Question about Linksys Wireless-N WRT150N Router
Laptop doesn't work with wireless router
Since returning from a long vacation and using my laptop in a different country, now it says that the settings saved on this computer for the network do not match the requirements.
Can you help?
  • eecom May 11, 2010
    Hi....Can you tell me/us where the problem is occurring, also which OS you are using?
    In Windows XP, for example, you would click the wireless icon in the notification area (bottom right) to view available wireless networks, then attempt to connect. Is this where the problem occurs - ie you're trying to connect to your current network and are locked out?
  • 55 Answers
Check to make sure you dident change the saved Key save in your computer
Posted on Jan 09, 2009
    Scholar:
  • 157 Answers
In the OS issue try to remove the ip address of your computer network...let the router find the ip address suitable for the network ip...
in the router issue...try to reset and reconfigure the router.it will be reset in the factory settings..all will be renewed....
there are 2 option to fix your problem..if not solve try to send message again..tnx
Posted on Jan 01, 2009
I purchased a SBG901 and have connected 2 MAC pc's wireless - 1 HP printer and 1 Compag laptop, I have one more pc which is running Vista on a HP Pavilion dv5 and visited the HP website to update
It might not be anything your doing wrong, the wireless portion of the card may have just gone bad. you could check this out by reconnecting your old router back up to verify it works or doesn't. If it doesn't work your wireless in your laptop went bad presuming that the wireless was not deactivated on the laptop. if it does work the Vista Driver may be incompatible with the new router, you may be able to hook up both routers at the same time which would allow you to keep using your HP system.
Feb 28, 2012 | Arris SURFboard SBG901 Wireless Cable...
Cant connect Verizon Wireless Router
Hi! Try to restart your router. If it doesn't work, try to restart your computer. If it still doesn't work, make sure that you don't have a power on/off for wireless on your laptop. If you have that button, turn it on/off and wait to see for a reaction from the laptop. If nothing happens, try to check the laptop's conectivity to other wireless devices. I hope this will work! Have a nice day!
Sep 02, 2011 | Sylvania G-Netbook
I have DSL-2640T router. I can't use the default ip address of that router ie. 192.168.1.1. I have a laptop. I want to join the laptop in my office through wireless. I don't know to make that router...
You could setup two different profiles, one for each wireless router.
Configure your home wireless router with a different SSID and encryption setting to the office wireless router.
Then configure the wireless card in your laptop with two different profiles, one for the office wireless router and one for the home wireless router. When you want to use the home or the office wireless router, just call up the profile you require.
Sep 26, 2010 | D-Link AirPlus DI-614+ Wireless Router
Wireless network
remove the wireless profiles on the PC and see if that helps - [b]Wireless Profiles
  • http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm
- Vista/windows 7
  • http://www.tp-link.com/support/showfaq.asp?id=214
- delete the wireless profiles Start control Panel classic view network and sharing center manage wireless networks
Delete the profiles you will then have to enter the wireless security key for any networks you connect to
Apr 11, 2010 | Dell Studio 17 Laptop
I hooked up wireless router for computer.....one laptop and an ipod work off the network,but i have another laptop that see's the network but does not connect.......the same laptop will connect to anyother...
The wireless card in this other laptop needs to be configured with this router's wireless settings. It is using the other wireless router's settings and therefore cannot connect to this wireless router..
Most wireless cards in laptops will allow you to setup different Profiles for different router's wireless settings. This will allow the laptop to connect to the different wireless routers by selecting the Profile for the wireless router you want to use.
I suggest you name the Profile by location which will make it easy to identify the correct wireless router.
Jan 04, 2010 | Dell Latitude D610 Intel Pentium M 1.6GHz...
My wireless laptop worked fine until i returned from vacation. Now i can't sign onto the internet. It says isp or no newtwork. What happened when I used this on vacation under my cousins router?
Check under network connections and see which network is set to default You may be trying to sign on and connect to the wrong network.
Please rate my help++++ Thanks for using FIXYA
Nov 24, 2009 | Microsoft MN-700 Wireless Router
PC works fine with Linksys USB card, but laptop's NetGear won't.
It looks like you are either using TKIP or AES just put the wireless to use MIXED and it will solve your problem.
Mar 19, 2009 | Linksys Wireless-G WRT54G Router
Linksys wireless-g
It has nothing to do with the brands. I do have different peripherals of different brands and they work well.
Maybe your son's laptop is more recent than yours. When you connect the wireless adapter to your laptop, does it detect the wireless network? I remember having a similar problem on vacation. At the hotel, I could'nt connect to the wireless network. The tech support told me to adjust some settings on my laptop. He said to go to the Network connexions, right-click on the wireless connection and selection Properties. Click on Configure...And select the Advanced button. Then on the list select Power on saving Mode. Other than Max power save mode.
Sep 06, 2008 | Televison & Video
Belkin Wireless Router Not Working.
The computer is not kaploot.
Stop.
Forget about wireless at the moment.
Power down your modem, router, pc and laptop.
Plug in a wired cable between the router and the PC and a wired cable and the laptop(you have ethernet cards in both, right?).
Power up the modem and let it completely cycle.
Power up the router.
Power up the PC.
Try accessing the internet from the PC.
Power up the laptop.
Try accessing the internte fro the laptop.
If this works write next week when you get back from vacation and we will get wireless working.
Jul 17, 2008 | Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
Password
In order for you to find your routers address, click START, RUN, type CMD followed by RETURN or ENTER, and type IPCONFIG/ALL followed by RETURN or ENTER. Look for DEFAULT GATEWAY. Put that address in your browser to access it.
Jul 12, 2008 | Linksys Wireless-G WRT54GS Router...
Linksys Wireless-N WRT150N Router Logo
123 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
