No agitation There is no agitation and water turns on and it emptys out into the drain help!! I can't figure this one out. I have an 80s vintage stacked washer and dryer. The washer motor turns the agitation spindle just fine. I can see it twist back and forth about 180 degrees. However, the plastic agitator fins spin back and forth about 5 degrees. I have removed the agitator from the spindle and checked it for broken teeth. There are none.
    Sergeant:
  • 311 Answers
Is this a whirlpool/kenmore top loader if so your drive coupler is broken
Posted on Dec 31, 2008
No drainage, Sound in Spin/Rinse Cycle
You may have a broken pump belt, or belt may have fell off pump pulley. Another possibility is that you have a bad clog before the pump keeping water from draining. Your machine will agitate because this is a separate belt. Good Luck Friend.
Oct 13, 2017 | Kenmore 98702 Stacked Washer/Dryer
98702 Stacked Washer / Dryer Your question about 98702 Stacked Washer / Dryer has been posted. Mom has a Kenmore stackable washer. She ran water in for a load and the water ran out of the washer and onto...
Get the control panel off and remove the water pressure tubing. Blow it out and reconnect to pressure switch. Remove water so that pressure can once again build inside the tube. Retry>
Oct 22, 2011 | Kenmore 98702 Stacked Washer/Dryer
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
The stackable washer will not agitate
Give me a model number. Fridgedare and White westinghouse made some of these stacks for Kenmore. I'll need to know the manufacture. Reply with the whole model number and I'll help.
Aug 27, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kicking out water during wash cycle - spin instead of agitation
Try these
  1. Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  2. The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  3. Check the drain control lever
  4. Test the drain control coils
  5. Check the cam bar
pls rate my suggestion..
Jul 19, 2009 | Maytag LSE7806A Top Load Stacked...
Washer wont drain....
try the lid switch with a screwdriver in the slot to see if it activates. Mine did the same thing, would agitate but not empty nor spin and it was the lid switch assembly--a 35.00 part that cost 150.00 to repair with a repairman!
Jul 11, 2009 | GE WSM2420T Top Load Stacked Washer /...
Frigidaire Stacked Washer and Dryer
check to see that the agitator is spinning out the water, if it is not, you may have torn the wire out of the door switch, which will prevent total water discharge
Jun 11, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire stackable will not stop filling with water or agitate.
yes unless pressure switch(water level switch)detects proper fill level wash will never start agitating some washer will not spin if switch does not detect empty tub
Jun 02, 2008 | Whirlpool LTE6234D Top Load Stacked...
My fridgidaire washer fillw with water and agitates but it will not spin or drain.
YOUR LID SWITCH IS BAD,POP THE TOP FIND THE WIRE JACK TO SWITCH CUT BOTH OUTSIDE WIRES,WIRE NUT THEM TOGETHER,MADE SURE YOU UNPLUG MACHINE FIRST,YOUR MACHINE WILL NOW WORK BUT WHEN YOU LIFT THE LID ON FILL OR SPIN IT WILL NOT TURN OFF,SO KEEP YOUR HANDS OUT OF THERE,THE LIP SWITCH CONTROLS FILL AND SPIN,THANKS-MIKE
May 29, 2008 | Frigidaire FEX831CS Top Load Stacked...
Washing Machines Logo
80 people viewed this question
Top Washing Machines Experts
