Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Maytag LSE7800ACW Dryer unit not rotating, but putting out heat. Is this a blown motor, slipped belt, blown fuse? Self-repairable? I'm pretty mechanically inclined, but wouldn't want to spend hours or wait overly long for parts delivery...
  • dlebolt Dec 31, 2008
    Thanks. Now how would I gain access to inspect? Service manual available through this site or on line?
  • 2,920 Answers
You probably have a slipped or broken belt
Posted on Dec 31, 2008
  • Ronnie Houston Dec 31, 2008
    call 1-877=922-2880 they should have the manual and parts
I have a Kenmore 70 series dryer that is not spinning. When turned on u can here the Moter but it won't spin. Belt looks ok.
Is the motor pulley rotating? if it is , how tight is the belt, is the motor pulley turning and the belt slipping? Is the motor weak perhaps, if it is not turning, or has lost power it may need replacing. if it does rotate and the belt is slipping replace the belt and possibly the pulley if you have that option.
Jun 24, 2015 | Kenmore Washing Machines
Maytag Neptune Drying Center MCE8000AYQ Why does it not tumble?
I would start at a belt. Most cities have a do it your self appliance store, they can order you the part and ship it to your door or you can pick it up. Some Belts are as low as $16. Before condemning it is worth the gamble. Before Disassembing the unit go to U tube search out your dryer there should be an instructional video on how to replace it. Also pay attention to how the current belt is fed. I take a picture with my phone or diagram it. It helps especially if you get called away from the project. Hope this helps
Jun 21, 2013 | Maytag Neptune MCE8000AY Electric Dryer
A constant clicking noise near the motor of my maytag dryer. seems something is slipping as occasionally the drum and belt slow down
It sounds as if the idler bearing has started to fail see this picture
The idler pulley in the picture is behind the motor.
I would check the ilder pulley to see if it rotates freely and does not have any odd side to side movements. If it does then replace the idler pulley and belt.
NOTE: Before you remove the idler pulley and belt note carefully the installation position of the belt, idler arm, spring and the idler pulley. For a first timer trying to do this it can be quite frustrating to get them all positioned correctly.
Idler pulley:
I hope this has been useful information to you. Good day.
Jan 06, 2010 | Washing Machines
Dryer does not heat. It does rotate. Any ideas?
The heating is either a blown fuse or element and the rotating is the belt that has come off or broken or worts case the motor has packed up
Dec 28, 2009 | Whirlpool LEQ9858P Electric Dryer
CHANGE THE DRYER BELT MODEL LSE7800ACW MAYTAG WASHER/DRYER COMBO can go to the following website and check out how the belt goes on the dryer.
On a front load dryer, you would normally remove the front to expose the drum and belt, after you remove the drum then that exposes the drum rollers, motor, idler arm pulley, etc.
Hope this helps
Sep 29, 2009 | Maytag Dryers
Has not heat - it happened suddenly
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, whcih requires
Jul 05, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag dryer won't rotate after blower wheel replacement
Check the drive belt and belt tensioner. From the way you describe it, the belt is loose and with a load in the drum, it will not rotate due to belt slipping.
Jun 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer Drum Won't Spin
Reach inside and grab ahold of the baffle. Try to spin the drum, it should have resistance. If it spins freely you have a broken belt. Hope that helps. Dave
Dec 16, 2008 | Maytag Dryers
I have a maytag stackable washer dryer model number LSE7800ACW when i turn on the washer it will not fill it will not spin it will not do anything but the dryer works just fine. What is wrong
HI. thanks for the question. you have a blown fuse ,inside the washer. remove the front panel. on the left ,you will find a small glass fuse .check that. if its failed you will be able to see, that the small metal strip inside the fuse is broken , if so replace the fuse. thanks the appliance doc . please rate my answer.
Oct 07, 2008 | Maytag Washing Machines
Maytag lse7800acw
The motor is faulty. Either the relay contacts are stuck or there is a shorted winding. Best to replace the motor.
Jan 13, 2008 | Washing Machines
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
49 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
