Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
The water hose inside of my refrigerator...
The coiled hose inside of my refrigerator has sprung a leak due to the light bulb melting the hose. How can I replace this part without having to spend a lot of cash?
    Sergeant:
  • 311 Answers
Cut off a small pice of the hose and take it to lowes/home depot and get an union to rejoin the two parts.size is problly 5/16
Posted on Dec 31, 2008
Whirlpool refrigerator is leaking cold water from the lower left hand corner.
Behind the refigerator are valves and water hoses going to the water dispensor and the ice maker. Anyone of these hose could have a leak either at the connection or the hose. I would not attempt at repairing this unless you are real familar with this problem or appliance repair man.
Feb 16, 2013 | Refrigerators
My refrigator is leaking water
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now ( Whirlpool makes many of the Kenmore branded refrigerators ) on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
hope this helpout ......
Aug 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The freezer leaks water and the fridge is 43 degrees and full of condensation on the inside
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Hope this works...............
Jul 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Leaking inside
The drain in the back of your freezer is frozen. When the defrost cycle runs, the water has no where to go except through the panel into your refrigerator.
Turn the refrigerator off. Take everything out of the freezer and store it someplace for a few hours. You can either let the freezer thaw on its own or help it out a bit. If you want to speed the process, remove the rear and bottom panels from the inside of the freezer to expose the coils and the bottom pan. Stay away from the coils. Melt/chip away all of the ice in the pan. With a hair dryer, melt the ice in the back of the pan. Soon you will see the drain - concentrate on melting the ice in it. Some hot water and a sponge can help speed the drain clearing process. When the water drains freely, finish drying out the rest of the freezer and reassemble the rear and bottom panels. Turn the refrigerator back on, and you are good to go.
Jan 30, 2010 | Kenmore Refrigerators
Water is leaking under the refrigerator. This is
If everything else on the refrigerator seems fine (freezing and refrigerating are fine), then you probably have a problem with the drain hose under the evaporator coil. On frost free freezers, there is a heater that comes on periodically to melt off all the frost on the evaporator coil, and that defrosted frost (water) goes out a drain hose and collects in a pan at the back of the unit where it can evaporate.
Either the drain is clogged with ice inside the freezer, (in which case you might notice ice building up on the bottom of the freezer, or perhaps water collecting on the bottom of the refrigerator if your freezer is on top) OR there is something wrong with the pan at the back of the refrigerator, like a crack, or it somehow got tilted so that the water pours out. It is located behind the panel on the back.
Or perhaps, and this would really ****, the water line that supplies your ice maker is leaking, if you have one. If you do have one, I would recommend turning the water line to the fridge off before pulling the fridge out.
Sep 14, 2009 | Kenmore Refrigerators
The water filter in my GE Profile Refrigerator leaked a large amount of water until we turned off the water to the refrigerator. We did not see any warnings on the LCD. It seems to me that if the filter...
Hi
The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section (not on all models, but this is the most common way), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 02, 2009 | GE Refrigerators
GE refrigerator leaks water under the vegetable and fruit bins
If the refrigerator is of the frost free type, and most all are today, the unit has a defrost cycle where the compressor is shutdown and a heater comes on to melt the ice buildup on the evaporator coil. This water has to go from a drip pan under the evaporator coil down a rubberized or plastic tube to another pan at the bottom of the fridge where it evaporates. Either this hose is blocked or the opening to the hose is blocked. Find the hose (usually on the back of the unit) and run a long wire with a small piece of cloth attached to the end of the wire to get it flowing again. Your water in the veggies comes from the overflow of the upper pan into the inside of the fridge.
Jun 26, 2009 | Refrigerators
All items in freezer were defrosted when I opened the door this morning. Fridge is semi cold.
Hi
Some leaking water refrigerator helps....
  1. My older style Amana freezer on top refrigerator is leaking inside
  2. My refrigerator is leaking water inside
  3. My refrigerator is leaking water onto the floor
My refrigerator is leaking water inside the fridge:
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 30, 2009 | Kenmore Refrigerators
Water leaking inside the refrigerator
Hi
Please do rate the solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
Apr 17, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Ksrs22f Hole in water dispenser hose
Cut 1/2 inch off either side of the hole,take one of those pieces of hose to a hardware store and get a plastic (better) or a brass compresion fitting to join the hose.
Apr 04, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
103 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
