Question about Tappan TGF657 Gas Kitchen Range
CONTROL PANEL ABOVE OVEN VENT DISCOLORED, LOOKS BURNT
COULD THE VENT BE PARTIALLY BLOCKED, THE MORE I USE THE OVEN, THE MORE SCORTCHED THE PANEL LOOKS. A NEW CONTROL PANEL IS ONLY $40, BUT I AM AFRAID THE SAME THING WILL HAPPEN. POOR DESIGN OR REPAIRABLE PROBLEM?
    Sergeant:
  • 311 Answers
Poor design.im a repairman 17 years sean it many times on all sorts of brands,but 40$ isnt bad
Posted on Dec 31, 2008
How do I remove the control panel
Main door lifts off. Look for screw under vent panel at top. Remove vent panel to find screw (s) holding control panel.
Oct 03, 2015 | Microwave Ovens
F10 code on a Kenmore self-clean range model #970-6061
Your Kenmore oven has a built-in fault detector. When the oven detects an issue, the display screen on the control panel will flash a fault code. The F10 fault code on your Kenmore oven indicates that the thermal protector on your oven's control unit, or microcontroller (MCU), has overheated. If the MCU overheats, the computer stops all motor functions. Several items on your oven could cause the thermal protector to overheat. Therefore, you must troubleshoot the F10 code to determine why it appeared on your display panel. Instructions 1 Inspect the area around and behind the oven to ensure you did not place the oven next to a source of heat, such as a register vent or other appliance that becomes very hot. If this is the case, you must remove the oven from the heat source to prevent the issue from occurring again. 2 Inspect the oven to ensure all vents on the oven are open and unblocked. This includes heat vents that vent to the outside of the home. Remove any clogs from the oven's venting and check to see if the code reappears. 3 Inspect all of the wiring harnesses that connect to the MCU. Remove the back cover from the control panel with a screwdriver. Look for disconnected harnesses or any harnesses with black residue on them. This indicates an issue with the MCU. Remove the bolts that secure the MCU to the control panel housing and then replace the MCU with a new one. Reconnect all of the harnesses and retest.
Aug 05, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
How to shut off F10 alarm on Frigidaire Gallery oven?
follow the next steps and proceed with commong sense: God bless you
  • 2 Inspect the oven to ensure all vents on the oven are open and unblocked. This includes heat vents that vent to the outside of the home. Remove any clogs from the oven's venting and check to see if the code reappears.
  • 3 Inspect all of the wiring harnesses that connect to the MCU. Remove the back cover from the control panel with a screwdriver. Look for disconnected harnesses or any harnesses with black residue on them. This indicates an issue with the MCU. Remove the bolts that secure the MCU to the control panel housing and then replace the MCU with a new one. Reconnect all of the harnesses and retest.
  • Jul 27, 2012 | Frigidaire FGGS3045KF Stainless Steel Gas...
    Control panel on GE Profile Spacemaker microwave not working
    You are right the control panel is very expensive, you can try the filter to see if you can get it working, but I must admit a new microwave oven sounds appealing.
    Jun 25, 2012 | GE SpaceMaker Microwave Ovens
    The control panel lights do not work nor does the oven. all the burners work fine this is a convection oven with a smooth top Gallery series
    Check your main breaker in the fuse panel, it may be partially tripped. Turn the 40 amp breaker off and back on. if the display does not return to the stove, the I would suggest you contact a local servicer.
    Aug 29, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    My GE double oven JKP26GP broiler burned out (burned a hole right thru). The keypad immediately went blank and the keypad controlled top unit isn't working now (top unit only - bottom is fine). Will...
    I'm afraid I don't know how to help you get a new control panel (part #WB36K5065 is no longer available). But we have the same oven and a similar problem. Our control panel works just fine, but the face is melted from a recent mishap (small fire in the upper oven while broiling), so the plastic face of the control panel looks awful and needs replacing. If you decide to replace your oven and would like to sell the front face to your control panel we'd love to purchase from you.
    Nov 21, 2009 | GE Ovens
    Jenn-Air range SVE47600W control panel is partially non-functional. Bake temperature control, off, oven light work. Clock does not display, oven clean and broil do not function. It may need a new panel...
    We have this part in stock and can send it out to you first thing Monday morning, if you like. We will include installation instructions for you. You can call us from 7AM until 9PM CST Monday through Saturday. We look forward to working with you!!
    Oct 15, 2009 | Ovens
    MH1150XMT-0 (whirlpool) partially dead control panel
    In order, I would suspect:
    - it needs a reset
    - door switch or door switch mount trouble
    - your keypad is failing
    The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
    If that doesn't work, leave it unplugged for maybe an hour.
    Then let us know if the hard reset does not fix it so I can give you some advice on the other two probable causes.
    Aug 23, 2008 | Whirlpool MH1150XM Convection/Microwave...
    We just purchased the KGRS807SSS gas kitchen range
    This is normal. Typically the vent from the oven will come up between the cooktop and the control panel.
    Sep 28, 2007 | KitchenAid KGRS807SSS Gas Kitchen Range
    Oven heating problems
    I'm afraid you might need a new thermostat. The only other thing you might check is to make sure that your 'vent' is not blocked with a pan or tea kettle etc., but I'm pretty sure it is a thermostat.
    Jun 09, 2007 | Maytag CWG3100A Gas Single Oven
    Tappan TGF657 Gas Kitchen Range Logo
    118 people viewed this question
    Top Tappan Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Sal De
    Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
