Question about Irons
I want an iron that really gets hot tthe one i have you have to
The one i have you have to go over the material several times to get the wrinkles out even when using spray starch
Have you tried ironing whilst the item is damp?
I do that with 100% cotton shirts and it works much better (hottest setting). Damp down with spray or just take it off the line before fully dry.
I can't use spray starch/ironing aid as husband is allergic.
Posted on Jan 01, 2009
How can I clean the plate of my Oliso pro. It has wonder under on it
get the iron hot. Take a piece of fabric and a dryer sheet. Put the dryer sheet between two layers of fabric. Place this at the edge of your ironing board. With the iron hot, run the sole place over the "fabric/dryer sheet set" several times. This will remove wonder under and many other adhesives from your iron.
May 31, 2016 | Oliso Tg1600 1800 Watts Smart Iron Pro
Why when I iron and move the iron back and forth, the fabric will wrinkle
Check the proper temperature to iron your specific type of cloth. Different materials require different temperatures and procedures. Read up on ironing on Google. Good Luck
Sep 01, 2014 | Irons
When I iron a piece of clothing and move the iron forward then back the fabric will wrinkle.
Check the bottom rear of the iron to see if there is a spur sticking up like a scratch. If so use wet sandpaper to get rid of it.
How to empty water form iron when finished
Unless you are not going to use the iron for a long time, especially if you use distilled water to fill your steam iron, I would really not bother.
However, if you do want to empty the iron after using it, you have a couple options:
- With the iron still hot, very carefully, use the cleaning function or the 'shot' of steam until no more steam is generated above the sink preferrably.
- With the iron unplug/NO electricty: very carefully tip the water out from whe filling hole above the sink - be aware that the water will remain extremely hot for a long time so avoid splashing water on yourrsel!
Hope the information is useful.
Sep 23, 2010 | Black & Decker D2030 Iron
Will not send steam to the iron. Cleaned boiler cleaned reservoir. Help!! i love this iron.
Assuming the iron is hot???, move the variable steam control from min to max several times to clear possible blockage. Sounds like the steam valve is clogged.
Jul 04, 2010 | Rowenta DG-980 Iron
Iron only stays hot enough to iron for about 2 minutes. The red light blinks except for that time.
I suggest contacting Rowenta; if you check here at FixYa, you'll find a spectrum of problems with what should be a simple, reliable device. Several instances of the iron not turning off at all until the plug is pulled from the wall, several others that fail to turn on at all. This once was a good company and it wouldn't surprise me to find that they are now made in . . . China.
Nov 12, 2009 | Rowenta DZ1700 Iron
Iron stopped working suddenly
perhaps the thermostat is irons are cheap to replace i would try cleaning /soaking the tank to remove lime scale. or strip the iron down checking thermostat and conections.
May 01, 2009 | Tefal UltraGlide Easycord FV4256 Iron
Irons Logo
151 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
