Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
The self cleaning dials are not working on my Kenmore. I dont know model number but stove is old. I accidently burned a plastic lid in the oven and started a slight fire and lots of black smoke. I have to cook tonight for New Years and the oven and the whole house smell like plastic. Is there a trick to the self cleaning? I locked stove, turned left dial to clean and right dial to clean but it did not go on? help
    Sergeant:
  • 311 Answers
Yes you may have to select a start and stop time on the clock.scrape all you can out before cleaning though
Posted on Dec 31, 2008
How do I use the self cleaning option on my Kenmore stove model# 970C623331. Do I remove oven racks?
that model doesn't come up,that could be the serial number,do you know that when the dryer is in self clean it gets up to 1000 degrees,when it gets this hot it can do damage to the electronics in the oven,from what i've seen on other peoples ovens i will never use the self clean again,but to answer your question remove the racks and clean them in the sink or you can soak them in the tub,whatever is easier for you.i get in there with an sos and scrub,if any spills are big on the floor i wet it and let it sit for a minute or two and scrape it out with a putty knife or you can use a spatula,if it's really bad easy off is made safe for most self clean ovens now,don't put tin foil on the oven floor when you cook,it can damage the floor,so watch out for that.kenmore doesn't make anything so you need the model number to see who made the stove,if you open the drawer under the oven door,look on the left or right side of the frame and you'll see a tag with the model and serial numbers,go here,put your model number in and you can look up the manual for your stove.hope this helps you out.
https://www.searspartsdirect.com/model/search.html?q=970C623331
Feb 27, 2018 | Kenmore Ovens
I have a Kenmore oven model # 665.95024100 and used the logi-clean cycle and now the door will not open. This happened before when I used it and I called the repair service to fix it but I cannot remember...
Articles on the internet suggest not using the self cleaning feature of modern ovens, becuase fuses and other parts may easily burn out due to the high temperature.
Suggested methods to open a locked Kenmore oven at the artlcle at the link below:
http://homeguides.sfgate.com/clear-oven-lock-mechanism-kenmore-stove-71754.html
How to Clear the Oven Lock Mechanism on Kenmore Stove
Feb 26, 2018 | Kenmore 40494 / 40495 / 40499 Electric...
Moved into this house. Has no manual on Kenmore glass top stove, on how to use self cleaning oven. Looking for manual or directions on how to use it. Only have model # 790.96011400 and serial # VF50635079
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 13, 2010 | Ovens
Code : E3 -F1-
I have an Inglis electric stove with a self cleaning oven We turned the left dial to "CLEAN" and when turned the right dial to clean, a buzzer went off. Can you give me any advise?
Oct 17, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Self cleanning oven - door is lock and I can not get it to open
if you open the lid on your stove,you will probably be able to reset the
switch manually (the latch).with the lid up its located toward the front
behind the safety latch.(by no means attempt to force,bypass,or disable this
switch)this is a safety feature designed to protect you from the high temps
generated by the cleaning cycle.hope this helps.thanx for using fix-ya
Try this, and let me know if it worked, I am trying to help someone else with the same problem, that stove is Model, 790
Mar 07, 2009 | Kenmore Ovens
I have locked my Kenmore self cleaning stove, now it won't open
Sorry you gave the sereial # for the oven. Need model #. Here is an manual that might work for you. cout and past in address bar.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0309524.pdf
Or you can go to this web sight and look up your oven.
http://www.managemyhome.com/mmh/answers/Answers.action#l4q106688
Good Luck
Dec 18, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore oven door stuck closed
if you open the lid on your stove,you will probably be able to reset the switch manually (the latch).with the lid up its located toward the front behind the safety latch.(by no means attempt to force,bypass,or disable this switch)this is a safety feature designed to protect you from the high temps generated by the cleaning cycle.hope this helps.thanx for using fix-ya
Oct 08, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Old Amana - no manual; can't operate self clean feature
Can you locate the model number on the oven? Also any particular name of the stove? The manufactured year. These should all be available on a stainless steel or aluminum attached plate , probably on the back of the stove or inside the door.
I wouldn't try using the self cleaning feature until we get some advice. it could lock up on you and not UNLOCK. Normally self cleaning takes place at 600 or more degrees .
I'm sure others still have the same stove., I will see what I can find for you.
Aug 21, 2008 | Amana AEW4530DDS Electric Single Oven
Kenmore Convection STove - All Oven elements non-fonctional
is the control electronic wih a dial or the whole manual if you can answer me with the model number i can look it up there will be a serial plate some where on the front of the oven most of the time you open the bottom drawer mod#is a bunch of numbers like 106.48062890 should be able to help more after that
Dec 10, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
149 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
