Question about Bosch 24 in. SHU53 Built-in Dishwasher
At end of cycle, lots of moisture on door/tub but dishes dry.
Is this normal?
    Sergeant:
  • 311 Answers
Is it clean water.if so that may be normal.read your opperators manual it will advise you.if its dirty water youve got a blockage
Posted on Dec 31, 2008
The dishwasher runs through it's cycle but does not clean the dishes properly and leaves a cloudy film and smears on the inside of the machine and the dishes
    Common Problem
  1. Confirm the wash water is hot
    1. Try heated wash(sani wash) if available
    2. Run hot water in sink to warm up before starting
    3. At least 120 degree Fahrenheit water temperature
  2. Open door check wash arm position start washer for a minute
    1. Confirm wash arm has rotated
    2. Check for plugged spray tips at either end of wash arm.
    3. Use small tweezers to remove
    4. Check for rack and dishes interfering with arm rotation
  3. Place cup in upper rack with opening up cycle washer.
    1. Confirm that cup quickly fills with water
    2. Not washing check water level in tub mim 1 1/2 inch
  4. Discontinue use of rinse/dry liquid additive.
    1. Confirm rinse/dry additive not leaking from dispenser into tub
    2. Washer detergent contains sparkle additive and too much sparkle/rinses/dry additive will coat dishes
    3. Try alternative wash detergent that contains minimal rinse/dry additive and use without liquid rinse/dry additive.
  5. It will take several wash cycles after the elimination of rinse/dry to purge the oily film from dishes and machine..
  6. If success "joy" is achieved with no additives then cautiously add back wash detergent with additives. Additives are important to facilitate drying and protecting the glassware china from leaching. The leaching process permanently etches the surface of glassware leaving a cloudy appearance.
Jan 03, 2016 | Dishwashers
Is this normal for Miele dishwasher? - some water left below filter and not everything dry after cycle
Plastic items do not get dry because they do not get as hot as glassware. A lot of moisture inside is do to the evaporation of water on the dishes during the dry cycle. Some water remains in the dishwasher because it is impossible to pump all of it out. There is nothing wrong with your dishwasher.
Oct 31, 2015 | Miele Dishwashers
Dishes on bottom rack are drying but dishes on top rack we have to towel dry. The service man that changed out our heating element told us to use Jet Dry which we did but same results.
Hello, well i must ask if there is water pooling on the dishes and that is not drying? If so it is actually normal for the dry cycle to get all of the water dried up on the top rack. What the heating element does is heat the air in the tub to help the water evaporate quicker. first what i would do is watch to see when the wash cycle is done open the door for a couple seconds and let all of the steam out to get rid of alot of excess moisture. When I have done this it tends to help the drying significantly. Also there should be a vent on either the front or top of the door, this is to let out the excess moisture. If it is blocked by anything or the steam is not allowed to exit it will hinder drying. And one other thing to consider is if the water coming into the dishwasher is not hooked up to a hot water line then i would strongly suggest doing so to save on drying time and energy because the dishwasher has a thermometer to tell if the water is up to temp, and if the water is cold the heating element will be used to heat the water thus using more energy and slowing wash times. Good luck I hope this helps.
Dec 15, 2010 | Dishwashers
Is there a heated dry feature on the Dacor? When I open the door at the end of the cycle there is still a lot of moisture and water droplets in the unit.
Below is a website with information about your dishwasher. It says it has a condensation dryer which means it dries the dishes using the heater coil in the bottom of the unit. This is a very slow process which continues to dry even after the unit has run all of its cycles. Usually over night they should be dry but any puddling water left on the dishes such as an over turned mug or cup will still be left on the dishes. The drying is done in this way to prevent damage to delicate glassware or melting plastic items in the unit. There is no dishwasher available that can fully dry the dishes due to the possibility of damaging your dishes.
http://www.homeeverything.com/web/sitefiles/product-9166/ED24.html
Sep 28, 2010 | Dacor ED24 Built-in Dishwasher
Dishes are not drying at the end of cycle there is no heat
if its a ss or lg its normal open the door at end of cycle
May 30, 2010 | Dishwashers
My new Kenmore Elite panel ready dishwasher leaves wet
You need only enough space so the door does not rub when opened. If the unit is too far back under the cabinet the countertop (if wood) can be damaged by the exhausting moisture. The dry feature on the newer models is just as you describe. The moisture from the hotter dishes evaporates and is condensed on the cooler walls and door of the wash tub. Dry dishes wet tub is normal.
Eric
Jan 04, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Whirlpool Dishwasher won't drain during normal cycle
As you say a clogged line or valve does not make sense.
Try running it without the heated drying and see if it empties or if the cancel button will work then.
The dishes should air dry quickly if you empty it and open the door.
It could be a defective thermostat allowing it to get too hot during the heat cycle
May 18, 2009 | Dishwashers
Whirlpool dishwasher is not fully drying dishes
Are you using jet dry or a similar drying agent? If not you should be. Also check to make sure the heater is getting hot in the dry cycle, just place your hand over the heating element to see if it's generating heat, don't touch it as it will burn you.
Feb 19, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
The dishwasher is not dring the dishes
How old is this unit? Are you removing the dishes at the end of the cycle or leaving them? Are you filling the rinse aid dispenser? The new dishwasher will not dry properly without rinse aid. Dishes have to be removed at the end of the cycle because a dishwasher is a moist environment moisture will reform on the dishes if left with door closed. A dishwasher does not have a fan to move the moist.
Jan 25, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Cycle ends and dishes are not dry
Drying dishes in a closed, hot chamber always seemed stupid to me.
We have made it a practice to open the machine, just crack at the top (our latch can be opened, door then tilted slightly, then latch closed again) to allow some of the moisture to escape.
OK, maybe your house isn't as dry as ours, but the additional humidity hasn't been a problem.
The filter serves to trap particles during the wash cycle, it shouldn't affect drying performance at all.
Your user guide will probably tell you if the filter is owner-accessible or not.
I checked but did not find a downloadable manual for your machine with a cursory look.
Aug 29, 2008 | KitchenAid 24 in. KUDI01ILBS Stainless...
Bosch 24 in. SHU53 Built-in Dishwasher Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
