Question about Kenmore 18 in. 14432 / 14439 Built-in Dishwasher
Dishwasher does not drain properly
This dishwasher has been running properly for the last two years. Now, after a wash is complete, water is found remaining at the bottom of the tub.
  • 2 more comments
  • Steve Daniels May 21, 2007
    I have not replaced the disposal, so there is a definite hole in the disposal for the water to escape.
    When I took out the pump, I blew into the disposal tube. Yes, some debris came out into the disposal.
    I initially tested the pump to see if it was operating. Yes, it was operating. I then tested it again with water. Very little water went through the pump. I then took the pump apart and determined that the pump design was not reliable. I reworked the pump to correct what I felt needed correcting. I then put the pump back together and tried it with water. It worked. I reinstalled the pump in the dishwasher and did a wash. The pump would not work. During the time the pump should be operating, it did not sound good - too much chattering. Even though the motor works, I think the motor is faulty anyway.
    Now I have to decide if I want to replace this poorly designed pump with a new Kenmore pump of the same model or find a good quality pump somewhere else. If you have any ideas for other pumps available, I would greatly appreciate the help. Thanks.
  • Anonymous Feb 11, 2008
    My dishwasher is not draining. Only used a few time in 1st year as it is in the basement. Looks like it has been leaking for some time. Took off drain hose and there is a rubber seal over drain. ? is that supposed to be there or is it the problem?
  • Anonymous Mar 09, 2008
    when use, water is left in the bottom of the dishwasher
  • Anonymous Mar 15, 2008
    sounds like pump is jammed screeches and grinds water does not empty
    Problem Solver:
  • 11 Answers
One of your problems could be your drain line is clogged with grease and debris from previous uses, the other problem could be if you had your disposal recently replaced the drain knockout on the disposal wasn't knocked out. In normal use of a dishwasher at the end there is always some water left in the sump area of the pump so seals and check valve baffles won't dry out and crack. Hope this helps.
Posted on May 20, 2007
I have a Bosch SHE55C05UC dishwasher and it just started to not wash properly and leave water in the pan below (first time it did not drain at all.. I tried the rinse/hold cycle and got the unit to drain...
I am assuming you have checked the filter and drain sump and there are no obstructions. Have you tried taking the drain pipe out of the sink downpipe and checking if it drains directly into the sink?
I am also assuming the wash cycle is completed when you open the dishwasher.
Do you hear the drain pump running?
Post your comment after you have checked the things I mentioned.
Jun 17, 2010 | Bosch SHE55C05UC Dishwasher
KitchenAid dishwasher allows water to drain while washing
Your dishwasher is siphoning the water out. The drain hose should turn upward, nearly to the bottom side of the counter top, before it attaches to the drain or disposal. If it has an independant drain it still needs the rise and also needs an air break to stop the siphoning.
Jul 17, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishwasher won't drain completely . It is 2 years old with very moderate use. Drain mechanisms have been checked and seem to have to clogs.
Hi..
If the water doesn't drain from your dishwasher completely, check these:
Drain line/air gap
Pump
Drain valve and/ or solenoid
Belt
Motor
Timer
Drain line/air gap
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid
Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Good luck!!!
Regards
PCmania
Jul 08, 2009 | Dishwashers
Food particles are on dishes after washing
Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
Jan 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
My GE dishwasher after complete washed look like water not out drain (water remain in the tub)
Normally, there is a filter that precedes the pump and that's probably clogged with food by products. Look for the filter screen near the bottom of your dishwasher and remove any debris there.
Another consideration is if your dishwasher drains into/ through your garbage disposal... If so.. make sure that is empty and drains properly when you run the water in the sink. Hope that helps....
Aug 07, 2008 | Dishwashers
Water not draining out after wash cycle
frigidaire dishwasher model#MDR251RER0/serial#TH84453602 not completely draining. I hear when it the drain cycle begins but does not empty completely out.
Jan 05, 2008 | Frigidaire 24 in. GLD2150RCC Built-in...
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Asko 1585 Dishwasher
do they flash lik all on one side then the other? Start a cycle, then open the door. Do the lights flash the same way when you open the door as when it stops? if soyou may have a door that needs to be adjusted so it closes better. when the cycle ends, is there any standing water in the bottom? if so you may have a poorly routed drain hose or a partial clog in it. Last, pull the bottom panels off and look inside the bottom of the dishwasher and see if there is standing water down there . If ther is you have aleak somewhere or a bad drain pump. You r only other choice is a bad pressure switch. If youve already adjusted the water fil to the proper level ( just up to the grey plastic housing that the lower wash arm sits on) tehre really aernt any more options. Hope this helps!
Aug 29, 2007 | Asko 24 in. 1585 Built-in Dishwasher
Dishwasher dosen't drain completely
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Dec 08, 2006 | GE 24 in. GSD2600GBB Built-in Dishwasher
Kenmore 18 in. 14432 / 14439 Built-in Dishwasher Logo
179 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
