Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
HE3t f20 error
Hi, a brand new machine showing f20 error, wet clothes in machine and door is locked. Any help would be greatly appreciated!!
  • Anonymous Mar 24, 2014
    have a f 20 error need to reset machine
Solution #2 is possibly correct, although in the repair manual (green papers found on inside of machine housing) this is not identified by an F20 code. I think the Sears people might have this one wrong. Try unplugging for a few minutes, then running the diagnostic check.
Posted on Jul 05, 2009
AzRunner gave the direction at where to look (plugged inlet line). Sure enough, found the hot water line full of scale from the on-demand water heater. It's been descaling ever since getting the water softer working and is causing problems at every screen. But that's another story.
Posted on Mar 17, 2008
This is a high efficiency machine, so the question is: are you using the high efficiency detergent? The code f20 is a drain problem, so the regular detergent will sud more and create a draining issue...I have an HE3t and had the same issue, so I hope this helps....Ryan
Posted on Sep 04, 2007
Washing machinge will not start when start buttin is depressed (for several seconds)
Posted on Aug 23, 2007
We had the same problem with a new machine. We washed one load successfully and the second time we got the F20 code. Sears came out and determined it was a bad valve. They had to then schedule another service call to fix it.
The new part was shipped to our house. The repairman showed me the old valve with some black debris on it, saying that our lines were dirty and that contributed to the problem, but its hard to understand how one use of the machine would clog a good valve. Anyway, with the new valve the machine works fine.
Posted on Oct 30, 2007
F20 error
If you remove the bottom panel, there is a drain plug and that would allow it to be opened. There is lots of water there though
Jan 05, 2014 | Whirlpool duet Washing Machines
Kenmore elite he3t washer door will not open, always showing as f22 error code
it is your safety latch on your door. On the front load washer it will lock the door and if there is a problem with the latch it will keep it closed to prevent injury. If you have cloths in there try unplugging for about fifteen minutes or so and then plug it back in.
May 07, 2011 | Washing Machines
He3t washer door is locked with clothes inside. Manual release doesn't work; and disconnecting DP21 doesn't work.
Possibly an item of clothing between the door and frame. Unplug the washer.
Press gently against the door latch while you pull on the emergency cord.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 27, 2010 | Kenmore HE3T Washer
Washer will not drain or stat new cycle, no error message
What is the make, mode # of your washer? Do you have dial or, a keyboardl controls
Apr 26, 2009 | Whirlpool Washing Machines
I have a Kenmore Elite Quiet Pak 4 HE3T Washer. The door is locked with clothes in it. The displays is saying F dL. What has happened and how can we open the door.
FdL Door lock error A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Possible Causes / Procedure
• Door lock mechanism is broken or removed from door.
• Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Apr 12, 2009 | Washing Machines
F20 error code no water coming into kenmore he3t washer
The following provided by fixya has the solution to error F20.
Click here for detailing on F20 Error
Good luck and please do rate my answer.
Jan 17, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
My HE3 washer, about 4 yrs old is locked , showed error code 6
Here are the steps to unlocking the door manually if clothes are still in the machine.
1.Unplug machine
2.remove bottom panel
3.Reach up along the inside of the front panel and locate the botttom of the door latch assembly
4.Located on the bottom of the door latch assembly is a tear dropped shaped tab
5. Gently pull down on the tab about a 1/4 inch or until a click is heard.
6. You may now open the door.
This code means the control is unable to properly detect motor speed. Due to this the machine shut itself down.
Nov 11, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
ERROR CODE
1.Unplug machine
This code means the door lock mechanism has failed or the central control unit has failed. Replace the door lock mech. first. This should fix the problem. (before replacing anything make sure there is no obstruction around the switch or in the switch.) After the machine has been unplugged it may fix itself. if not replace door lock mech.
Mar 29, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Fault code F20 on kenmore he2t clothes washer
I have a brand new front loader that never fill with water but shows F20. How can I get this machine to wash clothes?
Dec 29, 2007 | Washing Machines
Washing Machines Logo
814 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
