Question about Whirlpool GD2SHGX Refrigerator
Refrigerator is not defrosting right..whirlpool ref..
The freezer part of the ref. is not defrosting therefore ice is building up in the freezer and water is running down into the refrigerator..
  • snoopy52944 Jan 02, 2009
    got the drain unblocked..it was full of ice..we unpluged the ref. for about 24 hours.. how do we prevent this from happening again...
    Sergeant:
  • 311 Answers
Is it frost or ice.if frost you will need an ohm meter to check continouty on the heaters and term thermostat.term thermo must be cold to check.if ther ok check voltage to the heater system from the defrost timer.if no voltage replace timer.if its ice it could be a blocked defrost drain.unblock clean out
Posted on Dec 31, 2008
  • Thomas Malailua
    Thomas Malailua Jan 02, 2009
    well one thing you can do is take a weed eater string ,tie a nott in one end .push the other end threw the drain hole and pull thru the back area where the defrost drain pan is and flush with water.if their was any blockage this would clean it out.other possiabilties are that your defrost heater warps up away from your defrost drain then not heating it sufisintly causing it to freze up.if so you could replace heater.another thing you could to is make an heat probe.i use about 1/8 '' aluminum rod.hang on evaportor near heater then let it run into defrot drain hole ,being carful not to touch drain for it could melt somthing other than ice.thanks for using fixya,God bless your house,tom
Why does The freezer side stays cold but the refrigerator side gets warm
Your problem is more than likely a defrost issue. There is ice building up in the freezer coils and when it gets blocked with ice the cold air cant blow into the fresh food section. When you shut it off the ice melts and it gets cold again for a few days. remove the freezer back panel and check the defrost heater and defrost thermostat. if they check OK then check the defrost timer. It is best to replace all three components at the same time. This way you will be starting out with new components rather than one failing then the other.
Jul 16, 2014 | Kenmore Side by Side Refrigerator
Whirlpool refrigerator #ER2CHMXPL02 I think I have two separate problems. 1st one is a water leak that fills the bottom bins daily! The freezer does not seem to be defrosting, everything in there looks...
Could be that the freezer is too full with foodstuff and there is no air circulation, therefor, some places in the freezer build ice. The defroster is working and melting the ice that drips to the bottom bins.
I suggest you remove everything from the freezer. unplug the frigde. Let all ice build ups melt. Remove ice from the foodstuff and put back in. Make sure that vents in the freezer and fridge are not blocked.
Oct 18, 2013 | Whirlpool 21.0 cu. ft. Top Freezer...
My fridg and freezer is cold but not could enough the freezer wont keep food frozen. there is no ice build up, I replaced the defrost timer, and I cleaned the fan in the back what else could it be please...
Hello Nicole,
Their are a few things that couldbe causing your refrig.troubles.
1) their is ice build up in the return air vents that is not allowing air to flow correctly
you can see the air vents under the crispers in the ref.floor and can see if they
blocked with ice.
2) the freezer fan is bad and not circulating cold air into and out of the ref.
3) In addation to the defrost timer,perhaps the deforst heater and defrost thermostat are bad and frost is building up in the freezer,Do ya see frost
build up in the freezer??
GENE
Sep 21, 2011 | Amana BCI21V1C Bottom Freezer Refrigerator
Water is leaking in my refrigerator. what can i do to stop this.
aon the amana ref this is probley a defroat problem and ice is building up in the bottom of freezer . this is caused by ice build up and it plugs the drain in the right rear cornor of freezer . . clean the drain / or try a complete defrost and the problem should be over .. mm
Oct 16, 2010 | Amana Refrigerators
My meat is beginning to thaw in the freezer. this is the first time this has happened. any ideas? do i just need to defrost? the refrigerator is working fine, does this matter?
Usually when the ref is working fine the freezer isnt. You just dont know that yet. Check the back wall of the freezer and see if there is an ice build up. If so that means that theres a defrost problem so its either a bi-metal( terminator) heater, defrost timer or board.
Let me know if theres an ice buildup or not.
Aug 18, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Warm fridge cold freezer
Hi,advance thermostat setting, to get colder , it's possible you got defrost problem, is there excessive ice building inside back of freezer? to determine if you have a defrost problem, unplug ref. for about an hour,let it defrost, let all ice melt away, it's better to remove your produce, keep doors open to speed up defrosting, after defrosting and cleaning plug back your ref, and let it work for another hour, and check result, if it's o/k, put back your produce, let me know, during hot summer months, regular use (opening) of ref, could cause excessive ice build-up evap. if after defrosting and cleaning ref. work good for 3 to 4 days, but start doing the same thing, let me know, it means you got a defrost problem. also check your thermostat, but first defrost and clean it, that could just be your problem. good luck.
Aug 13, 2009 | Refrigerators
Ice build up in freezer
Defrost system failure.
Defrost timer, heater, therma disk, any one could be bad.
You could manually defrost and this would get the Ref back to working for a couple of days before it iced up again. Remember there is a lot of ice build up on the cooling coils in the freezer that you can't see so, a little extra time with a hair dryer is needed to do a complete manual defrost.
Jan 21, 2009 | Amana Refrigerators
Whirlpool GD2SHGX Refrigerator Logo
233 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
