Question about HP Photosmart C5180 All-In-One InkJet Printer
Color from monitor to printer isn't the same.
I use adobe photoshop to edit my photos. When I get the color just right on photoshop and print the color on the photo changes. Highlights and shadows are not the same as what I adjusted on photoshop. How do I fix this?
    Sergeant:
  • 237 Answers
Go to your printer properties and play around with the options you are given. You may find an option for paper quality: photo paper, print quality in which you can choose from the options from economical to best printing to photo printing. This may solve the highlights and shadows if your printer is set to print regular business copies.
Posted on Jan 04, 2009
How do I Print in black and white only?
Color options, which also mean no color options are set in the program you are using to print. The printer just does what the program, like word, adobe photoshop, paint etc. tell it to do.
Feb 21, 2015 | HP Deskjet 2512 USB 2.0 All-in-One Color...
Canon iP4500 colour management
Try this setting. This might be different but try to point some similar preferences and steps then you can give it a try.
Open Control Panel (I'm assuming that the OS is Windows XP) click on Printers and Faxes.
Right click the Canon iP4500
Click Properties in the drop down menu.
Click on the tab Color Management
There should be a list of color profiles if the drivers were installed properly.
They are-
(Generic)
(Matte Photo Paper)
(Photo Paper Pro)
(Photo Paper Pro Matte)
(Photo Paper Plus Glossy)
The last profile is the one you want. Just above you will see the choice of "Automatic" or "Manual". Click on Manual and this force the printer to use the highlighted profile for all printing jobs.
Now click on DEFAULT.
Go back to the main Properties page and click on the General tab.
Near the bottom you will see "Printing Preferences"
click on that.
You should now be in a Canon ip4500 Printing preferences window.
Look for Print Quality and click "Manual"
Click on "Set"
Click on "Diffusion" and just above that there is a slider that should be all the way to the right.
Click "OK" to save the settings.
Now just below you will see "Color Settings"
Click "Custom" and then "Set"
Everyone sees colors a little different but the following settings print a photo that folks I show them too really like the balance of.
Cyan 4
Magenta -12
Yellow 0
Black 0
Intensity Slider in the middle
Enable ICM not checked (disabled)
Print Type set to Photo (you might want to try the other settings here to see how the prints look to your eyes)
Brightness Normal
Click OK to save settings and return to the Main Menu.
If you now go under the Profiles tab you should see you new profile there.
You can give it a special name like "Canon Excellent Profile Settings" clip_image001.gifor some other easy to remember name. This is the profile you want to use when you print a photo.
That is it...simple eh?
Now the other important part is in PhotoShop/PS Elements. Open the program and then open any old photo.
Under File, scroll down to Print Preview and click
If not open, click on "Show More Options"
Bring up "Color Management" in the box just below the "Show More Options"
For "Source Space" click ""Document"
This setting depend on the profile you shoot in, either Adobe RGB or sRGB. You choose the one you use.
Below that there is a setting for "Print Space"
You want to match that to your source, whether Adobe RGB or sRGB.
For the "Intent" letting I choose Perceptual.
Then click "Use Black Point Compensation" and that is it. Ready to print
Aug 08, 2008 | Canon Pixma iP4500 InkJet Printer
I have a Samsung CLP-315 laser color printer. I'm trying to find out if there's a *.icc or *.icm color profile for it to use with Adobe Photoshop. Couldn't find anything yet via google or others. Would you...
I have just purchased a CLP 325 and have set it up to get excellent colour pictures using Adobe Photoshop and the icc profiles readily available.
Your current working icc profile could be either Adobe RGB (1998), sRGB, Profoto or another. I would suggest that for everyday work use sRGB, if you are a specialist use Adobe RGB (1998).
Firstly make these changes in Photoshop:
Edit / Assign Profile / ColourMatch RGB.
To print:
File / Print / printer profile should be Adobe RGB (1998)
Illustration attached
Aug 24, 2010 | Samsung CLP-315W Laser Color Printer
My printer worked fine when I used it a month or two ago to print color photos. Now it is printing them in negative for no reason. Even when I do a preview before printing the preview shows the photo in...
When you are on the print window at the end of the process, look for a "Preferences" or "Options", then look for tabs or other menus that say "Color" or some sort of "output" mode and see if there is a negative option you can disable.
Apr 16, 2009 | Canon Pixma iP4500 InkJet Printer
Color prints yield only brown.
do the pictures look right on the monitor?
a program that comes with Photoshop is called adobe gamma, and it starts the first time you run photoshop needs to be configured. try that as well
also try in microsoft word , to color some text and print it, does it print in the correct colors??
if nothing works, try reinstalling the printer driver, maybe you have chosen the wrong driver.
tell me what you get.
Mar 26, 2009 | Canon MX300 Office All-In-One Printer
Printing issues with Epson r285
hi! try this! 1. go to control panel, select the printer, then right click the model of your printer, select properties, then select printing preferences.    in printing preference, select effect, then check the box of vivid photos. If you check vivid photos it will add enhancement to your printout. But thats not it, 2. open your photoshop, find your color settings, set your RGB color to (sRGB IEC61996- 2.1) then you CMYK color to (U.S. Web Coated (SWOP) v2) then off all your Color-management Policies and don't mind anything. 3. After your Edit your photos from RGB, then convert it to CMYK, then try printing it.
Dec 17, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Printing black and white photos from digitally taken colour photos
Hi Pat,
First you will have to check the Nozzle of your printer. To do this, press the setup button and select Nozzle Check. Use a plain paper to do this. Press Ok after that. It will print out a pattern for each color. Make sure that the lines are connected to each other specially for black since that you are printing a black and white photo. Lines going across is on a stair case pattern and should be connected to each other. Proceed with cleaning cycle if needed.
You can do a cleaning cycle using your printer of the computer. You can skip this if you have a good Nozzle check.
Using printer:
Press setup then select head cleaning.
Using computer.
Go to utility of the printer and find maintenance. Click on the head cleaning button.
Once that the nozzle are fine, you can now try printing. I strongly suggest that you use other application first instead of Adobe Photoshop. Since that Photoshop uses color management, it can be that the settings are incorrect. Save first the picture that you opened in Photoshop. You can save it on your desktop to easily locate the file. Make sure that the file is in jpeg format. Now to isolate the issue if it is cause by a software or not, try the standard application for your O.S.
Smaple Application:
Windows O.S. : Windows Picture and Fa Viewer
- right click on the file and select open with.
- select windows picture and fax viewer.
- folow the on screen instuctions.
Note: If you are now on the window on what pinter to use. Make sure that you set the option for printers under preferences to print in gray scale or black only. Select also the correct paper type.
- Proceed with printing.
Mac OSX: Preview or Iphoto
- open the picture under one of the application.
- click file then print.
- Make sure printer is selected.
- underneath the print option, you will have to go to print setting.
- find the option that says color then select black.
- select the appropriate settings for paper.
- the click on print.
Now see if it did print out corectly. If it did, it means that the appplication is the one causing this. If you are familiar with the color manage features of the application Photoshop. Let Photoshop handles the color. After getting to the widow what printer to use, to the the preferences of the printer and select the correct paper type. You will have to find the color management of the printer.
For Windows, It under the advance option under the main tab. Select off no color adjustment.
For Mac instead of going to print setting, find color manage and turn it off. Select off no color adjustment.
Then try printing.
Regarding your other question, If the printer is producing excess inks on your print out when ot comes to black printing and color printing, that pad needs replacement.
Aug 15, 2008 | Epson Stylus Photo RX700 All-In-One InkJet...
Photoshop and the R1800
I had the same problem and read everything I could find about it. Finally after tinkering around, I discovered that printing everything using "Photo Enhance" setting produced the best pictures. Also, I use a calibrated monitor and print through Photoshop Elements 5. Lots of Luck! Cyndy
Jan 28, 2008 | Epson Stylus Photo R1800 InkJet Printer
How do I calibrate my monitor? I have a new epson 3100z and a Epson photo Printer890... PIM is a joke..... I use adobe for image editing and image expert to print... My photos look great on the monitor but...
PIM uses the exif-info in your original jpg. I'm not sure, but I think if you edit the picture this exif becomes useless (because it relates to the original), even if you save the file including the exif-info. Also, you apparently you need additional printing software to make use of PIM. This was in the news on this site sometime ago. If you search, you can find out where to download this software. If you've got photoshop, you should also have a program called adobe gamma. With this you can calibrate your monitor. You should be able to find it under start->configuration. When you have calibrated your monitor, you should of course not use the settings on your printer that push up the saturation/contrast of your images, or else you will get Disney-colors. (I made the mistake of using 'digital camera correction' on the 1270 myself). I get good results printing from photoshop, with a calibrated monitor as well as some media profiles for the paper I use (just calibrating your monitor will probably be enough to get pictures that are close to what is on the screen, I just haven't tried that yet). If you want to calibrate your monitor, there are some good tips on http://come.to/digitaldarkroom. (it's where I got what I know about this). Btw, I cant seem to reach the site right now, but it will probably be up again in a few hours.
Sep 13, 2005 | Epson PhotoPC 3100Z Digital Camera
HP Photosmart C5180 All-In-One InkJet Printer Logo
181 people viewed this question
Seeker5211
Seeker5211
