Question about Maytag MES5752BAS Stainless Steel Electric Kitchen Range
Digital readout blinks
Maytag free standing oven model MES5752BAS
oven works fine, but the digital read out blinks from bright to dim,,,left to right.
  • 242 Answers
Hello , I can help with this issue , When your display fades or flashes it is the first sign of your control board going out. The control powers your digital screen and they are very common to fail. If you have the model with the controls in the back top of unit against the wall it is basic to replace the board yourself , if you have the controls in the front of the unit it is more advanced to get into but is still possible. [controls meaning screen & burner knobs.]
A good place to order is sears parts. be sure to use your model off the oven its self. Please let meknow if you have anymore questions. Phil
Posted on Dec 31, 2008
On model PLEF398DCH Frigidaire Professional Series electric range, my digital readout for the right side burners works fine. My left side digital readout is inoperative, but the burners work fine. Is there...
Good Afternoon Lee,
I understand that the left hand side digital readout is not working on your Frigidaire range, model# PLEF398DCH. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Once you restore power, you will need to set the clock and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 27, 2014 | Frigidaire Kitchen Ranges
Oven goes to max temp when powered on. shut off with circuit breaker and restsrted, oven goes to max, Control panel not operating correctly
change the oven sensor probe thats mlocated in the upper left corner of the oven chamber and connects to the digital readout control board
Sep 11, 2011 | Maytag MGR5775QD Gas Kitchen Range
Maytag MGS5770ADC Two problems, 1) The temp.
HI
I see you have two different problems, one for the display you would have to change your clock, and because you did not give me a complete model number I can't get you the part number you need (four different colors possible on this model). Second, when an oven ignitor becomes weak it can extend cooking times and cause the same problems you have, also if you oven sensor is defective or has oven cleaner n it can cause temperatures to be erratic. I will and can help you but need a complete model number to get you more information. Located left or right side of storage drawer when its pulled out along the frame rails.
Good luck..
Jul 22, 2011 | Maytag MGS5770 Gas Kitchen Range
I have a code 5ab on the panel my model nuber is MGR5775QDS its a 30 inch free standing gas stove.
Your range is probably in the Sabbath mode. The error code shown on the display is"Sab", not "5ab".
To disable the Sabbath mode push and hold the Clock pad for 3 seconds
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/2348-maytag-oven-weird-error-code-5ab.html#ixzz1GLM0d1gp
Mar 12, 2011 | Maytag MGR5775QDS Dual Fuel (Electric and...
Maytag mer6875baf free standing electric range control panel blinking when it is on. It was sudden onset and now the panel shows no read out whatsoever.
The problem is likely the erc electronic range control died. This is easy to check and replace. Here is link that should help http://appliancehelponline.com/ovenerc.html you can also enter your model # for diagrams and illustrations.
Jul 16, 2010 | Maytag Kitchen Ranges
Can not work automatic clean cycle on Maytag range
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
May 05, 2010 | Maytag MER5775Q Electric Kitchen Range
I have a Maytag slide-in range and the touch pad to the oven went dark and doesn't work. The cooktop works! It went out while cooking and we had to turn the breaker off to turn the oven off. What's wrong?
your control board is defective and needs replacement,you can do this by removing the rear cover behind the control board and removing the screws holding the electronics panel
Jan 08, 2010 | Maytag MES5752BAS Stainless Steel Electric...
I get an "F1" code on my Maytag range.
you need a new temperature probe. its usually located in the upper left hand corner in the rear of the oven.
Mar 19, 2009 | Maytag MES5570 Electric Kitchen Range
I have a Maytag Performa free standing stove/oven. The range top works well, but the oven will not work. When you program the oven to come on, the tempeture starts at 100 then quickly goes to programmed...
I am assuming that element does not come on at all...
A good place to start is the temperature probe . If it is Reading too high, its signal the control board that it does not need to heat.
Alternately the control board may not be acting properly.
Jul 28, 2008 | Maytag Kitchen Ranges
Maytag MES5752BAS Stainless Steel Electric Kitchen Range Logo
134 people viewed this question
Top Maytag Kitchen Ranges Experts
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
