Question about Kenmore Refrigerators
Leaking Kenmore fridge
Normal 0 Hi .
I have Kenmore refrigerators model 46-66812.
The problem with it that the water is leaking inside the main section of the refrigerator..
I defrost the refrigerator and opened the back panel of the freezer (top part) and checked the drain. I was able to insert a wire only about 10 cm. It felt like it is not just clogged with ice or something, but that it is closed with something hard. Is it right? Should not it be open all the way to the bottom? What could be the problem? What should I do?
I really appreciate you advice.
Best regards,
Igor.
    President:
  • 2,692 Answers
The wire could not bend past a a curve in the hose. Blow it out with a tire pump and compressed air or you also can buy a can of compressed air. Another option go from the bottom of the drain lone above the drip pan and run the wire up,or blow it backwards..
Posted on Dec 31, 2008
Kenmore elite 596.735 .water leaking from rear of water filter unit.
What is the complete model number of your unit? Look inside the refrigerator section.
Oct 21, 2012 | Kenmore 73502 / 73504 / 73509 Bottom...
Water leaking inside refrig below ice maker
Hi
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now ( Whirlpool makes many of the Kenmore branded refrigerators ) on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 22, 2009 | Kenmore Refrigerators
I have a Kenmore Cold Spot Model 70192000. Having
HI, I can help you with this. It sounds like the defrost drain is plugged. If you will get me the model# from inside the fresh food section of the refrigerator, I can look up this model and instruct you on how to repair this.
Thanks
Vic
Jun 08, 2009 | Kenmore 50522 / 50524 Side by Side...
All items in freezer were defrosted when I opened the door this morning. Fridge is semi cold.
Hi
Some leaking water refrigerator helps....
  1. My older style Amana freezer on top refrigerator is leaking inside
  2. My refrigerator is leaking water inside
  3. My refrigerator is leaking water onto the floor
My refrigerator is leaking water inside the fridge:
Thanks
Rylee
May 30, 2009 | Kenmore Refrigerators
Hot to touch
there is another fan at the bottom, rear, of the refigerator. remove the bootom panel and look at the cooling fins to make sure they are not bent into the fan blades. Caefully bend the fins away from the fan. this should improve the cooling of the refrigerator and get rid of the hot spot on the rail between the refrigerator and freezer.
Apr 26, 2009 | Kenmore 53542 / 53544 Side by Side...
Water leaking inside the refrigerator
Hi
Please do rate the solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
Apr 17, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
ok sounds like a froze or blocked defrost drain.take a pice of weed eater line about 6 feet .tie a good knot at one end.then feed the unnotted end down the drain hole and pullout at other end.when you pull the nott witt clean drain.if it wont go thru it may be frozen.you can shut it down over night or use blow dryer.watch out for water and electricty
Dec 31, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
323 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
