Question about Craftsman 2600 PSI Honda Powered Pressure Washer
I have a craftsman w/ honda model # 580752060 pressure washer. Started washing & after about 10 min. lost all pressure, no water comes from nozzle while engine runs. Cut off engine & nozzle sprays
    Problem Solver:
  • 16 Answers
You have a clog somewhere
Posted on Oct 17, 2012
3 Suggested Answers
SOURCE:
  • 259 Answers
SOURCE: 2500 pressure washer 2.3, its
Check he screen where the hose screws in. There is a screen inside the fitting you should clean. Take it out carefully by using a screw driver around the edges and make sure the screen is clean. After you put the screen back in take the hose off the gun and see if water comes out of the hose. If it does you have to take the gun apart and clean it.
Posted on Mar 20, 2011
  • 5603 Answers
SOURCE: modeL 580752610 CRAFTSMAN 2600PSI
This is the typical problem when the water admitance valve sticks. This valve admits more water to the pump when the pressure drops when wand is triggered. When pressure increases, water is blocked. This is the way they regulate the pressure. The valve is in a bore, usually crossways to the axis of the shaft of the pump. Disassemble the valve noting how the parts go in. Clean the bore with crocus cloth on a dowel rod. Replace all the O rings on the valve spool. Lightly lube the spool with plumber's grease and reassemble.... Good as new! You can often buy a kit of O rings for the valve. They must be EXACT right size. This is normally a one-half hour job.
Posted on Apr 15, 2011
How do i fix a honda landa 3500 pressure washer, when the water doesn't come out when started?
Check out the trigger mechanism. Water should come out at any time, even when you do not have the unit started.
Aug 22, 2016 | Honda Landa PG 3500 PSI Pressure Washer
Throttle linkage is loose and when started water does not come out the nozzle after BEING BLED OF AIR
The unloader on your pump is bad...this is causing both problems. Find your pump model # ...probably an AR pump ...they fit the Honda GC engines well and go to this site Pressure washer parts catalog quick links Pressure Washers High Pressure... they can guide you to the correct unloader... Good luck
Jan 19, 2014 | Powerboss 020309 3000 psi 2.5...
Craftsman 2500psi 2.3 gpm briggs and stratton pressure washer wont start
if it is still within the warranty period , take it to an authorized service agent for a check
if not I would be looking at the fuel system ( water in the carby) or wires to the stop/.start switch
May 17, 2017 | Craftsman 2500 PSI Briggs & Stratton...
Why will water not flow through hose into the spray gun with the washer not started as well I started the power washer and the water still does not come out.
My Craftsman pressure washer has a filter in the hose tp the pressure wand. I found I must have had some dirt in my garden hose and these filters were plugged. No pressure at all till I cleaned them out.
Jul 04, 2017 | Craftsman 2500 PSI Briggs & Stratton...
Pressure washer lost pressure in the middle of a job
The pressure valve has stuck in the high pressure position. This prevents anymore inflow and hence no further water will be pumped.
Rebuild the valve... There are O Rings to replace and clean the bore with croocus cloth. Lube the O rings with plumber's grease... good as new! 15 minute job. Get EXACT sized O rings for the unit.
May 16, 2010 | Honda Pressure Washer PSI 3000
Karcher k2400hh pressure washer, water pressure cuts out.
Hello cikanek:
Try this:
From your posting, I assume you have removed the splash cap and the nylon bypass valve cover. Connect the water supply to the pump and connect the high pressure hose and wand to the pump outlet. Wad up a small towel and place it over the bypass valve opening to catch the valve insert when it pops out. With the engine throttle closed, pull the starter cord several times to see it the valve insert will pop out. If it doesn't come out after two or three pulls, set the throttle to low and start the engine. I have performed this procedure a number of times and the valve insert always pops out. There is no real danger of the valve parts getting seriously airborn since the actual pump output volume is very low (2.5 Gal/min).
Good luck,
Ed
May 17, 2009 | Honda Karcher G2400HH-R Pressure Washer
After about 10 mins error code H2O is displayed.
the h2o message means the machine isn't getting enough water. check pressure and water intake pipe.
Mar 15, 2009 | Washing Machines
Please help me,,,, my maytag epic z front load washer
I think you've actually got an uprated control board.
Modern designs allow for less water usage - most in as you say about 3"
Water level is determined in 2 ways #1 pressure - A pressure switch is used with an inverted container low down in the water. As level rises, pressure builds untill the switch opens and the water shuts off.
#2 Time - The valve is only allowed to open for a preset time (to prevent flooding)
If the first board was faulty, the pressure switch probably was being ignored, so was overfilling.
Older models also used more water per wash.
Shutting off after 10 minutes on a quick wash? - if it performs a full cycle in this time, it's working normally. As I said - just updated.
Let me know if there are any defects or faults , otherwise, it seems to be "modernised" by using the new board.
Jul 04, 2008 | Maytag EPIC MFW9700S Front Load Washer
Craftsman 2600 PSI  Honda Powered Pressure Washer Logo
1,290 people viewed this question
Top Craftsman Garden Experts
john h
lnbn1975
Jay Finke
Jay Finke
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
