Question about Car Audio & Video
Amp turns on but no sound
I have a Soundstream Reference 300 2 channel amplifier i picked up from a friend. (for free). Now i hooked it up to see if it works b4 i did anything with it. now it has 3 lights on it 1 is a Fault light(yellow), high power light (red), and high current (green) now ive had this same model of amp bout 10 yrs ago and it was a monster for a ''rated 200 watts'' to the point i hooked it up put in both modes power and current and it doesnt put any sound out now the all the lights work as they should but the fault light doesnt come on though. can anyone tell me what the problem is and how i might be able find the problem and how to go about fixing it and any insights would greatly appreciated
  • 1 more comment
  • hugo chapa Jan 05, 2009
    i have the same problem with an crunch blx1000d....all voltajes ok..no sound out.....helpme pleaseeeeeeeee.......bybybybby...
  • jasonj28 Jan 06, 2009
    its an 2 month old pioneer aftermarket cd player
  • jason skovly May 11, 2010
    are you using the factory or aftermarket deck in your auto?
5 Suggested Answers
  • 631 Answers
SOURCE: california 3600 mosfet discrete 3 ch amplifier 600 watts does not work
It sounds like it's going into protect. To be sure it's not the wiring, disconnect all speaker wires from it. If the light still goes out, check the DC voltage on the B+ and remote terminals. Place the black meter lead on the ground terminal of the amplifier. If the voltage remains above 11 volts as the amp tries to power up, the output transistors are almost certainly shorted causing the amp to go into protect.
Posted on Nov 25, 2007
  • 631 Answers
SOURCE: boss chaos 150 200 watt that shows light but doesn't produce sound
If this is the CH150, it's not bridgeable. Try connecting it normally (one speaker per channel) to see if it will produce output.
Posted on Dec 05, 2007
pjstanley
  • 185 Answers
SOURCE: QSC 2450 Power amplifier
i have a pyle pro 1000 watt max 2 channel mono and 2 channel stereo and when i get that thing loud the little red light cums on basically what i mean is that the amp on channel one is cooked i myself i wouldn't even use it y cause more damage
Posted on Apr 07, 2008
  • 13 Answers
SOURCE: don't know to conneect my amplifier connecting firdt a soundstream ecualizer
What are you running in to your amp? If it's a CD player or radio, find the wires from them, disconnect them from the amp and connect them to the equalizer, then connect the equalizer to the amp.
Posted on Jul 12, 2009
alicantecoli
  • 21990 Answers
SOURCE: Soundstream Reference Class A 6.0
The cause was most likely that it was overdriven causing this power stage melt down ,best advice is to bin it as it will cost more in time and labour to repair than its worth ,these sort of amps can be picked up from local electrical retailer from 100euros ,by the time you locate components and then solder them in is it worth it ,unless you enjoy doing it and have nothing else to do on a dark winters night then please do so .
Posted on Jan 03, 2011
When connecting power to Sound Stream amplifier model # LW4.480,Whats the configuration?I'm wondering if the remote trrminal next to the pos. and grnd. needs a connection in order to power up the amp?
Hi Alex, my name is Shaun. i will try to help you with your problem. The remote terminal you are referring to is an internal contactor that will power up the amp when your vehicle is turned on. It needs to be hooked up to a switched hot, so that when you turn on your key, the amp will power up. Your best bet would be to pigtail into the switched hot wire that powers your head unit. Be sure NOT to use the power antenna switch wire, if your head unit has one, as this will cause the amp to turn off every time you put in a CD or use an MP3 player. Also be sure not to use the "constant hot" wire for your head unit. Doing so will cause the amp to stay on all the time and drain your battery. Hope this helps. If you need any more help with this, feel free to reply to this answer and we can dig deeper. Have a great day!
Jun 16, 2011 | Soundstream 680 WATTS 4 CHANNEL MARINE...
Have a 1996 soundstream reference 1000s amp 2 chan. Want to hook up 2 2011 12 inch kicker cvt woofers 4ohm. What is the best way to run this set up?
I have Ref-1000s with two Pioneer TS-W1200C 4-ohm subs bridged in series. So it is 8-ohm mono load, easy for an amplifier, long durability, less heating, low current consumption. I have heard that this amp might break if used with low impedance loads.
Mar 18, 2011 | Soundstream Car Audio & Video
I have a visonik 800watt amp and i got it from a friend for free and i hooked it up right and as soon as i turned it on the 2 fuses blew then i replaced them and tryed it again and it stoped again so i...
Its the amp, do not put any more fuses in it
you need to get it checked out by a technician.
Its probably a power supply fault or blown output devices.
Hope this helps
Thanks for using FixYa
Aug 02, 2010 | Visonik V2508 2-Channel Amplifier
Sound stream little wonder 62o. keeps tripping off for no reason its new only 3 weeks.spoken with other persons they have the same problem
IN MY OPINION I WOULDNT OWN A SOUNDSTREAM AMP NOT BY ANY MEANS KNOCKIN UR AMP BUT IVE NO GOOD LUCK W ANY SOUNDSTREAM AMP IVE EVER HAD
Feb 19, 2010 | Soundstream Tarantula Car Audio Amplifier
I have a brand new soundstream xxx 6500d amplifier and when i installed it for the first time protect mode light come on even without rca jacks and speaker wires hooked up. any1 can help?
You need to plug in the RCA and speakers you could blow the amp. The amp is sensing no Input and No output. I would unplug the amp wait around 30 seconds then install the rca and speakers THEN install amp to battery + cable. You should be ok.
Jan 24, 2010 | Soundstream Xxx-6500d Power Amplifier Xxx...
I have a reference 700sx and the left channel does not work.I tried changing rca cables and also a different rca output from the deck.is there a place I can take/send it to be looked at and or fixed?
SEE MY ADD UNDER THE REPAIR FACILITY LISTINGS ON THIS SITE. MY CONTACT INFORMATION IS THERE. I HAVE A REFERENCE 700SX MYSELF ALONG WITH A FEW OTHER SOUNDSTREAM AMPLIFIERS. IF YOU CANNOT FIND THE ADD. YOU CAN EMAIL ME AT PROFSRVCS@AOL.COM. I AM NEW TO THIS FORUM AND I HAVE YET TO FIGURE OUT HOW TO DIRECT PEOPLE TO MY ADD IN THE REPAIR SECTION. THANKS......V
Dec 03, 2009 | Soundstream CAR AMPLIFIER, 4 CH, 120 WPC...
Buster
have you got a wiring kit if so tell me what wires you've got and what amp it is and what subs you've got and what head unit u got have u got the standard one or an uprated one post back
Jun 05, 2009 | Soundstream EGA300.2X 300 Watt 2 Channel...
Soundstream rub 500-1 mono....
U need to make sure your subs are wired correctly. And u need to make sure all your speakers are at the same ohm load. If u hook up two subs on one channel and two more on the other one u need to make sure that your subs are all 2ohm or 4ohm subs cause if u got two 4ohm subs ran parrallel then u will have a 2ohm setting and if both of them are 2ohm subs them your load will be a 1ohm load witch could harm your amp unless its an 1ohm stable amplifier.
Nov 21, 2008 | Soundstream RUB500-1 Car Audio Amplifier
Car Audio & Video Logo
193 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
