Question about Toshiba 65H82 65" Rear Projection Television
Toshiba 57H82 Convergence issue
Hi, Acquired a 57h82, that has a convergence issue. The picture is ghosted in red and the red convergence cannot be adjusted left to right. Up and down is ok. I replaced both of the convergence chips, but it made no difference. I assume as I did the chip replacement, and the issue is still exactly the same I did it ok. Does anyone have any other ideas... I have heard that some resistors on the board can be a problem, and should be replaced, but which ones and how do I check them? Thanks
    President:
  • 4,402 Answers
More info here:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 05, 2007
Toshiba 57H82 - 57" Lower left of picture screen
If the TV looks zig zag or scrambled and its moving aroudn the screen the hypermodule has failed.
If however it looks 3D or warped and is not moving around the convergence is the issue. You can get DIY repair kits including all parts, instructions, and support from sites such as www.TvRepairKits.com
Feb 22, 2011 | Toshiba 57H82 57" Rear Projection...
I HAVE A TOSHIBA 57H82 . AND THE PICTURE JUMPS A ROUND. LIKE I SEE TWO PICTURE .
I think you need the convergence I.C.s there are 2 of them, (STK392-110 I think), you will need to be able to solder.
Mar 16, 2010 | Toshiba 57H82 57" Rear Projection...
The picture has ghost images, not lining up
This sounds like a convergence problem. Use the menu functions to reset your set's convergence. If this is not enough, you may need to replace the convergence board.
Feb 17, 2010 | Toshiba 57H82 57" Rear Projection...
Color convergence messed up
you can get the convergence repair kit for your model that has both convergence IC and the six feed resistors at this link, The repair kit also has step by step instructions with pictures so you can do the repair your self. Heres the link.The 50H82 kit is the same for the 57H82, http://servicemanuals.vstore.ca/product_info.php/pName/toshiba-50h71--50h81-convergence-repair-kit/cName/convergence-repair-kits
Feb 01, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba 57H82 entire screen flickers. Not clear. mult images
Sounds like the Hyper board is needing replacement very common problem for toshibas.
Dec 27, 2008 | Toshiba 57H82 57" Rear Projection...
Service Manual for Toshiba 57H82
By the red being "off" I suspect you have a convergence problem and adjusting will bnot likely fix the problem. The convergence amps need to be replaced but if you email me I can send you the servoce manual... Just provide me with enough info in your mail, model number, because I get nearly 3000 emails a day and I won't likely remember what manual you're looking for...
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
Dec 18, 2008 | Toshiba 57H82 57" Rear Projection...
Service manual for Toshiba 57H82
I found an owners manual and other info on your TV but not a maintenance/service manual. I would suggest contacting Customer support, See below:
Customer_Support@tacp.com
http://www.tacp.toshiba.com/customersupport/
Dec 17, 2008 | Toshiba 57H82 57" Rear Projection...
Red Ghost
This may be a convergence issue but it is difficult to determine with that description. Watch this video and see if it will help you determine if you have a convergence problem or possible something else.
Aug 10, 2008 | Toshiba 57H82 57" Rear Projection...
Toshiba 57h82
your convergence amp ic's./if you want to cheat/align the other two colors and manualy move the green yoke rings on the green picture tube neck so the green cross aligns with the red and blue.,they shuold form white when all three are aligned,on top of each other.
Sep 13, 2007 | Toshiba 57H82 57" Rear Projection...
57H82 convergence issue, but not STK IC
There are probably eight to ten resistors sitting behind the heat sincs the Chips mount on. You will need an Ohm Meter the easiest way to check them is just compare them with one another, you will see a pattern then you will see one that is really high or open (infinity) that is the one to change check the coor code on it to be sure you replace it with the right size
May 05, 2007 | Toshiba 57H82 57" Rear Projection...
Toshiba 65H82 65" Rear Projection Television Logo
502 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
