Question about Dryers
HAVE POWER TO THE DRYER, BUT IT WILL NOT START.
  • Dryers Master
  • 8,220 Answers
The first thing I would check is the lid switch, then if that proved to be ok I would go for the fuse. On most dryers the fuse is wired in the same circuit as the lid switch. So when you open the door the dryer stops right? If their was a probo with blockage and that dryer was getting too hot then the fuse melts and ends the connection stopping the possibility of a fire.If that was ok I would look at the timer or the motor as the problem. However the timer would be the LAST thing I would replace.
Posted on Jan 01, 2009
Dryer will not start. Start control engages solenoid and holds contacts closed, but nothing else happens. Solenoid disengages when door is opened and light does come on. Wiring contacts all appear tight...
Check for power through the soleniod... if power is going to the motor and it is not running then the motor is shot...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 14, 2011 | Kenmore 63942 Dryer
Gas Dryer (model#110.74972300) won't start. Power suplly is good but machine won't power up when set & start button is released. What's wrong?
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 17, 2010 | Kenmore Dryers
The Dryer will not start but has power as the drum light works.rhe start switch seems to have power going to it but makes no noise when turned to the right and dryer does not start
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
Nov 08, 2010 | GE DBXR463EDWW Electric Dryer
Dryer will not start but has power going to it timer works light comes on in drum just wont start when you hit the button
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 12, 2010 | Dryers
DLG330RAW Gas Dryer: no power when I push the knob to start drying...
heatman101
May 07, 2010 | Amana DLG330RAW Gas Dryer
Has power but will not start
Dryer Repair - The
Dryer Repair - The
heatman101
Feb 23, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Frigidaire Crown dryer will not start. Has power to it
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Jun 11, 2009 | Frigidaire Electric Dryer
PF singal on dryer. Can not start dryer something electrical possibe pf power failer
Jun 03, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer will not start and it has power to it.
Hello jmhbfdtk4,
If your dryer has power and will not start when you press the start button, you may have an interlock that isn't made to allow it to start. It could be the door switch, a non-resettable fuse inside the dryer or something else. Are you getting any error messages on the system? Please advise and I will follow along with you...
Regards,
Rick
Nov 23, 2008 | Dryers
Whirlpool duet dryer won't start
whirlpool duet dryer has power but will not start--when I press start, it beeps once and the sensing light comes but the dryer doesn't start
Nov 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
Top Dryers Experts
