Question about Biostar MCP6P-M2 Motherboard - v6.0, NVIDIA GeForce 6150, Socket AM2, MicroATX, Audio, Video, 10/100
No sound on MOBO
I installed a new MCP6P-M2 Board. I cannot get sound. I was of the understanding that the sound was on board. Is this correct or do I have to install a sound card and if so can it be installed in the PCI Express slot as that's the only one left. I have my Netgear Card and a USB card in the other two PCI slots.
  • 1 more comment
  • Bum Dec 31, 2008
    Thanks, appreciate your help. I'll try that....................Bum
  • Bum Dec 31, 2008
    I downloaded the audio driver for that board and run the file, where it went I haven't the slightest idea but awhile later I noticed I had sound. I wish i knew where the driver was though. Anyhow, I'm smiling!........Bum
  • breakfastinb Jan 14, 2009
    I installed the driver after installing DirectX 9... still no sound!
    What to do?
  • 4 Answers
NO SOUND -a common problem with windows xp sp3 due to that microsoft removed support for high definition audio. You must download kb835221.exe to enable the hd audio support. Or you can remove and replace the windows xp sp3 with lower version sp2 or sp1.
Posted on Mar 17, 2009
You didnt say what operating system you are using. If you are using XP you may need to update xp then reinstall. DirectX 9 has to be installed before most of the newer sound drivers will even try to install. If your copy is XP or XP sp1 you probably just need to udate dx9
Posted on Jan 01, 2009
    Novelist:
  • 101 Answers
This board uses high definition audio amongst its special features.
After installing Windows you must run ALL of the driver install disk to activate the special features of the motherboard. The chipset driver should always be first as this allows other drivers access to all portions of the motherboard.
Check the Device Manager in the control panel to be sure you have no driver conflicts or issues.
If youi do not have the drivers disk, the best place to download replacements is the manufacturer's website. the drivers for this board are found here:)
http://www.biostar.com.tw/app/en-us/mb/driver.php?S_ID=315
Posted on Dec 31, 2008
  • Eric Ramirez
    Eric Ramirez Dec 31, 2008
    If you downloaded but selected the Run option, the download would go into the temporary files while installing and then be deleted. You can keep a copy by downloading the file again but select the Save option. I like to keep all of the drivers for a system in a folder called c:\drivers just in case I have to reinstall the operating system later.
Help
try new heatsink on cpu
May 04, 2013 | Biostar MCP6P-M2 Motherboard - v6.0,...
Please do help me withmy Biostar MCP6P-M2+ motherboard, my problem is. the board has a power coz his indicator are on. but. when i turned On the Board. the the processor fan do running but in just a...
It is either a faulty board or your CPU is not connected properly. Check the CPU is "flat" in the socket and no pins are bent. also, ensure the thermal paste is evenly spread and fan plate flush against CPU. Failing that, ensure all your earthing screws are installed and your display is working correctly.
Oct 12, 2017 | Biostar MCP6P-M2 Motherboard - v6.0,...
I have a new MCP6P-M2 mother board. I have tried to install the lan drivers manually because there is no such option on the autorun disk. i still get the following error when using the Network Setup...
Install it from the Device Manager, but before you do that, if possible extract the driver and save it in a specific folder so that it'll make you easily locate when you browse from the "Found New Hardware" Wizard. Good luck.
May 21, 2010 | Biostar MCP6P-M2 Motherboard - v6.0,...
I recently purchased a new mobo (biostar mcp6p-m2). i am having trouble trying to boot up my windows xp disc. it keeps giving me a "DISK BOOT FAILURE, INSERT DISK AND PRESS ENTER". i have a feeling i may...
  1. Make sure the CD/DVD drive is connected and has power.
  2. You didn't say if the drive is IDE or SATA. If it is IDE, make sure the BIOS has IDE enabled.
  3. Check the 'boot order' in the BIOS and make sure the CD/DVD drive is first.
Mar 14, 2010 | Biostar MCP6P-M2 Motherboard - v6.0,...
No onboard video with my new MCP6P M2+ mainboard
Try removing the bios battery for 30 seconds then boot the pc, this will clear the bios. Maybe the bios was misconfigured. Else you can jump the "clear cmos" pins on your motherboard, same affect as removing the battery. If that doesn't work try different ram, it's possible the ram is not compatible. Sounds plausible being that there were no post beeps. Good luck.
Sep 14, 2009 | Biostar MCP6P-M2 Motherboard - v6.0,...
Black screen on boot on biostar mcp6p m2+
That board has a built in video card if I have the right info. If you are using an external video ie plug in card then you need to make sure the onboard video is disabled or that the plug in card is designated as the main video card. Not doing either of those will cause the black screen.
Aug 10, 2009 | Biostar MCP6P-M2 Motherboard - v6.0,...
MCP6P-M2 v6 not working?
u should change the ram and try again.
Jan 16, 2009 | Biostar MCP6P-M2 Motherboard - v6.0,...
Hi Just installed a new Biostar MCP6P-M2 motherboard and cant the sound to work for the life of me.
I think you installed windows xp sp3, try re installing with windows xp sp2 because microsoft removed support for high definition audio in sp3 version of xp, if you dont want to re-install or you want to use sp3, download the high definition audio update (kb835221.exe).
Jan 08, 2009 | Biostar MCP6P-M2 Motherboard - v6.0,...
SATA HDD lost contact
wtf? I think it may just be the **** Biostar SATA cable. Try replacing with another cable. Never would have crossed my mind. How the hell do you screw up a ******* cable, Biostar?
Dec 29, 2008 | Biostar MCP6P-M2 Motherboard - v6.0,...
Biostar MCP6P-M2 Motherboard - v6.0, NVIDIA GeForce 6150, Socket AM2, MicroATX, Audio, Video, 10/100 Logo
584 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
