Question about Magic Chef CAV2000AWW Top Load Washer
MAGIC CHEF WASHER SPINS WATER OUT MAKING CRAZY NOISE & THE WATER GOES OUT ON THE FLOOR. WHAT'S WRONG? DOES THE PUMP HAVE TO BE REPLACED?
  • josieflo69 Jan 03, 2009
    We found the problem was -the drain pump was leaking & while the machine was spinning, something ground up the white plastic housing underneath the washer..to powder. it was all over the floor when we moved the washer.. Thanks for your response.
    Sergeant:
  • 311 Answers
Could be.pop the top and take off frount cover.run unit and look where water coming from.could alos inspect pump the pully dose come off on those an then drag metal to metal but normaly no water leak.also could be a bad tub seal you would see leaking from under neath
Posted on Dec 31, 2008
  • Thomas Malailua
    Thomas Malailua Jan 03, 2009
    dont worry about the white powder its fro the snubber that the tub pivits on[normal to see]
The washer filled up with water but not won't drain spin and is making a funny noise . It's an older magic chef.
The most common issue would be the coupler for the motor transmission. It is a rubber coupling and when it goes bad it makes a grinding, or whirring noise and the machine won't spin or wash. You need to remove the cabinet and look directly under the tub where the motor and tranny connect. This is a reletivly easy and cheap fix. Just google how to replace motor coupling on a top load washer and you may also include your make and model for more direct instructions.
Jun 23, 2011 | Washing Machines
I have a magic chef 20 lb capacity heavy duty washer model W20HN3S serial ME851474 with spin problems. Clothes come out soaking wet. Can I replace a belt?
If your washer will wash (agitate) your clothes but does not spin well, you will need to replace the "thrust bearing" in the washer. The repair is simple and will only take you a short to do. Here is a link to the "thrust bearing kit" you will need.
Jan 07, 2011 | Chef Cooking Magic Chef Washing Machine...
Margic Chef washing machine makes loud ginding noise when agitating and on the spinning cycle.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Magic Chef CAV4000AWW Top Load Washer
Waher works fine but when it gets to the spin cycle it starts making a horrendous noise like a bearing or something
the most common probelm is the drain pump. tilt the machine back so you can see underneath then grab the belt and push or pull it by hand and you should here the grinding noise you may aslo be able to see a silver ribbed disc stick up from the drain pump touching the bottom of the washer replace the drain pump
Aug 25, 2010 | Magic Chef CAV2000AWW Top Load Washer
MAGIC CHEF WASHER WONT SPIN OUT
underneath the washer is a pully assembly kit . remove the belt ,the c clip and replace the pully kit about $ 20.00 cost for parts.
Feb 02, 2010 | Magic Chef CAV4000AWW Top Load Washer
My washing machine drains but does not spin
Look for a motor belt that is worn out and make sure that the drum turns freely (machine off).
Aug 01, 2009 | Magic Chef CAV2000AWW Top Load Washer
MAgic Chef top loading washer will not spin or drain
you have to open it,at the bottom of the drum it has a either clear or black plastic hose that goes to pump held together with pressure clips remove them water will flow then ,it also will flood the aerea around it,so plenty of soil to soak it up
Aug 31, 2008 | Magic Chef CAV2000 Top Load Washer
Magic Chef CAV2005AWW makes a noise in agitate cycle
Sounds like a problem in the gear case. This would be a transmision replacement.
Dec 07, 2007 | Magic Chef CAV2005A Top Load Washer
Washing Machine Won't Spin/Drain
Apparently, there is an issue with this model. Get it checked out. I did.
Jul 31, 2007 | Magic Chef CAV2005A Top Load Washer
Magic Chef CAV2000AWW Top Load Washer Logo
212 people viewed this question
Top Magic Chef Washing Machines Experts
Ian Jones
Dan Webster
Dan Webster
Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
