Question about Akai LCT2716 27 in. LCD Television
Mt power contro; board blow the fuse on the left side. Does anyone sell the rmo533 board new. ? It has other numbers of 32power300pcb
    Genius:
  • 1,694 Answers
Power boards are normally rebuilt by a qualified tech.......T.
Posted on Jan 14, 2009
1987 ford ranger turn signals keep blowing fuses. have changed flasher fuse and switch on column. just keeps blowing?
first thing i guess to understand what is going on here ,is a little back to basics on how turnsignals work , first item you have is power fuse then it's off to flasher module than it goes to the turnsignal switch on colum ,of course anywhere on it way to there the power could got to ground and cause the fuse to trip, now the power depending on Left or right selection , is directed to lights on both front and back of truck,thankfully rangers don't have em on the side) now any place in this pathway the wire could go to ground and blow the fuse, now to troubleshoot and narrow down the area that fault is located , (1) replace fuse with correct size and ck for proper fit in fusebox and start and operate truck for a few minutes DO not use turnsignals, ck fuse is it still good if so go to step 2 if not stop and ck wire conditions in steering colum and switch(2) start truck and try right hand turn signal only verify lights working ,Ok yes/no if not replace fuse and try left side same way, Ok yes /no if right or left side only blows fuses take ALL bulbS OUT of lights and try again , if fuse still blows then look for wire fault on that side of truck if fuse is still good then look carefull at light bulb sockets for rust and powered corrosion (ill bet an 87 has some ) you may need to replace bulb sockets , they do sell em in autoparts stores .
Jun 30, 2014 | 1987 Ford Ranger
My driver side power seat quit working in my 2004 eddie bauer explorer. I rplaced the entire seat (adjuster assembly, track and all) and still no workie. I hear clicking at the chip board when I move the...
Sounds like a short in the wiring. Start tracing the wire back. You will probably find it under the carpet on the Left side, near the door. Good luck.
Aug 16, 2013 | Ford Explorer Cars & Trucks
Turn on
Three thoughts---check for short to ground with fuse removed and power off (unplugged) on both sides of fuse.
Use a original type fuse---generic ones often blow for no reason.
Consider replacing the board if you can confirm issue is on it.
Nov 03, 2012 | Samsung UN55B8000 55 in. LCD HDTV
I have an LG desktop computer model MT-Intel serial number 104067 and I need to purchase new fans but I can't seem to find anyone who sells LG components ....
you shouldn't need to buy lg specific fans, pc fans in general are interchangeable. Measure your faulty fans from side to side and search for fans of that size instead. Just check the amount of wires you have coming from your fans and make sure the replacements are the same amount.(not necessary but just to be on the safe side, it will make sure all of your sensors work correctly)
Hope this helps.
May 09, 2011 | LG Computers & Internet
My zenith plasma 42w46x tv. doesnt show pic. the sound is there but no pic. I opened it up and founf out the the board on the right side of the tv(looking at it from the back) has two fuses, one of them...
Hi:
This is the X-systain board replace this board and your problem will be solved. The part number can be found on a white sticker some where on the board. Get the number and google it or enter it on E-Bay because alot of shops sell these boards when the get units with bad screens. Or try www.shopjimmy.com for a new board.
Mar 10, 2011 | Televison & Video
Mine has 7 red blinks and wont come on. i pulled off the back and found a fuse blown on left circuit board, i can unplug the left circuit board from main circuit board thats in middle and tv will act like...
No, your done. Now replace the Y-Main, that's the large one you found the fuse blown on and replace the two buffer boards that the Y plugs into. Those are the two at the far left. The part numbers are on the boards. So that's 3 boards you will need. sometimes they sell the buffers together as a pair which is cheaper. DO NOT buy from second hand resellers. Always buy new when it comes to plasma sets.
Nov 30, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
Fuse Blowing in Power Supply SOYO MT-GW-DYLM24D6 24
If you can solder connectors you can build your own power supply for SOYO. Try the following link or google "gbyer external power supply".
http://slickdeals.net/forums/showthread.php?t=1655449&page=5
Replacement power supplies were avilable recently but it seems they are all depleted.
Nov 06, 2009 | Computers & Internet
No power to Samsung FP-T5084
I had the same problem twice with my Samsung FPT 5084 and it was the 12 AMP fuse on the power board both times. The bad part is you have to remove the whole back plate to get to it but once off it sits on the power board (dead center) towards the lower left hand side of it. Replace the top fuse or you can replace both. They're just regular ceramic sealed 12 AMP fuses that cost about 50 cents each.
Jan 22, 2009 | Samsung FPT5084 50 in. Plasma HDTV
RCA HDTV R52WH74YX61 blown fuse
there are 3 small red rectangular shape objects to the right of the flyback transformer these are fuses the fl231 most time goes bad .fl231 is the location number under the green circuit board. the location number can also be wriitten on top(brown side of the cicuit board)
you may have to put back the .6a you took out was it ok?
TRITRONIC ELECTRONICS sell parts . cathray 416 241 1106 sells also
Nov 22, 2008 | Televison & Video
I need a replacement fuse
Ita on the end in small lettering on the fuse 100%.. You may need a magnifyer to see it. BUT a fusse does not blow all by its self most of the time. It will blow if there is a problem with a circuit and Will case a fire if it is replaced by a larger fude and keeps the circuit from blowing.
Sep 10, 2006 | Koss KS2503 System
Akai LCT2716 27 in. LCD Television Logo
61 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
