Question about SanDisk Sansa Fuze MP3 Player
Will not turn on
I was on my fuze and then the screen went white and i turned it off and now it will not turn on even when it is connected to my pc with the data cable
Please help !! :)
  • 2 more comments
  • JDCM72 Jan 17, 2009
    my Sansa Fuse went white last time I turned it on and now it wont even work!!! GRR!!!
  • jazjasm Feb 13, 2009
    went to got listen to it and it wouldnt turn on finally aftera few tries it
    turned on but came on white and wouldnt play musi :(
  • Anonymous Feb 17, 2009
    When I turned it on its screen was white. But it can still play music its just that i cant see what Im doing. Someone help.
  • Anonymous Feb 19, 2009
    wheni turned it on i can still hear music but cant see what is happening
Found this on another forum, turn the sansa to the off position and hold it there for ten seconds. It should re-set. I was amazed at how well this worked, because I thought I was scr*****d.
Posted on Feb 15, 2009
My wife plugged her sansa fuze into her car radio usb port thinking she could play her music on the radio thru the aux. input. the sansa screen went white and is frozen. can't even turn it off. Did she...
Did you try to reset the player? You do this by sliding and holding the power button on the side for about 15-20 seconds. I have a Sansa Clip which resets in the same way. Best of luck!
Oct 05, 2010 | SanDisk Sansa Fuze MP3 Player
Its froze on a screen iv never seen...
it means the software has corrupted ....go to www.htc.com and select the fuze and the rom should be there dowload it to your pc ..remove your sim card and memory card ...connect to active sync and run the .ruu file(the file you downloaded from HTC ) the onscreen instructions are easy to follow ......make sure phone is atleast 50 % charged
May 24, 2010 | HTC FUZE Smartphone
My Sansa fuze mp3 player has become unresponsive and the screen has gone white (blank)... It does not respond even if I connect it to the computer. It does not turn off...What's wrong and how can it be...
it should turn off if you hold the reset (on) switch in the on position for ten to fifteen seconds. if that doesn't work, try downloading the firmware update. but be careful, i had the same problems, and when i downloaded the update...it ruined the mp3 player, and sansa would not help
Jan 11, 2010 | SanDisk Sansa Fuze MP3 Player
Sansa fuze 4g isn't recognized by computer...won't charge, screen only shows "writing" screen when body of mp3 player is pressed together...any ideas?
When i plug my Fuze in the pc, it turns on, but doesnt charge, and isnt even recongnized by my pc. So i cant put anything on it and it doesnt even show up in device manager.
Dec 26, 2009 | SanDisk Sansa Fuze MP3 Player
Sansa fuze 2gb wont turn on or charge
Mine did the exact same thing, (Even the going to bed thing) I'm glad you posted your question. Incidentally enough after trying to turn-off and on for ten minutes, I pressed all the buttons a whole bunch to show it my frustration.....then it worked. (?) I don't know why, but I think that the computer going into hibernation or shutting off affected it.
Jun 23, 2009 | SanDisk Sansa Fuze MP3 Player
My sansa screen went white
Try resetting the device by holding teh power switch in the ON position for about 15 seconds, then while it's OFF, slide the power switch DOWN to the HOLD position. Now for the tricky part, let's force a manual MSC connection. Press and hold the center button while plugging in to the USB port. Let us know if the screen lights, and the battery begins charging in this mode. If it's charging, let her charge for a while to give the battery a chance. Then, open a Windows Explorer window. I like to use [Windows key] + E, or go to My Computer. See if the Fuze appears under "devices with removable storage". If it's communicating, you have the options of formatting the device and reloading the firmware.
Jun 06, 2009 | SanDisk Sansa Fuze MP3 Player
White screen
try charging it fully then turn it on and off again
Feb 22, 2009 | SanDisk Sansa Fuze MP3 Player
My sansa fuze is not working
Hi and welcome to FixYa,
Appreciate the direct "Ask Me;.
Offhand, the message indicates that the Sansa is requesting that the internal storage be reformatted using the PC. This would require that the Fuze be connected to the PC through USB. Thereafter, the computer would recognize it as an external storage device. Steps required to format:
  • connect Sansa Fuse to USB of PC;
  • double click on "My Computer";
  • it would show probable as an "E";
  • right click on the "E" and click on "Format...";
  • a new window will pop up;
  • under the "File system" pls select FAT or FAT 32;
  • verify that "Quick Format" is un-checked;
  • click on Start button.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 21, 2008 | SanDisk Sansa Fuze MP3 Player
SanDisk Sansa Fuze MP3 Player Logo
61 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
