Question about Nintendo Wii Console
Wii sensor not detecting remotes
Wii has been working fine for 2 years. Took the wii on a trip, upon return set it back up and with the wii fit board. Now the sensor only reads the remote when I point it to the right, where I have a mirror.
  • souixan May 11, 2010
    When you point the Wii remote at the screen in the main menu do you get the pointer icon?
    Problem Solver:
  • 25 Answers
There might be so many reasons, You may visit Wii Fix Guide to know exactly the reason for this problem also this DIY guide will help you fixing the problem without any technical knowldege. It also gives information on fixing many Wii Related Problems, so its. a kind of Wii Problems Reference Fix Guide.
Posted on Feb 20, 2009
How to connect wii fit board to the wii
Important Note!
Do Not use "One-Time Mode" sync.
Syncing can be completed only if a compatible game disc is running in the console.The Wii Balance Board may need to be synced to each compatible game individually.Some games may require you to go into a specific screen to sync the Wii Balance Board.These sync settings will be saved even after the console is turned off.
1. Insert a Wii Balance Board compatible game disc in the Wii console.
2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game.3. Open the SD Card slot cover on the front of the Wii console.4. Remove the Battery Cover on the bottom of the Wii Balance Board.
5. Press and release the SYNC button on the Wii Balance Board. The Power LED on the board will start blinking.
6. Press and release the SYNC button on the console while the Power LED on the board is still blinking.
7. The Power LED will stop blinking and light steadily once the synchronization is complete.8. Replace the battery cover and return the board to the normal operating position.
Nov 16, 2011 | Nintendo Wii Fit for Wii
We have done the checking of the wii fit board and it recegonizes it but then when trying to do a game any fit game it says step off and press A and we do and then it just keeps saying that over and over...
You could try these:
  • Turn it off and then try again without stepping on it before it asks you to.
  • Try reconnecting all the remotes.
  • If you have the board sitting on a thick carpet or something it might cause problems. Try using a hard surface.
  • Try getting the batteries out and then put them back in.
  • Try using another game for the Wii board. If it works it's not a hardware problem and you need to get another Wii fit disc.
  • There also seems to be an issue with rechargeable batteries (the constant charge may be damaging the unit). What you have to do is get a new board from the store you bought it and use AA cells, otherwise the new one might stop working also.
If none of these work your wii board might be faulty (damaged pressure sensors) and you would have to return it and get another one or a refund on your money.
Hope this helps!
May 13, 2011 | Nintendo Wii Fit for Wii
I can't sync my board to my remote
You have to insert a wii fit game and bypass all the stuff until the game is ready to play.Open the battery compartment on the Wii board and open the large door on the front of the Wii console.Press the sync button on the board,then press the sync button at the top of the console compartment.The fit board light should stay steady blue.If it doesn't,try it again.When the fit board stays steady blue,it is synched.
Jul 13, 2010 | Nintendo Wii Fit for Wii
The running games on my wii fit and wii fit plus don't work. I follow the instructions (off the balance board, remote in pocket or in hand), but can't get my mii to move in the game. Can you help?
This has to be your bluetooth movent sensor bar which presumably you have on the top of your TV set. This bluetooth connection will not work when more than 2.5m away from the sensor. If moving closer to the sensor doesn't work, Try borrowing another sensor bar. Make sure the switch on the balance board faces away form your TV set and the batteries are new or fully charged.
Mar 18, 2010 | Nintendo Wii Console
Problem getting wii GUITAR working with RockBand 2 after a resync
first of all you should make sure you have fresh batteries and then try the special resynch via the red dot like button on the inside of the controller (press it at the same time as the one in sd card slot) if that doesnt work try just moving closer to the wii at far distance the controller signal gets weak. if its not that then its a hardware issue
Jan 07, 2010 | Nintendo Wii Rock Band Guitar for Wii
Wii remote not sensing motion
The senser might not be working this happened to me and we googled and we just ended up buying new remotes or the batterys. the light will be on if they are dead. well ours did.
Jul 21, 2009 | Nintendo Wii Console
I got a brand new wii fit balance board and i syncd it, put in the batteries that came with it, (new batteries) put on a cover, and its working fine. about 2 weeks later it was bought, I was playing a game...
According to the Nintendo support site, here's what to do.
Your movements are not being correctly detected
  1. Make sure that the Wii Balance Board is placed properly in front of the TV: The blue power light should be facing away from the TV. If the Wii Balance Board is facing the wrong way, your movements will be reversed.
  2. Check the battery life of the batteries in the Wii Balance Board. If the battery level is low, try a fresh set of batteries.
  3. Check to make sure nothing is pressing against the bottom of the Wii Balance Board. If you do find anything pressing against the bottom (such as carpet), try using the foot extensions.
If the Wii Balance Board is still not correctly detecting your movement, please call 1-800-255-3700 for assistance.
Here's the link if you want to see for yourself
http://www.nintendo.com/consumer/systems/wii/en_na/ts/balanceBoard.jsp#movement
Jun 08, 2009 | Video Game Consoles & Games
I have the rechargeable battery pack on in my wii fit balance board. I the power keeps cutting out and it is saying communication is lost on the balance board, and to push the power button again. This...
If you remove the rechargable battery pack and put regular batteries back in, are you still having the same problem? If so, I would recommend returning the rechargable unit and replacing it.
For what it is worth, I've been using my Wii Fit board for nearly a month on 4 alkaline batteries and have not had any problems.
I recommend rechargeable NiMH batteries with a 15-minute quick charger. Always have four more batteries than you need in your machine, ie: if you have a Wii Fit, a Nyko Wireless Sensor Bar, and two Wiimotes, then you should have 16 batteries total (4 + 4 + 2 + 2 + 4 spare).
Jan 27, 2009 | Nintendo Wii Fit for Wii
WII FIT Board only recognizes movement on one side
Try doing the balance board test to make sure all the sensors are working probably. Click on "User Settings" (the wrench) on the wii fit plaza page. From there your should click on the "wii balance board check." It will walk you through the process and check your sensors to make sure they are working.
Dec 25, 2008 | Nintendo Wii Fit for Wii
Wii
check wii console is connected then insert wii fit cd and see what happens put new batterys in remotes and make sure wii works before installing wii fit
May 26, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
