is just beyond my reach. I'm guessing the belt needs replacing on the approximately 4 year old unit and possibly some other unit. I did notice that the drum shows some rubbing on one section of the outer portion of the drum.
    Sergeant:
  • 311 Answers
Lewis your almost there.the noise is a roller/wheel .unplug unit pop the top remove the frount panels.this will expose the drum.remove the belt and then you will have exposed all the moving parts inspect clean and replace as needed.you can do it yes we can
Posted on Dec 31, 2008
Westinghouse LD 605E Sensor Dryer It makes a loud banging noise when turning. Drum seems to be loose. Any ideas?
According to your description listed your rollers to the drum have failed. Your rollers support the drum and weight of clothes during rotation. They are not difficult to replace if your mechanically inclined. The model number of the unit seems to be incorrect, I am unable to direct you with parts or directions without more information.
Good Luck
Jul 15, 2011 | Dryers
Hi, my Bosch maxx 900 front loader washer was in the process of doing a load when a really loud bang happened..now it won't spin..makes all the right noises, but barrel won't move. Took off back panel and...
If you rotate the pulley on the back of the drum does it rotate the drum? i have seen these snap the back of the drum off. also they can have issues with the controller board for the motors which would require a technician to determine.
Oct 24, 2010 | Bosch Washing Machines
Kenmore electric dryer making loud noise when running
It sounds like the belt that goes around the drum. I have a similar Kenmore, and I get that same rotational thumping noise. The belt is probably about to break or come apart. If you take it off and run it trough your hands, I think that you'll find either belt separation, or a bad spot missing a chunk.
Fortunately the belt is a cheap item. I've kept my Kenmore dryer running over 20 years now.
Mar 18, 2017 | Kenmore Dryers
Noise when the drum turns.
Hello, I have the same issue with a machine now 5.5 years old. At lower drum rotating speeds, a loud clicking (almost stripping sound) is heard. I have only inspected from the lower front cover and found nothing. Will also look in the back for clues...
Dec 30, 2009 | Whirlpool Washing Machines
Very loud metal on metal screeching noise maytag model LDE8414ACE
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Loud metal-metal "screeching" sounds will eminate from the front bearing glides, (click on link below), for a picture of the glides. Link provided by www.repairclinic.com, they provide repair parts, disassembly procedures and diagrams.
You may also want to inspect for foreign objects in the front and rear drum seals and in the blower.
Drum rollers may sometimes cause loud noises also.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-LDE8414ACE-%3d%3di1309&PartID=1309
http://www.repairclinic.com/SSPartDetail.aspx?s=t-LDE8414ACE-%3d%3di1245880&PartID=1245880
http://www.repairclinic.com/SSPartDetail.aspx?s=t-LDE8414ACE-%3d%3di400518&PartID=400518
Jul 16, 2009 | Maytag 7.0 Cu. Ft. Electric Dryer
Kenmore 80 Series loud rattling noise
Its called a Drum Support. Purchase at any appliance parts supply store or online from Sears or Whirlpool.
Part# 3397588 or 349241T (Pk of 2)
Jun 08, 2009 | Kenmore 63942 Dryer
Loud squealing noise from Drum belt looks fine other solutions
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 06, 2009 | GE Dryers
Pounding noise after wash and final spin
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
    if this helps please give a fix ya vote
  • Jul 14, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    Loud Thump each time the Drum Rotates
    You have a problem with your dryer drum.  The seam weld has cracked and the drum needs to be replaced.  You will need to call a qualified LG technician to resolve this issue.
    Apr 15, 2008 | LG DLE2532W Electric Dryer
    Hotpoint WMA42 - Noise!!
    appliance sounds like it has bearing failure.common on this machine.advise looking for a new machine.sorry
    Dec 30, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
    Dryers Logo
    83 people viewed this question
    Top Dryers Experts
