Question about Sharp AR-BC260 Color Copier
Error code F2-42
Color copies have lines on them the copier makes a clunking sound (like plastic clicking) and I get an error code F2-42. Anybody got any ideas.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
Are the lines horizontal or vertical? DO you get lines on B/W copies (black and white) also? If you try to copy a blank white page do you get the lines? Does the toner / lines wipe off after the copy comes out? If the toner wipes off after the copy comes out you have a problem in the fusing unit ( the hot area that fixes the image onto the page). If the lines are vertical then you have something inside the device that is dragging across the page as it goes through the device. If the lines are horizontal then you it could be the drum cleaning blade, the transport blade, or charge roller. The noise could be that one of the blades are bouncing. It could be that a gear is worn. Please give more info on the problem to better help.
Posted on Jan 04, 2009
Printer making loud clicking/clunking sounds
Sounds like the problem I had where the plastic gears that drive the roller on one of the the toner cartidges are broken.
Your gunna have to take it to a repair shop or send it back where ever you got it. If they won't take it might still be under Samsung's warranty.
Feb 02, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Cannon pixma ip 4600 error code 5700 - paper jam
The error code 5700 is the sensor error.Replace the sheet
feed unit and then adjust the timing of the paper feed gears.
Sep 02, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Solution for "code 373 ricoh aficio color 6513"
Hello sir; the error code you display is toner senser problem, now the first thing you have to do is make a full color copy find out which color missing then pull out developer unit from missing color the senser right underneath, replace it.
May 23, 2009 | Ricoh 6513 Copier
Doc 12 error code 9-343
i had similar problem a week ago running black only job on extra heavy card stock.
there is black toner built up. when you run black only copy with little toner use, it builds up toner in black developer and motor could not run.
always mix black and color jobs and run alternate, so there is no excesses in any color. or cheaper way how i did without paying color clicks.
i got rid of excess black in following manner.
took 11x17 white sheet, copied as negative (solid black) and ran 30-50 black copies, which drained all excess black and then continued with job.
hope it works for you or get professional help or you will lose motherboard and motor if you just follow instruction as it tells you on error screen... switch off and switch on. do not keep on repeating.
Oct 23, 2008 | Xerox DocuColor 12 Printer
Error Code 9-357
Don't have the codes for that one BUT 09 --- codes always refer to drum/toner problems. Make sure the drum unit is plugged in properly, and cables/plugs etc secure
Jul 19, 2008 | Xerox DocuColor 12 Color Copier
Error Code E000020-0225
Wedm/Craig. I will glady help you, and I am extremely confident that I am correct. More importantly I wish to to help you avoid The "COPIER DUDE COMPANY" taking a large chunk of your cash. I work for a "COPIER DUDE COMPANY" and we charge $200 just to say "yep, you have a problem". So lets start from square one and please forgive me if I get long winded and redundant. You tagged onto a request for help initiated by a customer called Brassmonkey who had a code of E000020-0181.This code means that when the copier attempted to calibrate each color (cyan,magenta,yellow and black) as it does from time to time to maintain optimum copy quality, the target values for yellow could not be achieved. Not even close. Yellow is the first color the copier checks and is used as a reference for the rest of the color calibration.Therefore it tends to be the primary error code in the event of a problem. Now here is where it gets hairy. Hang with me here. A patch of color is placed on what is called a transfer belt. This belt is where the image/copy is created prior to it being transferred to the paper. In fact, there is a point in time where the color copy you requested exists on this plastic belt, held by a staic charge, and is waiting to be pushed onto the paper as it goes through the machine. So when the copier goes thru periodic calibrations, again it makes a yellow "patch"....looks at it....... reajusts....looks at it... until it hits the optimum target of quality. And it does this for every color. So, now to the NUTS of it all. You have a drum&developer "unit" for each color.One dual unit for each. They are fed toner as they need it. Any one unit can fail due to shear normal use,and this is not a function of toner.{I have seen weird shit that defies logic before but toner is on the wierd shit list} Now, at some point the "plastic transfer belt " fails. So no matter how new the drum/developer units are, the "medium" from which the colors are being judged by cannot provide a valid measurement. Its like an old guy like me trying to read small print with scratched glasses. New text does not mean I can read it better. So now you have an 000020-0225 code. This means that the magenta color calibration failed.This tends to lean toward the transfer belt(scratched glasses) being worn. Two color calobration failures make ya wonder. Canon says that under the best of conditions the tranfer belt is good for 300K. These are all remote troubleshooting suggestions but at least you will have the benefit of these details. And the transfer belt is A: not real expensive and B: not labor intensive. I hope this helps. Good luck and take care. ............SPINAL........
Feb 25, 2008 | Canon imageRUNNER C3200 Copier
Canon IR 3100 error code (E000020-0081)
error code E00020-0081 my canon printer IRC3170i.what is the problem?Anybody can help?
Feb 19, 2008 | Office Equipment & Supplies
Color background, and then C255X error code (x depends of the color imaging unit)
Those codes are related to an abnormal toner to carrier ratio. If you are getting multiple errors that could be a control board failure. I will consult Konica Minolta Solutions and post futher as the information becomes available.
Jan 03, 2008 | Konica Minolta bizhub C250 All-In-One...
Sharp AR-BC260 Color Copier Logo
878 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
