Question about BenQ FP71G 17" LCD Monitor
BenQ FP71G+ Monitor is almost 2 years old, and while playing BF2142, monitor went black. nothing shows. light stays green when connected to a video device(tried it on both my desktop and my laptop to ensure it wasnt the vid card), and when not connected but powered on, green LED on front turns to brown, so it knows when it has signal. ive disassembled the monitor, and can provide pics of the cards(looks like there is a fuse built into the PCB with the power connection(right behind power connection) which looks blown(I think this is my problem), additionally, the item labeled T601 on the PCB with power plug(dont know what it is called... box thing with yellow tape all over it) shows some blacken marks on the yellow tape. Anyone know what that fuse is for, and does this sound like my problem?
  • 4 more comments
  • Jason Fisher May 05, 2007
    ok, went and got a multi-meter, fuse reads good... but still wont display anything and power is on.
  • Iulian Dec 15, 2007
    At the beginning or in use, my LCD comes black. If I disconnect and connect again data cable or power cable, the image rise again, for one our or more. Image never re-comes if I use on/off taste. When screen black, power LED is green.
    Had you this problem? How did you resolve it?
  • Anonymous Dec 16, 2007
    My FP71G+ monitor went
    device(tried it on both my desktop and my laptop to ensure that video card was working , and when not connected but powered on, green LED on front
    turns to brown, so it knows when it has signal. Opened back panel and there are no visible signs of any components being burnt or damaged.
  • Anonymous Mar 01, 2009
    I have same prob. with monitor. Screen black, light green. after screws are removed, my case does not want to pop open easily. Any suggestions?
  • AzZerot Dec 13, 2009
    i have a problem with my Benq fp71g+
    last night i put it near a monitor with tube and it turn in green
    can anybody help me to get loose of that green?
    Thanks
    tazz_tavy@yahoo.com
  • Nitay May 11, 2010
    How did u guys manage to open the back panel of the monitor? I unscrewed 4 screws in each corner of the panel, and 1 screw right underneath the holder. Did i miss anything? My FP71G+ won't open... Thanks Spofer
We recently come across this problem - and like many others - looked online for a solution without much luck. So it was a clear case of fault finding. The symptoms of the indicator changing from amber to green on signal indicated a problem with the powersupply/inverter board, and not the smaller signals processing board, so that's where we started. On careful testing it soon became clear that the black picofuse (just above the main transformer) was blown. This indicated a major fault in the backlight driver circuit. There are two independant yet identical circuits that drive the backlights - this made testing easy. We found that the two driver transistors marked C5707 were almost completely shorted. You will identify these as being two of four identical black components with a built in heat sink at each end of a grey 0.22 Microfarad capacitor - looking much like bookends! Replacing these C5707 transistors with BD139 transistors (Note: these are constructed mirror image to the original transistors - fit them backwards to the original transistors !) and replacing the 3 Amp picofuse with a 1 ohm 1 watt resistor completely solved the problem ! - Colin Knight, Radtvid Electronics, South Africa.
Posted on Dec 31, 2008
I have the same problem, I also openned the rear panel and examined the power pc board, there is definately burn marks on the board... not sure if it would be easier to order the main board from the company and re-install.. Also, could it be the smaller board I guess it would be a video pc board. Please let me know if you solve this problem. Thanks!
Posted on May 18, 2007
Check the following: http://www.electronicrepairguide.com/benq-fp731-lcd-monitor-repair.html Seems a likely solution - however did not work for me, I have something else . . .
Posted on Sep 21, 2007
    Champion:
  • 220 Answers
For display off problem definitely first culprit is Inverter board.If readily available replacement will solve the problem.
Posted on Feb 16, 2008
JHHJIYUTYEYFUFUUYGKBUYJG
Posted on Feb 13, 2008
My BenQ FP71G powers on and off, repeatedly, by itself no matter whether connected to computer or not. Everything else is fine. Sometimes it stays on for a minute or so, but usually for just a few...
my BenQ FP71G 17 in goes on after hundreds of times pushing on off switch and when it's on it does not go off, I have checked the on/off switch which is working oke and when the moniter is on the auto adjust message (brightness and contrast)pops up frequently and the screen adjusts itself.
Oct 12, 2010 | BenQ FP71G 17" LCD Monitor
BenQ FP71G+ LCD Monitor fault
its not the fault with the monitor..its the VGa Cable thats going loose..plzs check the connections ...and contact the vendoe for furtehr support or replacements whichever is applicable
Mar 14, 2008 | BenQ FP71G 17" LCD Monitor
My LCD screen stopped working. Playing a game when the monitor was blackened. This time the screen is black. If I start the monitor, the led is orange, if I connect to my PC led color turns green but does...
victorash02, Is screen black n blank, or just black? Do flashlight test! Yes it could be both! Most likely problem with unit's internal "switch-mode-power-supply"/"CCFL inverter supply". You or technician will need to investigate for probable cause of black screen of death. Need a little history of unit! Did it work just fine 2 weeks ago? How many "ON" hours of use on the unit? When was it made? Did you PROVE that PC not cause and works ok? Get back here with more info so we can help.
12fixlouie on fixya. Read my fixya profile for a little while.
Mar 09, 2010 | BenQ FP71G 17" LCD Monitor
Not display not lighting
Check data interface cable. if connected replace the same.
Aug 23, 2009 | BenQ FP71G 17" LCD Monitor
I have a benq fp71g model q7t4 computer monitor when i hit the power button the green indicator light comes on but goes right off i can hear a clicking sound when i hit the button what can i do
use another monitor with your pc to make sure your graphic card is working and
connect that benq monitor (to double check it is ok) another pc
find out if the clicking comes from the monitor or the pc tower,
if yes from the tower than your video card fails.
exchange it with another and replug benq monitor, boot up.that should solve the prob
Jul 28, 2009 | Computers & Internet
When i turn on my monitor it shows my desktop then shuts off after 10 seconds...never stays on
elainenemeth, Hi, Tell me more! How old is this LCD monitor? Is it out of warranty? Did the "SHUT-DOWN-IMMEDIATE" problem occur without warning? Did the BenQ display a "perfect" image the day before? Did you actually count----1001, 1002----1010 and then it shut down, after pushing the monitor on button. Did you do the "flashlight" test? With monitor connected to a "known-good", fully booted pc with Win Desktop displayed, TURN ON the monitor! Did it display the desktop for 1-2-10 seconds ? What did you see or not see when you pointed the flashlight at different angles about 1-2" inches from the now dark (black) screen? Get back to me with your results. I will offer the best advice possible to you as a consumer/user of LCD/FPD monitor. I'm louie12fix on fixya or lmistyrel @ aol.com Bye for now.
Apr 17, 2009 | BenQ FP71G 17" LCD Monitor
Problem with moniter
i have BENQ lcd 15" monitor, the problem is that the menu appear atomaticaly
Aug 25, 2008 | BenQ FP71G 17" LCD Monitor
Benq FP71G+S NOt starting.
Hello
I have had this problem twice once at my school and once with my BenQ FP71G Monitor. At my school the monitor ( HP ) just stopped working and smelt like burnt popcorn.(though is think this is due to some kids chucking a soccer(football) ball at it! With my BenQ it has the same problem though i nownthink it is because of the monitor has been on for excessive hours ( 3-4 ) and just shut down because of overheating. I will see in a couple of hours if it works !
Copper_R
Dec 30, 2007 | BenQ FP71G 17" LCD Monitor
BenQ FP71G 17" LCD Monitor Logo
3,197 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
