Question about Dishwashers
MY DISHWASHER WILL NOT TURN ON- THE WATER HAS NOT FULLY DRAINED FROM THE LAST WASH-I HAVE CLEANED OUT THE FILTER AND ALL THE WIRES SEEM TO BE CONNECTED. I AM NOT SURE WHERE THE PLUNGER OR PUMP IS LOCATED AND IF IT IS A GOOD IDEA TO OPEN THEM BEFORE I CONSULT AN EXPERT.
    Sergeant:
  • 311 Answers
If theres no lites at all check power with volt meter at cord in the little box at the bottem panel.if power ther next check door switches then board.you can look at your wiring diagram for you checks.its on the bottem also
Posted on Dec 31, 2008
Washed some dirty runners & 2 small rugs on Daily Wash; came up with error code 5E cleaned debris filter any idea where water hose mesh filter is?
Usually on the back where hoses are attached to it . inside hoses are screens . turn water off ,unscrew the hose and check , then put hose back on tight .
Feb 14, 2016 | Washing Machines
At the end of a wash cycle, when the door is opened, the spray arm continues to spray some water inside. Also, this sometimes coincides with water continuously draining out of the dishwasher which I...
at the end of the rinse cycle, it is normal to have some residual water spray from the jets. it is residual water pressure. If it sprays for more than a couple of seconds then it could be and obstruction in the fill valve or high water pressure. required pressure is 30 psi. Any water above the stand pipe will be drained out.
One last recommendation, this type of dishwasher needs to be fully drained (stand pipe removed) at least once a day.
good luck
Aug 26, 2017 | JetTech Jet Tech F-14 - Counter-Top -...
My dishwasher doesn't seem to be washing the
Hello
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Upper or Lower Spray Arm
Your dishwasher has a lower spray arm. It may also have an upper spray arm at the top of the dishwasher. These spray arms are designed to shoot high pressure, high temperature water at your dishes. It is possible that the holes of the spray arms, where the water comes out, are blocked with debris, affecting wash quality. You should inspect your dishwasher's spray arms regularly. Clean out the spray arms as need be.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
Detergent or Detergent Cup
It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, please see our section My dishwasher detergent cup won't open.
Aug 09, 2011 | Viking 24 in. Professional Series VUD040...
My dishwasher spray arms were clogged with calcium buildup so I cleaned one and replaced the other. I also removed the fixed disc-shaped device underneath the lower spray arm and found the particle filter...
you may want to check your hot water tank. It may need drained and cleaned, Or you may have the rod in the tank disintegrating. Also check you water faucet areators to see if they have calcium pieces too.
Feb 10, 2011 | Maytag Dishwashers
Firgidaire dishwasher MODEL FDB641RJSB leaves cloudy residue on dishes. Top spin arm does not seem to be rotating,
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes
Feb 01, 2011 | Frigidaire FDB125RH Dishwasher
Miele Dishwasher G841 - Water not draining after wash cycle
If you suspect the dish washer, try discharging the drain in a bucket. After the drain cycle check the wash tub. If water is still left, you have to clean the drain filter attached to the bottom. Refer user guide.
The final drain end of the dish washer where you discharge, the fixing junction has to be cleaned, incase it is clogged.
Jun 01, 2010 | Miele 24 in. Touchtronic Platinum Built-in...
Water not draining from GE Monogram
hi, check your waste pipe is clear, check that the filters in the bottom of the machine are clear, try it again on rinse cycle, if it does not empty select rinse again and gently turn selector click by click ,see if empties now? if it does it may be your progamme timer fault if not it may be your pump
Feb 05, 2009 | GE 24 in. ZBD0710KSS Stainless Steel...
Not spining and water not draining off
check filter and check for foreign object stuck in pump impellor
Sep 25, 2008 | GE WSXH208A Front Load Washer
Problem with conia cdw1211 dishwasher
Had same problem - was advised by service centre to remove secondary filter (round mesh cylinder in main filter on floor of machine) & discard it as it became coated with oil & caused the sensors to malfunction. Fixed the problem immediately.
Apr 12, 2008 | Dishwashers
Dishwashers Logo
87 people viewed this question
Top Dishwashers Experts
