Question about Bamix Gastro 200 Handheld Blender
Bamix hand held mixer blade won't come off
I want to remove the blade which you turn and depress at the same time taking it out of its little wedge but the rod it is on is not stationary and thus the blade is not coming off...I have very limited space for any tool the hold the rod stationary and I doubt that it is intended to be done that way...but out of ideas..can't use other attachments til I can remove the blade...
4 Suggested Answers
SOURCE: Bamix De Luxe Hand Mixer - cutter guard
Instructions state to remove it, turn it clockwise, so the opposite remains true. To replace it, turn it counterclockwise.
Posted on Sep 11, 2008
SOURCE: Whisk blade on BAMIX hand-held blender is frozen!
try to gently twist the blade up and around the shaft with a pair of pliers. I've loosened mine by pushing and pulling on the blade with the pliers. be sure to use caution so as not to wreck the blade.
Posted on Mar 18, 2009
  • 6 Answers
SOURCE: i need to purchase a bamix hand held blender
Amazon! Or eBay.
Posted on Mar 30, 2011
How can I find a new Bamix old model spice blender/chopper
Bar mix products made millions for world wide sales
kitchen aids that change design so often
they cant support a large parts division
(R&D is geared to sell the next better barmix product )
if you cannot find a new old part
or super ceeded shaft from the next model up
or used drive shaft for sale online
look for a complete used bar mix spice blender/chopper
some people collect barmix units for a hobby or collection
and sell double ups
when you say old model
if the shaft is plastic ....... its .unfix able
its a heat molded construction process
Vintage Bamix M122 2-Speed Hand Held Food Blender Mixer-Chopper
Sep 16, 2016 | Bamix Blenders
I recently burnt out the circuit board for my Bamix M133 stick mixer and thus need to know where I can get a replacement
You could email bamix.com.au. The motors have a 20 year warranty I think. Get a quote before any repairs , as some times replacement is the best option.
Sep 03, 2016 | Bamix Mono M133 White Hand Blender
How can I Loosen the spring blades on a Bamix mixer attachment
You are lucky. they usually fall off mine.
However you can gently ease them off with small needle nosed pliers.
May 23, 2014 | Bamix Blenders
Rusting blade
Why don't you just clean it?
Very carefully use a soap pad, and then dry thoroughly. remember to dry thoroughly after every use, and wipe a little veggie oil on the blades with a paper towel.
Apr 07, 2014 | Bamix Mono Handheld Blender
Making meringue with hand held bamix
Use the A blade and make sure whatever you are mixing the egg whites in is scrupulously free from any grease etc. Make sure the bowl is clean and dry before you use it.
Best wishes
Sep 20, 2012 | Bamix Deluxe Handheld Blender
I have a bamix M200 hand blender & the shaft does not turn although the motor is working can you help?
After a period of time food residue will migrate up through the seal on the "foot" and lodge in the shaft. Once this is gummer up the motor will go but the shaft will not be able to rotate.
The machine will need to be disassembled and the shaft cleaned out. I recommend that you find your local Bamix Service Centre to do this as there are fragile parts in the stick mixer.
May 21, 2010 | Bamix Deluxe Handheld Blender
Mar 17, 2009 | Bamix Mono Single-Speed Handheld Blender
Bamix stick blender Handle vibrates but shaft does not turn
Old food residue and juices will have got into the shaft bearings, and have dried out enough in 9 years to stop it turning. Starting with the simplest solution, try immersing the shaft in hot, or even boiling, water nearly up to the top of the metal shaft. CAUTION - DON'T BURN YOURSELF! Let it stand in the water for a few hours, and then try turning the shaft by hand (with the machine unplugged, of course). This could be repeated a number of times. You may also be able to unscrew the blade guard after this treatment, bear in mind it has a left hand thread, so if you are looking at it from the bottom, turn it clockwise to loosen. Be careful not to lose any seals or springs when it comes off.
If this doesn't work, support the Bamix upside down, and pour a small amount of WD-40 into the blade guard, so that it pools around the end of the shaft. Leave to stand, and the oil should slowly seep into the bearings, dissolving the food residues. Again, try this a few times.
If neither of these work, the Bamix will need to be dismantled to clean the shaft and bearings. This is really beyond the scope of this forum and requires some experience of this type of work.
Mar 13, 2009 | Blenders
Nov 21, 2007 | Bamix Blenders
My hand mixer stopped working.
Have you tried greasing it near the blade. I read in my instruction book that sometimes they seize if they aren't used often. They also suggest trying to soak the wand in a pot of hot water for a minute or two and then trying to use it in the water. Hope this helps
Aug 30, 2007 | Bamix Gastro 200 Handheld Blender
Bamix Gastro 200 Handheld Blender Logo
85 people viewed this question
Top Bamix Blenders Experts
Ruth summersides
Stan Ford
Mai Lor
Are you a Bamix Blender Expert? Answer questions, earn points and help others
