Question about Kitchen Ranges
Digital screen is showing -F 1- and beeping
When my stove is plugged in we will be using it and all of a sudden the screen shows a dash f space 1 and another dash "-F 1-" and i want to know how to get it not to do that
  • 311 Answers
Dont know the brand but f1 usually means you need a new clock/board.try unpluging for 5 min.then try again.other wise clock
Posted on Dec 31, 2008
What is the EOC and how much does it cost to replace? Can I replace it myself or do I need a professional to replace it?
kenmore stove model #c970635326 serial #nf70205945 is showing f11 on the clock and a constant beeping noise.
when you unplug and plug it back on the clock show 12:00 for a few seconds then the f11 shows again and the continuing beeping noise
how much is an eoc to replace....can i do it myself....
Jan 09, 2011 | Kenmore Ovens
Error Code F7
F7 Function key shorted Replace touch padThis is what the code means. The key could just be stuck. Try pushing it several times to see if it will unstick. before you replace the touchpad.
Mar 11, 2010 | Kitchen Ranges
My admiral designer series stove is showing a F 1
f-1 usuqally meens a stuck key pad.sometimes if you unplug it for a wile it may reset other than that you need to replace the clock/touchpad.
Mar 08, 2010 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Whirlpool Dryer works on 1 cycle
Activate the diagnostic test mode to determine the functionality of the console buttons and the console electronics as a whole.
Diagnostic Mode Activation Procedure
  1. Make sure the machine is plugged and in standby mode. That is, no indicator light is on.
  2. Press the following keypad sequence within five seconds: More Time>Less Time>More Time>Less Time. All of the indicator lights should light up and "88" is displayed.
  3. Turn the cycle selector knob one complete rotation. When the knob points to a cycle, the corresponding indicator light should turn off and the machine should beep. Only a beep is heard when the knob points at the large spaces between the Automatic and Manual cycle groups.
  4. A beep should be heard when a button is pressed and the indicator light corresponding to it should turn off.
Any failure on the above tests indicates a faulty console board. Please let me know the result of the test for further troubleshooting and repair guide.
Jan 22, 2010 | Dryers
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Whirlpool oven
When I had a similar problem, the door wouldn't unlock even after unplugging, waiting 30 minutes, and plugging the oven back in. I finally had to manually unlock the oven by turning the lock latch motor myself.
Here's a good page that describes what the lock latch motor looks like and where it's located. Of course, there is 220V current running around inside there, so please unplug before removing the back access cover and put it back on before plugging the oven back in.
My symptoms:
  • Oven failed to complete auto-clean cycle.
  • Oven started beeping; control panel showed FSE 1
  • About a minute after plugging in, oven started beeping and displaying FSE 1 again
Once I unlocked the door manually and plugged back in, the oven started behaving normally.
Jan 01, 2008 | Whirlpool RF368 Electric Kitchen Range
Vivicam 3750
do you live near salt water the salt in the air will seep into and under protected spaces look a little closer using a magnifying glass
Dec 28, 2007 | Vivitar ViviCam 3750 Digital Camera
Kitchen Ranges Logo
94 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
