Question about GE WSXH208A Front Load Washer
GE Model WSXH208-How do you know if PUMP motor is not working?
Washier Machine -- water does not drain...undo the pump that attached to the motor pump and moved stuff inside...put it all back...however, the water still does not drain...is it the PUMP motor? How do I know? Does the PUMP motor make any noise or any air...how do I know if the PUMP motor is working? Please HELP! thank you
  • Thomas Malailua
    Thomas Malailua May 11, 2010
    more info
  • Anonymous Mar 18, 2014
    w.m does not run,only drain pump is on,no motor runing or water inlet works
    Problem Solver:
Found out the motor usually don't burn out that easy...therefore, I put it all back....let it run and felt the motor warming up....then it works....guess I was just a little antsy... ;=))
Posted on Jan 01, 2009
I have a GE front loading washing machine. it will not drain model is wsxh208
Hello there:
This is due to the drain pump being clogged
The drain plug is on the front of this washer - you can see it without removing anything - there is a small 5"x3" panel on the front bottom that you pull out and then the plug twists free - have a large pan ready and unsrew slowly - water will come gushing out - have towels at the ready!
There are 2 screws on the bottom of the larger bottom front panel - remove these and you can see inside
you will see the drain plug housing is connected to the water pump and there are two hoses connected to the housing and the pump one coming from the washer to the drain plug and one going from the pump to your drain.
Remove the hoses carefully - I used plyers to pinch the clamps together.
the hardest part of this is removing the drain plug housing and pump - because it seems like you should be able to just remove the pump - but you can not!!
There are two screws holding in the housing and pump - remove them and the whole thing pulls clear.
Once out you can make sure there is not more coins or **** in the thing. Three screws hold the housing to the pump - mark these with a sharpie before you remove them - because once it is off there are multiple ways to re attach it.
Once free of the drain plug housing spin the pump a few times and put it all back together -
Hope this is very helpful for you
Best regards Mike
Sep 28, 2010 | GE WSXH208A Front Load Washer
Washer not draining
a lot of GE washers use a separate motor/pump assembly that is supposted to drain the tank before it spins. That motor is not very strong and can stall if it gets a little clogged with hair or lint or cloth threads. My dad's did that from tassels from a bed spread that fell off in the wash. You can take the front cover off with a knife blade to push the lock clips in so the cover pulls off.
when you do that you can remove the hoses to the pump and pull the clogged material out.
Nov 07, 2009 | GE Washing Machines
Portable Dishwasher wont drain GE Model #GSC3508K00WW
There's a few things you can look into that won't cost you any money.
First, manually remove as much water as possible and then check the sump area for paper or any other large object clogging the drain. A cup or so of water in the sump area of your dishwasher is normal and it is there to prevent the seals from drying out. The dishwasher will pump this old water out before beginning to wash.
Make sure the door is properly latched as the pump will not drain if the door is not latched properly.
Check the belt, drain line, air gap, drain valve and solenoid assembly, the motor, and the pump. If your dishwasher uses a belt to drive the pump, and it has broken or come off the pulley, replace it.
If you have recently installed a garbage disposer in your home, make sure that the drain plug on the disposer has been removed. It's just a little plastic piece that blocks the hole where you hook the dishwasher drain hose. If your dishwasher drains through the garbage disposer, you need to run the garbage disposer before you run the dishwasher to make sure that the drain is clear.
There is a drain hose between the drain valve or pump and the garbage disposal or drain line. If an obstruction has blocked this, then your dishwasher won't drain. The drain hose is connected by clamps to the drain valve and the disposer or drain pipe. Remove it and visually inspect it for a clog or a kink. Try to remove any debris. If it is in good condition, just put it back on, and if not, purchase a new one to install.
If you don't have an air gap in the drain line, at least use a high drain loop. Making a large loop about 18" off the ground with the drain line can prevent any back flow into the dishwasher from the sink.
If you have one, the air gap will be located on top of the sink. The air gap is there to prevent any siphoning of standing water from the sink. When your dishwasher drains, the air gap diaphragm will form a seal and allow the water to drain properly. If the diaphragm in the air gap is faulty, it’s possible that water can leak onto the cabinet and into the sink area. When this happens, then the air gap must be replaced.
Like the inlet valve, there is also a drain valve on most models. When no power goes to the drain valve it remains closed and prevents water from leaving the machine. When the valve receives power during the drain cycle, the solenoid opens and allows the water to leave the machine. If your drain hose is attached directly to the pump, you don't have a drain valve. The motor simply reverses and the pump sends the water in the opposite direction, which is out of the machine.
If the motor doesn’t turn or work properly, the dishwasher may not drain. Make sure you have power to the unit. If you notice that the motor hums but won't turn, it could be seized, and you probably need to replace it.
if you need to buy any parts, I have had alot of help from http://www.apwagner.com
Small objects can sometimes get stuck in the pump. When this occurs, you’ll need to open the pump and remove any debris buildup. The dishwasher pump is usually mounted directly to the motor and runs off the motor as well. The pump is also attached to the bottom of your dishwasher and pushes the water from the dishwasher.There's a few things you can look into that won't cost you any money.
Oct 26, 2009 | GE 24-7/8" Convertible Portable Dishwasher...
Water did not drain
try to operate the machine emty and see if this will drain the water
if you have a filter check that is ok
check waste pipe and check if the pump is clear ( air noise if faulty)
if the water is emptied when machine has no clothes than it is the motor carbons
you have to chabge them they are ususally cheap 10-30 pouns dollar euros
depress the inset to release them and when replaced clean case in the motor so'' ignitions'' will work properly
any shOP REPAI AND PARTS WILL STOCK THEM GET THE RIGHT MODEL IN ORDER TO PURCHASE THEM
Sep 27, 2009 | Frigidaire 14 Cycle Tumble Action Washer
GE Washing Machine (model # GUSR2LOOT) drain problem
Check for a blockage in the water pump. If it does not drain first it does not spin. Check for power to the drain pump motor.If no pump blockage check the lid switch for continuity. No continuity, replace the lid switch.
Jul 03, 2009 | GE Washing Machines
I have a GE Front Load WSXH208 and it doesn't work.
Sorry I don't have any pictures of this handy, but here's what you should do:
Unplug machine. Take the front lower panel off by removing the two 1/4 inch hex head screws at the very bottom of the lower panel, right by the floor. Next pull the bottom of that panel out and down to release it from the two pegs at the top of the panel. Now, after you have removed as much water from the machine as possible with a scoop or cup, pull the machine forward about two feet and lean it back against the wall. (this will keep the rest of the water in the machine when you disconnect the hoses to the pump) Remove hoses from pump. Remove two screws holding pump to bottom of washer. Look for obstructions in pump, and also clean out the area of the hose just before the pump.
Reassemble and test.
Note: The washer will not spin if there is still water in it.
Nov 16, 2008 | GE WSXH208A Front Load Washer
Drain pump/motor not draining.
actually it sounds like there was or is something in the water pump (like a string or metal underwire from a bra). before replacing the water pump i would look inside it and check for foreign objects.
  1. unplug the machine, but leave other hoses connected
  2. use a butter knife or putty knife to open the front panel; at the top seam between the top panel and the front panel is 2 metal clips (about where the edges of the lid are). push these strait in to release the front panel.
  3. once the front panel is off then you should see the water pump on the right side. it has 2 large black hoses and 2 wires attached to it.
  4. take off the water pump (two 3/8 bolts) and look inside it.
some pictures borrowed from fixitnow.com, allpar.com, applianceaid.com and repairclinic.com
  • if you need to buy a new pump, then they are around $50 at repairclinic.com
  • or shop around; GE Washer Pump part # WH23X10013
  • here is a cheap one on ebay:
http://cgi.ebay.com/GE-WH23X10013-Washing-Machine-Washer-Water-Pump-Motor_W0QQitemZ170239837032QQihZ007QQcategoryZ20714QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
let me know if you get stuck
Mike
Jul 30, 2008 | GE WJSR2070B Top Load Washer
Clogged washer pump
you have to take out the little motor that drains the water and clean it up , first you open the front panel or back panel depending of the model , second follow the DRAIN HOSE to where its attached to the DRAIN MOTOR , remove the motor for cleaning , its probably clogged.
Apr 05, 2008 | GE WBSR3140DW Top Load Washer
Ge washing machine model wip4013srw how to fix the problem
Unidentified buzzing noise in top loader machines is often due to a jammed or seized drain pump, especially if the pump has its own motor - sometimes just opening the front of the pump (usually under a panel at the base of the front, possibly behind a small - 3-4 inch - panel to one side or other) will clear it. behind the pump cover will be a sealed plug or similar, usually needs a half turn to undo. small pieces of wood or plastic sometimes are the cause, and may be "floating" on the drum side of the drain pump so may not be visible immediately. Make sure the machine is unplugged and check with your fingers to see if the pump blades rotate freely - they will have some resistance, but should not feel like you are pressing against something solid. If you still have the manual for the machine, somewhere you would expect to find detailed instructions for a user to clear the pump - it is not usually a difficult or complicated job however some machines have a very different drain system. You may have a certain amount of water comes out over the floor - this is normal. On an optimistic note, many of these machines are still functioning after more than five years with no problems, so it is likely to be minor. If you suspect the electronic control to be the reason for the problem, it may just be that it will not continue a cycle without properly draining, even if the drum appears to be draining adequately - check the drain pump. The pulley attached with string is slightly unusual - perhaps this is as a result of an old bodged repair and needs to be resecured - without more detail or a photo this is hard to say. Best solution for that would be if you could find a similar machine, possibly in a second-hand shop and ask to look at the base to see if there is anything obviously different with your machine.
Feb 12, 2007 | GE WBSR3140DW Top Load Washer
GE WSXH208A Front Load Washer Logo
387 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
