Question about Samsung SD 616E (729507925578) Internal DVD Drive
Media player says that it cant find the burner
HI
I am experiencing the following problem when I try to burn a CD.
I have the Samsung DVD ROM SD-616E. I used to be able to burn CDs via media player, itunes, etc but now I can only Rip the CD to burn then add my songs to the burn area, but when I click BURN, it tells me to "connect the burner and restart the player". But the Samsung is connected because it lets me listen to the CD, etc...can you help??
I guess you have a Read-Only drive - ROM. You need a CD/DVD RW drive for burning.
Posted on Jan 29, 2009
Wont read or write to samsung sw 248 drive i've uninstalled and rebooted drive and drivers, deleted all burning software i have itunes but used to be able to burn music before cant do anything now put...
HI,
This is gonna be a bit complicated since were going to access your registry, but just follow all the steps and it will be much easier
1. Click on START
2. Type REGEDIT on the search bar on START Menu on the Run Box
3. Expand HKEY_LOCAL_MACHINE
4. Expand SYSTEM
5. Expand CurrentControlSet
6. Expand Control
7. Expand Class
8. Click {4D36E965-E325-11CE-BFC1-08002BE10318}
9. Look for the Upper Filters / right click on it / click on Delete
10. Look for the Lower Filters / right click on it / click on Delete
11. Restart PC
12. Try you CD / DVD ROM
If nothing happens, click on this link then click on RUN and follow the steps, then restart computer and try to run a disc again, if still nothing happens, theres a possibility that the problem is with the hardware side or the media player that you are you using...
Hope this will help...Thank you for using Fixya...
Jun 22, 2011 | Samsung SW 248 CD-RW Burner
I have a dell dimension 8300 computer/ windows XP OS with a Samsung Sd 616e internal dvd Rom Drive. When I insert a dvd or CD nothing happens, except a whirring sound of continuous spinning. Also, when I...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Dec 06, 2010 | Samsung SD 616E (729507925578) Internal...
Cant burn a cd from toshiba laptop
your laptop might not be able to burn discs
Jun 03, 2009 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
Cant burn a CD/DVD on the Samsung DVD-Rom SD-616Q
This unit can read most formats, but it doesn't support write operations.
Mar 26, 2009 | Microsoft Windows XP Home Edition
Samsung dvd-rom 616E won't play sounds
I decided to check to see which video player programs were already on my computer. I have a Dell, so there were several that came preinstalled.
Did I mention that Windows Update had installed several new fixes recently?
My toolbar no longer worked like it did last week, that was a clue.
2 of my programs were no longer in the programs list, Interplayer and Power DVD were missing.
I went to the Power DVD site and downloaded the latest update.
Now my DVD player works fine.
I don't know why RealPlayer or Media Player didn't work, even with the updates.
I don't care, as long as something works.
I could have tried Winamp too but Power DVD worked and I didn't try anything else after that.
It doesn't have to be a problem with the hardware, but could be the software.
Nov 23, 2008 | Samsung SD 616E (729507925578) Internal...
Samsung SD 616E Internal DVD not working
I have the same problem, wont read anything in the drive. It is a master and there is no slave dirve so its not that, jumpers etc checked, drivers, cables. Just wont work.
Dec 14, 2007 | Samsung SD 616E (729507925578) Internal...
Need player for dvd-rom
you don't need a programme to run a dvd rom, you use windows media player, or if you mean burning software, try some of these free programmes http://en.softonic.com/search/win-dvd-player
Jun 11, 2007 | Compaq (294415-B21) DVD-RAM Burner
Unable to read some of the DVDs......
It's possible that the drive has died. CD and DVD drives are notorious for short lives but then I've seen some last 5 years. The lens could be dirty, just a small piece of lint is enough to cause hassles. Try using a Lens cleaner, available from all good audio shops. Some machines don't like +R disks and a firmware upgrade is needed. I've done many Liteon Drives with terrific results but if the manufacturer hasn't put one out then you're lost. It's possible you've used the wrong upgrade to fix your problem. With the prices of drives today it's sometimes cheaper to replace it. Believe me they can die quickly, my record is a week from brand new to unuseable and that was a Sony. BMW
Jun 03, 2006 | Samsung SD 616E (729507925578) Internal...
Toshiba A30 - DVD-ROM CDRW
Wow, That's a weird malfunction. Only TDK??? What about other media types? Did you try a diffrent burning software?
May 12, 2006 | Toshiba (SD-R2412) for Satellite A10, A15,...
Samsung SD 616E (729507925578) Internal DVD Drive Logo
289 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
