Question about HP Compaq Presario V2000 Notebook
Does my v2000 have an internal microphone?
My daughter got an external web cam for Christmas, she can get the video to work but there is no audio. Is there an internal microphone or do I have to purchase an external one? Thank you.
(I have checked all of the settings and the sound is on... checked the control panel too...)
  • ljanniello Jan 01, 2009
    the webcam is made by HP and I don't see a model listed on the box, simply "HP Webcam." It has 100K pixels, CIF 352 x 288, works on LCD, CRT monitors, Compatible with AIM, Live Messenger, Skype and Yahoo Messenger...
    And yes, they did load the software and the drivers.... they were able to get video, but not audio.... I'm not sure if the web cam needs an external mic or if there is an internal one that is not turned on for some reason.....
    Thanks, all......
  • Mark Robinson May 11, 2010
    whats the make and model of webcam ?
  • 4 Answers
A V2000 should not come with an internal microphone; that is, I've never seen one. Check the front of your computer, where the headphone jack is: if there is another one with a little microphone icon beside it, then you will have to purchase an external mic.
cheers!
G33K_G1RL
Posted on Jan 02, 2009
    Problem Solver:
  • 11 Answers
If ur webcam is not working, then first of all connect ur webcam to laptop, then insert his cd into drive. and install drivers.and start ur cam. and remove ur cam after shutdown properly ur laptop.
Posted on Jan 01, 2009
How to disable the hp internal web cam so I can use an external web cam? Thank you!
Just connect the external web-cam.
Then, open the software that uses a web-cam, and configure it to select the external web-cam, rather than "defaulting" to the internal web-cam.
Aug 31, 2010 | HP Pavilion dv7-1130us laptop
The Audio in my webcam central won't seem to work can anyone help me fix this problem when i first got my dell it seemed to work but now it doesn't and i want to record a video but the audio won't seem to...
I have a Dell 1545 with Dell web cam central & I've had this issue. The problem is that Dell web cam central installs it's own microphone settings onto your laptop called something like Dell web cam Live!. This isn't the built in microphone in my laptop & maybe not yours either. You have to change the settings for your computer system & Dell web cam central. Go to start> control panel> sound> recording .. on mine there is an option for Microphone "High Definition Audio Device" ... that is the built in mic. You want that for your default & apply it. Then open Dell web cam central & go to the "Record Video's" option. In the middle of this is an orange button with a video camera icon. Next to this on the same button is a little arrow pointing down .. click that. Under microphone .. choose Microphone "High Definition Audio Device" just like the sound option in control panel. I've done this & it's completely fixed. I can record videos with sound & use my built in mic in voice/video chat.
Sep 28, 2009 | Dell Inspiron 1545 Notebook
Audio on Dell Webcam Central And voice record isn't working
I have a Dell 1545 with Dell web cam central & I've had this issue. The problem is that Dell web cam central installs it's own microphone settings onto your laptop called something like Dell web cam Live!. This isn't the built in microphone in my laptop & maybe not yours either. You have to change the settings for your computer system & Dell web cam central. Go to start> control panel> sound> recording .. on mine there is an option for Microphone "High Definition Audio Device" ... that is the built in mic. You want that for your default & apply it. Also .. as a side note .. I disabled the web cam central Live! microphone completely from this window. Then open Dell web cam central & go to the "Record Video's" option. In the middle of this is an orange button with a video camera icon. Next to this on the same button is a little arrow pointing down .. click that. Under microphone .. choose Microphone "High Definition Audio Device" just like the sound option in control panel. I've done this & it's completely fixed. I can record videos with sound & use my built in mic in voice/video chat.
Aug 15, 2009 | Dell Inspiron 1545 Notebook
Microsoft Lifecam / Using a different microphone
Im not sure I understood exactly the issue but the solutions are more than one ...
you may just uninstall the web cam ...and set the mic you want to use and after that reinstall the web cam ...and you have every chances to be installed and the external mic to remain in use..
or ...to use the mic from the external pink entry of the pc ...just select it from the sound driver ...options..
in your capture program you might also have the choice for which mic to use ....
in your yahoo messenger for example you have this choice on preferences /audio device....
you also may find on your control panel ...sound and audio device /audio../and for the sound recording audio device ...select the one you want...
good luck !
May 26, 2009 | Microsoft LifeCam VX-3000 Web Camera
Web cams and microphone
Hi, First I would suggest you get a Microsoft Life Cam VX-3000 as it will install the easiest and has a mic built in. Then I would suggest you and your family download SKYPE as it is FREE to talk on using the computer. It allows oyou to connect with several family members. Only have to pay if you telephone anyone from the computer using Skype.
So download SKYPE from this site: http://www.skype.com/intl/en/download/skype/windows/beta/
and follow these instruction to setup your voice/video.
Normal 0 After you install Skype and have it operational with you ID. Go to "TOOLS", click on "OPTIONS," Then go to "Audio Settings" and click on it. Make sure both the Microphone and Speaker's are correctly chosen. Then "make a free test call." Wait till the voice tells you to record. Then when finished talking wait for the test persons voice to insure your audio transmission is working. Then go back to options and test your video settings. Click on Video Settings and proceed to set up you video camera. Also, you can Visit this site for additional information to setup video.
http://www.skype.com/help/guides/video/
Hope this helps. Bud
Jan 02, 2009 | Microsoft LifeCam VX-1000 Webcam
The microphone does not work
Hi
Try booting in safe mode and reinstall the mic,sound(audio and video)driver and the web cam driver as well...
Good Luck
Genius Guy...
Oct 15, 2008 | Microsoft LifeCam VX-3000 Web Camera
Web Cam Microphone Not Working
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Aug 15, 2008 | A4tech Xmaster PK-835 Webcam
Lifecam video works great - but no audio!
do a cam/mic test in the audio/video settings in the tools tab in yahoo/msn. Then you need to minimise the yahoo/msn screen and right click on the cam icon in the taskbar and check that the mic and cam are enabled and that it is set to allow other programes to take control of this device
Dec 02, 2007 | Microsoft LifeCam VX-3000 Web Camera
Just bought a logitech web cam..But
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video should work. Enjoy.
Oct 18, 2007 | Logitech QuickCam Communicate STX Personal...
HP Compaq Presario V2000 Notebook Logo
207 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
