Question about Whirlpool GU2400XTP Built-in Dishwasher
Waste water does not get expelled, does not empty
Motor and impeller seam to be fine , impeller turns clockwise to wash and counterclockwise to drain but the waste water does not drain
  • l5167 Dec 31, 2008
    The problem is solved , I wish I called for help sooner
    Thanks Again!!!!!
    Sergeant:
  • 311 Answers
Youve got a blockage,most of the time its at the air gap on top the sink.It can be at the disposer.start there and work your way back
Posted on Dec 31, 2008
My whirlpool aquasteam ADP7955 TOUCH starts it's cycle fine but halfway through starts beeping and a different cycle starts flashing. What is going I'm?
Is it aborting the wash and going into a drain cycle? That would be because there is something wrong with the draining cycle - the water is not flowing out. Check your drain filter, if fitted, before anything else - then check for blockages at the waste pipe connectors on the sink / waste pie, etc. Can you hear the drain pump running on the drain only cycle? a chug chug chug noise. If not, the pump may be seized with a coin / nail / pin / broken zip / button etc. Can you you turn the pump impeller by hand, or is it seized?
Check all the basic things like filling, emptying, filters, water supply before doing anything else.
Jan 02, 2018 | Whirlpool Washing Machines
Dishwasher draining / emptying of water
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid
Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt
One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor
If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer
Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Oct 27, 2008 | Frigidaire Dishwashers
Have 8kg front loader ewf1481 machine wont empty. red light came on. emptied emergecy hose pulled out filter/cleaned (minimal discharge,lint small amount) pressed start showed 1min remain to rinse (made...
It doesn't matter which way you turn the impeller- it should just be free to rotate ;-0)
I would recommend checking that the impeller motor is actually working by following the last part (in bold italics) of my , pre-typed(!) guidance notes on filters and motors-
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
John C
Mar 03, 2011 | Electrolux Washing Machines
The machine wont empty water gives a code of 03 I have cleaned the drain filter and check the drain hose still wont drain water unit is 1 1/2 years old
03 is drain error, as you know. The machine is sensing that the water isnt draining enough in 5 minutes...Unless there is an electronic problem the main reasons for the error code is because the drain hose is blocked, or the pump has something preventing it from turning, like a coin jammed in the impeller, or the pump motor itself needs to be replaced....These pump motors tend to get detritis in behind the impeller shaft seal and this often causes the pump to fail.....Good luck....Nomess
Jun 16, 2010 | LG WM2233H Front Load Stacked Washer /...
Dishwasher will not fill up.
Set the controls to off then power off at the mains for 30 mins and then power mains back on and run a drain program or a full wash program. If the water won’t drain away then the most likely problems are the door interlock switch is faulty, the drain water motor is faulty, there is a blockage in the drain outlet pipe or filter – this will need unblocking, there is a blockage in the water pump – this will need to be unblocked, the controller board is faulty – but this generally shows an error code. First turn off the mains power to the dishwasher then check the internal filter and screen and clean it thoroughly. Then check the waste water hose and any outlet valve and make sure that it is unblocked and free of any obstruction or waste material. If you have access to the water pump you can check that it is free of obstruction and is able to turn and that none of the impeller vanes have been damaged. Then if all this is OK then try turning on the mains power and running a hot wash cleaning cycle to flush out any remaining sludge / debris.
If the outlet pipe is clear and the pump motor is turning and there is no pump damage then there has to be a blockage somewhere. You could lay the out pipe flat on the ground with the end draining into a tray to see if any water actually does come out. If it does then you do not have a total blockage. This is because it will be most likely draining out of the machine due to gravity and shows that there may be a partial blockage of the pump is defective even though the motor may be running. You will need to remove the pipes to and from the pump to check for blockages and also remove the pump to inspect for damage to the impeller or a blockage in the pump housing where the hoses connect. If the pump housing is clear and the impeller can be turned freely with your fingers then the direct coupled or belt driven linkage between the motor and the pump is the most likely broken and will need repair or replacement. If the impeller cannot be turned easily and does not turn with the motor running then the impeller or the direct linkage is either seized or broken and will need replacing. If your pump and impeller is belt driven then check that the belt is not slipping – this will normally result in increased noise and a possible smell of burning rubber
Dec 30, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
My bosch diswasher is 2 months old and now the water doesn't drain. how can i fix it
If the outlet pipe is clear and the pump motor is turning and there is no pump damage then there has to be a blockage somewhere. You could lay the out pipe flat on the ground with the end draining into a tray to see if any water actually does come out. If it does then you do not have a total blockage. This is because it will be most likely draining out of the machine due to gravity and shows that there may be a partial blockage of the pump is defective even though the motor may be running. You will need to remove the pipes to and from the pump to check for blockages and also remove the pump to inspect for damage to the impeller or a blockage in the pump housing where the hoses connect. If the pump housing is clear and the impeller can be turned freely with your fingers then the direct coupled or belt driven linkage between the motor and the pump is the most likely broken and will need repair or replacement. If the impeller cannot be turned easily and does not turn with the motor running then the impeller or the direct linkage is either seized or broken and will need replacing. If your pump and impeller is belt driven then check that the belt is not slipping – this will normally result in increased noise and a possible smell of burning rubber.
Dec 28, 2009 | Bosch Dishwashers
Washing wont empty of water to finnish cycle ive a washer dryer 1100
Do the following.
  1. Switch off the machine, unplug or disconnect the mains power to the machine and turn off the water supply to the machine.
  2. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Nov 08, 2009 | Washing Machines
After wash cylce waste water reains in bottom of
Hi
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Please do rate this solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Mar 31, 2009 | Fisher Dishwashers
Neff S5555 - empties water but stuck in draining mode.
if this machine uses an electrical-mechanical timer with cam switches, the try oiling the shaft bushings both for the timer motor and cams-the timer may be getting stuck because of dry or corroded bushings
May 26, 2007 | Neff 24 in. S5555X0GB Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
111 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
