Question about Haier DVD100 DVD Player
DVD problem I followed the instructions for conecting the DVD to a TV but nothing appears on the tv screen even though the DVD is working correctly.
0 characters
1 Points
Blu ray shows the "Blu ray Disc" Logo on TV screen and then just show a black creen
Hi! and welcome to Fixya!
It looks like your tv is unable to handle the output video resolution from your bluray. The reason why you do not have picture on the tv screen after the bluray disc logo appears.
You can follow the instruction below to set the video resolution on your player to its lowest resolution:
1. Using your bluray remote control, press the following buttons in order... STOP button (press and release) ....HOME button (press and release)....POP UP/MENU button ( press and release )
Note: press the buttons in order with 1 second interval. Make sure tv and bluray are ON when you try this. If first attempt nothing happens, try this again.
2. When the home menu screen appears after doing the above instruction, you can set the video resolution again manually. Follow the instruction:
Using the BD remote control press HOME button > then go to SETUP > select screen settings > then change OUTPUT VIDEO RESOLUTION to Auto > change also 24P OUT to 1080P // set the BD-ROM 24P OUTPUT to Auto
The next time you turn on the bluray player you will have picture again.
Let me know if this works!
Oct 24, 2015 | Sony DVD & Blu-Ray Players
How do i fix my toshiba dvd player?
Select correct input in your tv. Look for cable conections and the correct input in your tv.
Aug 03, 2014 | Toshiba DVD & Blu-Ray Players
Dvd will not play on tv
If the cables have been installed correctly with matching color codes and your TV has been set for DVD player input, you should see something. Try swapping players to find out whether the old one works. If so, there may be something wrong with your new player.
Dec 15, 2013 | Craig DVD & Blu-Ray Players
We have a philiips dvd recorder, but unable to
switch tv to the input mode you have conected dvd to e.g ( AV or EXT ) if dvd is a recorder one have you put areal in back and tuned in dvd recorder
Nov 28, 2009 | Philips DVD & Blu-Ray Players
DVD Player won't show recordings on my TV screen
put the dvd player on the same channel as you set your Tv when wathing direct tv. and try recording
if you are using rca push on cable yellow,red ,white set to your A,V audio,video channel
when recordining you will be changing channels on the direct tv box
do you have a manual for dvd player read that really good that might help.
Sep 28, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
On my new magnavox zv450mw8a i cannot get the vcr to come through the tv. i have followed the instructions on page 20 in the owners manual.what am i doing wrong?
I had the same problem with the dvd/vcr and my tv not communicating with each other even though they were plugged up correctly. I called the manufacturer phone # on the instruction manual. What they told me to do is strange, but it worked. They said to switch the bottom "in" yellow connector to the bottom "out".....and plug the bottom "out" yellow connector into the bottom "in". It worked on mine. Hope this helps.
Sep 22, 2008 | DVD & Blu-Ray Players
Setting up a new Philips DVD Recorder
You can download Philips manuals from
although the problem seems to be that you need to select the correct AV channel on your TV. The connection on the TV that you have used will be labelled.
Jun 07, 2008 | DVD & Blu-Ray Players
Subtitles on Sanyo DVD Player Model DMW-380
For the DVM-390 model, the above problem can be due to the TV Guardian (TVG) mode. I would go to the intial setting options and under Language turn the TVG mode to "Off" and see if that allows the subtitle languages to appear on screen.
May 23, 2008 | Sanyo DWM-390 DVD Player
It does not display or play
You have to run a search of available channels on the DVD recorder through the setup menu. After the recorder has located all available channels, make sure the TV is on the correct input. (Video 1, Video 2 or whatever)
If all else fails, then read the manual. HaHa
Dec 29, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Haier DVD100 DVD Player Logo
14 people viewed this question
Top Haier DVD & Blu-Ray Players Experts
Martin Murray
Custom Exchange
Custom Exchange
Paul Bade
Are you a Haier DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
