Question about SanDisk Sansa Shaker SDMX9N-512 MP3 Player
I bought my daughter a sansa shake for christmas and it wont sync on any computer?
  • 3 Answers
I wouldnt use sync feature for the shaker read the following:
check the file types from you music the shaker only plays MP3 and PCM WAV  file types. You may have WMA (if u used windows media player) which will not play on the shaker  (i had this same ploblem btw) you can easly find free music file converter software to change these files to mp3 or wav types (which i did), or you could rerip to songs from a cd and tell the windows media player to rip the files as mp3 types instead of the default wma format  from the windows media player widow :
tools >> options >> Rip Music >> under format select mp3 (theres a wav option but i used the mp3 option to be safe)
do not use the sync feature it will automatically convert your files to to wma (why? i dont know) instead copy the files directly from the folder that contains them :
right click the file you need to put on the player select open file location drag and drop to the player (or copy/paste if you want).
hope this helped =P
Posted on Dec 31, 2008
I bought my sansa mp3 4gb from radio shake but i don't know how to transfer music from cd or internet to my mp3, I tryed , I instaled the cd to my computer but it didant say any think about how to transfer...
The easiest way is to use Windows Media Player to Sync the songs you would like on it. Plug the MP3 player into the computer, go the the Sync tab of Media player and add songs to the list. When you are done adding to the list simply click Sync.
The other way would be to go under My Computer and open the MP3 contents by right-clicking on Explore and copy and pasting the songs, video, or photos into the right folders. The video will have to go through the Sansa Media Converter first though to be in the correct format.
Dec 07, 2008 | SanDisk Sansa e250 MP3 Player
I have a sansa e260 and it connects and charges on computer and program can be located but computer is not reading that it is connected so can't sync it. Can you help? Thanks. Michele
I found another complaint similar to mine and someone had posted a solution, which also worked on my daughter's Sansa e 260.
I went to settings, then usb mode and selected MSC instead of MTP and computer instantly recognized the hardware and I could sync her music for her! Can't remember name of person who'd posted solution, but thanks heaps!
Sep 14, 2008 | SanDisk Sansa e260 MP3 Player
Sansa wont charge
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
May 17, 2008 | SanDisk Sansa c200 MP3 Player
I'm new to MP3
itunes is protective of it songs so i don,t no about that
but i have a sansa m240
on the player hit the menu Button
its the shall one on the top
till it turns on then let go and press it again
scroll down to settings press the white Button
below the play Button. scroll down to usb
then select auto detect
plug in the player to your pc
you can transfer them yourself
or use windows media player 11
to
transfer them yourself right click on the music
go down copy click
go to my computer or computer in start menu
select sansa m230
select tcnando hit ctrl v
on the key board
to transfer the the files
to use windows media player 11
open windows media player 11
plug in player to pc
a window should pop up
follow the instructions
than click on the sync tab
you should see the sansa
click and drag the music
from the left hand side
to your players sync list on the left
and click start sync .
I hope i could help
Apr 10, 2008 | SanDisk Sansa m230 MP3 Player
Very new to this-got iPod, can I put songs on SanDisk?
I bought a sandisk and it came with best buy stuff loaded. Well best buy stuff expired and i have a lot of memory tied uop with it. I want to totaly reformat and remove all related stuff to best buy so I can start from scratch
Scan disk sansa c200 series locked with an error message
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
Apr 04, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa shaker
-Tha Mp3 Doctor
Mar 01, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Sandisk sansa
Go ahead and do this, in case the DB is corrupted:
Feb 08, 2008 | SanDisk Sansa e250 MP3 Player
Mp3 format??? HELP, PLEASE!
No You Don't Have To Converter The Tracks. It Depends On How You Put The Tracks On Your Sansa, Do You Drag And Drop Or Do You Sync With Copy To Device In Windows Media Player 9, Or Sync In Windows Media Player
Dec 30, 2007 | SanDisk Sansa e250 MP3 Player
Sansa shaker not playing
Funny I found this forum because I've been having the same problem. My understanding is that subscription services (yahoo music, iTunes, etc.) don't come in an mp3 file format. You can, however, add songs from cd's you own.
Here's a link you might find helpful. It's from the Sansa Forums. One of the posters describes how you can convert files. I don't know how complicated it is. Good luck! :)
http://forums.sandisk.com/sansa/board/message?board.id=shaker&thread.id=121
I understand your frustration! I've been having the same problem. I just wasted TWO HOURS trying to get music to download onto this Shaker. The extra $40 for a better device would have been worth it! I can't afford to buy all the cd's that I'd need to fill this player with the songs my son likes. I'm thinking of bringing it back!
Dec 18, 2007 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
SanDisk Sansa Shaker SDMX9N-512 MP3 Player Logo
90 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
