Question about E-Machines (T3104) PC Desktop
PC freezing up after memory upgrade
I upgraded the memory on an EMACHINES T3104 desktop from 256 to 2GB (2 X 1GB Samsung DRR PC3200 chips/mem cards), and after doing so, the PC freezes up at diferent times, no matter what application I may be using (even while doing updates). In looking at other online forums, I'm seeing where it's possible that I need to check/change a BIOS setting to make the 2GB memory work. While I am above average in computer knowledge, this is an area I am deficient in. This "freezing" did not occur with the single 256 board. I can't believe I would be unable to not use the full 2GB capability of the machine memory. Thx for any responses
  • dirtbag170 Dec 31, 2008
    Thx very much ****. I will try all these suggestions.
    President:
  • 948 Answers
You can use a utility called CPU-Z to find the timing of the memory installed in the PC. Then check your memory documentation (I could find no specs at the Samsung site) to make sure they match in the BIOS. I would remove one stick and see if the problem is better, and also try another brand (Kingston, Corsair, other major brand) to see if any of them work.
Posted on Dec 31, 2008
I bought 2 x 1 GB 128M x 72 333MHz PC2700 DDR SDRAM cards to upgrade my HP Compaq dx 6100 MT Pentium 4 Desktop - Upgraded the BIOS as prescribed...BUT if i insert these memory cards in any order in the...
wrong parts, its not support by chipset
Memory
One of the following
2-GB DDR Synch Dram PC3200 (400-MHz) Non ECC (2x 1GB)
Memory Speed Supported DDR Synch DRAM PC3200 (400MHz) non-ECC
Product documentation
Dec 20, 2014 | HP Computers & Internet
I want upgrade my emachines t6528 hard drive and ram.i need help
Memory Upgrade for eMachines eMachines T6528 Computer, the eMachines eMachines T6528 Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your eMachines eMachines T6528 Computer to up to a maximum of 4.0 GB Memory, the system has 4 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
As for the Hard Disc.... the following address will give step by step instructions on installing a new HD. http://www.manualowl.com/m/eMachines/T6528/Manual/
Thank You for using FixYa
Tom Miller
KD4DTK
Aug 19, 2012 | E-Machines T6528 PC Desktop
Have an older emachines T3104. The hard drive died, so had to reload OS (XP Home). The emachines website no longer lists the sound drivers for this machine. Where can I get them?
If you know the manufacturer of sound chip, go to their web site and get the driver.
You can look in the device manager to find the sound chip manufacturer.
Apr 06, 2011 | E-Machines (T3104) PC Desktop
Information on what type of memory upgrade device
Standard Memory: 512 MB - (MegaByte)
Approximately 1 million bytes','300')" onmouseout="hideddrivetip()" href="http://www.ec.kingston.com/ecom/configurator_new/modelsinfo.asp?SysID=25761&mfr=eMachines&model=eMachines+T3104&search_type=&root=us&LinkBack=http%3A%2F%2Fwww.kingston.com&Sys=25761-eMachines-eMachines+T3104&distributor=0&submit1=Search#" ;>MB
(Removable)
Maximum Memory: 2 GB - (GigaByte)
Approximately 1 billion bytes, or exactly 1 byte x 1,0243. (1,073,741,824) bytes.','300')" onmouseout="hideddrivetip()" href="http://www.ec.kingston.com/ecom/configurator_new/modelsinfo.asp?SysID=25761&mfr=eMachines&model=eMachines+T3104&search_type=&root=us&LinkBack=http%3A%2F%2Fwww.kingston.com&Sys=25761-eMachines-eMachines+T3104&distributor=0&submit1=Search#" ;>GB
Expansion: 2 Sockets
CPU & ChipSet: AMD Sempron
Bus Architecture: PCI; USB - (Universal Serial Bus)
Standard connection for peripherals such as digital cameras, scanners, printers etc. Allows for quick and easy data transfer. Uses the plug and play facility available with Windows 98 / ME / 2000 XP or Macs.','300')" onmouseout="hideddrivetip()" href="http://www.ec.kingston.com/ecom/configurator_new/modelsinfo.asp?SysID=25761&mfr=eMachines&model=eMachines+T3104&search_type=&root=us&LinkBack=http%3A%2F%2Fwww.kingston.com&Sys=25761-eMachines-eMachines+T3104&distributor=0&submit1=Search#" ;>USB
Mfgr's System P/N's: N/A
Comments MODULES MUST BE ORDERED AND INSTALLED IN PAIRS for Dual Channel.
KVR400X64C3A/512
KVR400X64C3A/1G
KVR400X64C3AK2/1G
KVR400X64C3AK2/2G
Jul 22, 2010 | E-Machines eMachines Desktop PC
Can I add 1GB memory chip in 2nd slot with a 512MB chip in 1st?
You can upgrade by inserting a 1GB PC2100 DDR SDRAM DIMM. I would put the 1MB in the first slot and move the 512MB chip to the second slot.
The 1GB should cost around $40.
Jul 05, 2009 | HP Pavilion 763n PC Desktop
Chip size
yes as long as it is the same ddr and not sdr
Jun 01, 2009 | Computers & Internet
Not recognise memory for windows XP.
the 4260 takes PC2700 DDR. not PC3200, also the 4260 take only memories with special chip buildin for that particular motherboard.
Mar 11, 2009 | Dell Dimension 1100 PC Desktop
Dimension 2400 is at 1.5MG - will not go to 2.0MG per manual!
yeah thats a normal issue with the dimension 2400 as the older bios only supports a max of 1gb of memory you will need to go to the dell website which ive linked below and get the bios update which will give you support up to 2gb-pc3200 ddr memory
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_CEL_2400&os=WW1&osl=en&catid=&impid=
Dec 07, 2008 | Dell Dimension 2400 PC Desktop
Its about the memory card
The board supports upto 4 GB RAM. PC3200 RAM is supported.
1. Reset CMOS settings by CMOS jumper.
2. Try updating BIOS of your motherboard from :
http://support.asus.com/download/download_item.aspx?product=1&model=P5GL-MX
Best of Luck,
rajesh_im
Feb 13, 2008 | ASUS P5GL-MX Motherboard
E-Machines (T3104) PC Desktop Logo
215 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
