Question about JVC GR-AX230 Camcorder
Will record for only few seconds then rewinds and stops recording
Recording problem
start recording then in few seconds starts rewind and stops recording
  • 33 Answers
Could be a drum or heads. Looking at a $120 repair
Posted on Dec 31, 2008
How do you rewind while dictating with the Olympus DM 620?
To rewind, you simply push the rewind button. However, this does not rewind from the point you are at like a tape does, it goes to the beginning of the recording. Once you are in the play mode, pushing rewind will rewind from that point.
Jun 03, 2015 | Olympus Audio Players & Recorders
Sony Handycam CCD-TRV37 8mm Analog... 2 Problems, maybe more unknown at this time:
This does require disassembly to remedy the problem. There are various possible fixes. The most prevelant I have seen is cold solder connections of the board connector for the fpc cable from the top operation switch block ass'y. All you need is someone who can handle this task, like a professional. The controls that you are experiencing problems with are all linked with one cable and connector. One bad solder joint can cause serveral operation faults. Good Luck, magic seadog
Aug 18, 2007 | Sony Handycam CCD-TRV37 Camcorder
I taped a TV show. But I can't fast forward to see the end part that I want to watch. It just advances to the end.
I'm not surprised that it advances on the end. The VCR doesn't know where the end of the taped programme is. You will have to search manually for it. Start at the end of the tape and rewind a few minutes worth of recording then press 'play' and see what you get. If not successful rewind further and try again, etc,etc. Alternatively you could press "play +rewind" which should allow you to watch the record on what is fast (=x2) rewind. It will help you if you know how long the show was and at what point the tape was when recording started.
Mar 26, 2015 | Televison & Video
What is the reason the tape won't play on sa-ak95
It may be the tape(s) themselves. Pre-recorded cassette tapes are usually no problem for most players, but many user-recorded tapes were of the C90 or C120 variety. These cassettes use much thinner tape in order to get the recording time. This can cause the tape, after many starts and stops and partial fast-forwards and rewinds to get tight on the reels. This will cause the tape sensor to think that the tape is at the end of the reel when it is not. Sometimes rewinding from end-to-end will help, but not always,
Nov 07, 2014 | Microwave Ovens
Video cassette player/recorder LGRC 689D wont rewind properly
The problem is in the idler assembly inside the machine, some use rubber that dry out and crack, or there is a spring loaded double clutch wheels that get weak over time. In order to fix this the idler assembly must be replaced.
May 04, 2012 | Televison & Video
I do not know how to use it, i have the manual, but i do not find it
The recorder takes 2 AAA batteries. Press Menu/Folder (on the right above the jogdial (Stop, Rewind, Fast Forward, Play)) to select the folder to add a new recorded item. (The folders are A,B,C, or S. Folder S will come up with a date and you can select another date for the recording.) Folders A, B and C can hold 100 files each; Folder S has 365 dates which can hold 15 items each.
Press and hold the Menu/Folder button for a second or longer. The Screen should show the Mode menu. Press Play and then the Fast Forward and Rewind buttons to set the recording quality. HQ is the high quality recording and will fill up the available storage on the organizer more rapidly. LP will record for the longest period.
Set the Microphone sensitivity by pressing and holding Menu/Folder. Then press the Fast Forward or Rewind button until Mic appears on the display. Then press Play and use the Fast Forward or Rewind buttons to select Low or High sensitivity. (An external mic often gives better results.)
Once you have set the folder for the next recording and the recording quality and microphone sensitivity, press Rec (center above the jogdial) to start recording. Press Stop to end the recording or Rec to pause it. (It will stop if the Pause is longer than 10 minutes.) Press Display to see how much longer you can record before using up the available storage space.
To play back a record, locate the item in the folder then press Play.
The manual for the Olympus VN-1800 is available from the Olympus support site: http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=841 . The direct link to the English version of the manual is http://www.olympusamerica.com/files/oima_cckb/VN-900_VN-1800_VN-3600_Instructions_EN.pdf .
I hope this helps.
Aug 30, 2011 | Olympus VN-1800 Digital Voice Organizer
Rewinding to listen to recording
You should use the computer with Digital Voice Editor software to have more options when trabscribing. You could then use the transcribing keys to playback your recordings and regulate the velocity of the playback.
Download Digital Voice Editor Version 3.1.03 for Windows Vista/XP/2000.
64 bit version operating systems are not supported, though
Jun 08, 2009 | Sony ICDP620 Digital Voice Recorder
How do I rewind
by just pressing the rewind button, it goes to beginning. by press and holding down the rewind button, it will start rewinding slowly and get faster the longer it is being held down.
Jan 20, 2009 | Olympus WS-300M Digital Voice Recorder
Eject light comes on after I start playing the tape
ksmitheram,
I had the same problem with my camcorder just awhile ago. This can reflect a low battery. Try plugging in the camcorder for a couple of hours without using it. Then try recording or playing back the tape with it plugged in. Unplug it and check again. If this does not work you may have to replace the tape head.
Dec 25, 2007 | Samsung SC-D363 Mini DV Digital Camcorder
VCR won't rewind
Soution #1 get nice but cheep VHS " rewind " macine.
2nd. Some machines have a special rubber wheel in the center,between the left [ take up or rewind ] & right [ play\record ] assemble. VERY diffiult to repair if u don't know what u are doing.
3rd. Find & REplace EVERY rubber band that u find in the machine.
Oct 18, 2007 | Sansui VHF6010 VHS VCR
JVC GR-AX230 Camcorder Logo
78 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
