Question about Panasonic Microwave Ovens
I have an Panasonic Multi-Matic Microwave Oven won't start
It is built into above my kitchen cupboard. It was intermittent a while ago. Then it worked fine for a while. Now it clicks when I press the button and doesn't start. Any Ideas?
Thanks,
Brian
E-mail: brian_tab@yahoo.com
  • Brian Menzie Jan 04, 2009
    On the back of the my (Pansonic Multi-Matic II) unit the Model # is:
    Model #: NE-7810
    The symptoms?
    Now it does not work at all.
    It Clicks when I press Switch, then it
    Sounds like it is about to work, but doesn't.
  • William Miller
    William Miller May 11, 2010
    What is the model number?
    When you say it was intermittent, exactly what was the symptom?
  • Panasonic Master
  • 9,098 Answers
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
If you only need a switch, you can order a universal type here for $5 postpaid.
Otherwise, the best place to order parts for this brand is Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Posted on Jan 04, 2009
Can panasonic microwave oven nn-cf771s be built in to kitchen unit?
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Aug 05, 2016 | Panasonic NN-CF771SBPQ
Am looking for a operation manual, where can access/
[PDF]Operating Instructions - Panasonic
service.us.panasonic.com/OPERMANPDF/NNSN797.PDF
Panasonicreduce the chance of injury, and tell you what can happen if the instructions ... Thank you for purchasing a Panasonic Microwave Oven. ..... m Warning Label ...
Free Microwave Oven User Manuals ' ManualsOnline.com
kitchen.manualsonline.com > Kitchen Appliance
Free kitchen appliance user manuals, instructions, and product support information. Find owners guides and ... Agilent Technologies Microwave Oven Manuals.
[PDF]Owner's Manual - GE Appliances
products.geappliances.com/MarketingObjectRetrieval/Dispatcher?...
oven surface when the microwave oven is in operation. ? Do not ... cooking time. ? See door surface cleaning instructions in the Care and ..... Foods calling for a dry lookor crisp surface after ... changed. Press and hold the AM/PM pad.
[PDF]MICROWAVE OVEN - Whirlpool
www.whirlpool.com/.../Use%20and%20Car...
Whirlpool Home AppliancesRead all instructions before using the microwave oven. ... If there is any damage, do not operate the microwave oven ..... Microwave oven door looks wavy. ?.
Jan 04, 2016 | Microwave Ovens
The flex on my built in microwave is too short to reach the spur on the wall. We have it plugged into a one plug extention lead. Is this safe?
This is not recommended, microwave oven's draw a lot of current when they are running, any extention cord joins will get hot causing a potential danger for fire.
Jun 30, 2012 | Panasonic Microwave Ovens
Panasonic Counter top Microwave model # NNT695SF Often when I push the start button, the microwave will go for a few seconds and then cut out. I then open the door and then shut the door and push the...
Issue with your Main Panel Power Fail to innitiate ..Du to Component mal-functioning inside the unit ...Possibility Magnetron defect, Or main Transformer Over heat, Also check for safety swich on the door for bad connection...
Sep 30, 2010 | Panasonic NN-T695SF Microwave Oven
I have a built in Whirlpool Micro Wave oven that quit
if you open the cupboard door above the microwave you should see two or four screws/bolts holding the microwave up there. there should also be an electrical outlet up there where the microwave is plugged in. have at least two strong people. put some blankets on your stove top to protect it. unplug and remove the screws. it should be connected in back by a metal plate also. when the microwave is tilted down at a fourty five degree angle, you can give a little lift and it should pop off the plate in back. it is heavy. get a new one at sears or other appliance retail outlets. i dont recommend best buy. they really screwed me over so i dont send business their way.
Oct 20, 2009 | Microwave Ovens
Panasonic microwave oven NN-S235WF modle
just replace micorwave power out let.
Dec 30, 2008 | Microwave Ovens
Microwave oven
no sir we cant, if that's the requirements for the microwave to run with out trouble, then that's what you have to follow. if you dont, it might overheat because of poor ventilation.
Feb 20, 2008 | Microwave Ovens
Insructions
Looking at mine, it fits in pretty snug. Not much space needed on the sides and the top is bolted into the cupboard. This may help a bit but you may want to look at the install instructions for your specific model:
http://www.onwisconsin.com/homes/remodel/oct04/270397.asp
Feb 17, 2008 | Microwave Ovens
Microwave Ovens Logo
73 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
